Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Mon Jul 14, 2008 11:19 am Post subject: 009 advance spring Q |
I'm going to sell this 009 and wanted to make sure all the correct guts are inside. Is it suppose to have another advance spring?
_________________ Justin |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Mon Jul 14, 2008 1:39 pm Post subject: |
Thanks Glen. Somehow, I knew you'd reply to this one... _________________ Justin |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Mon Jul 14, 2008 6:44 pm Post subject: |
I have a old German Bosch 009 that has two springs, it works great, no flat spots and its all in at 30 degrees at about 3500 rpm. I also have a newer Bosch 009 that is not marked Germany that only has one spring. I was going to rebuild the newer one and try it in my car to see if it makes any difference.
Earthquake _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
dan97019 Samba Member
Joined: December 01, 2006 Posts: 326 Location: portland Oregon
Posted: Mon Jul 14, 2008 7:35 pm Post subject: |
I have 4 different 009's all that i have had for at least 15 or 20 years, 3 have 1 spring and the only one that says germany on it has 2, I have tried them all in my car over the last week or so and they all behave a little different they all have the flat spot but the duration and the location seems to change slightly in each distributor im still trying to decide which one i like. |
Dale M. Samba Member
Posted: Mon Jul 14, 2008 7:50 pm Post subject: |
First thing we do when we get dist. from this guy is pull out extra spring and throw it away.....
http://www.thesamba.com/vw/classifieds/detail.php?id=490347
Posted: Mon Jul 14, 2008 11:01 pm Post subject: |
Where does this flat show up, my car does not seem to have any flat spots from idle to 4500 rpm which is about where I shift. my motor is a stock 1600 DP with a 009 with blue coil and a cheap 1 3/8 header with "J" tubes and a stinger. I also jetted it up two jet sizes over stock [34 pict3] and I think I have the timing set at 10 degrees BTDC.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
