joe comfort Samba Member
Joined: March 18, 2005 Posts: 408 Location: Lake Havasu, AZ.
Posted: Mon Jul 14, 2008 6:52 pm Post subject: Stuck right rear drum |
I have read the threads on this problem and still I can't remove the right rear drum off my 66 Westy.
I soaked it with Kroli, I loosened the castle nut and drove it around hoping to brake it loose, I backed off the shoes, I used a sledge to break it loose, I used a torch and got it cherry red and used a heavy duty 3 arm puller and still it is stuck. With help from a friend we used his ultra heavy duty puller and still no go, even began to bend the 3/4 inch plate. I have come to point where I have to cut the drum off. Some say cut it off, others say don't.
Any help is appreciated, I am readying my Makita with cut off blade for the impending drum surgery!! Any suggestions?? |
big bus mike Samba Member
Posted: Mon Jul 14, 2008 7:17 pm Post subject: |
Soak the drum with brake fluid and let it sit for a day. Repeat 2 or 3 times. Then hit it with a torch and see if you can break it loose. |
Posted: Mon Jul 14, 2008 7:33 pm Post subject: |
Thanks Mike, I will do that. Also a friend suggested also to use a jack hammer to vibrate it loose. He had the same problem and an old timer mechanic did this and voila it came off. We'll see!! I will hold off on the Makita for now. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24737 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jul 15, 2008 7:13 am Post subject: |
If all else fails, go down to your local Rental Store and rent a drum puller. Make sure to rent the five lug type and not the three lug type. _________________ In Stereo, Where Available! |
Posted: Thu Jul 17, 2008 4:58 pm Post subject: |
Well I finally got it off!! I used PB Blaster and let it soak, then I used a Bosch 60 lb jack hammer to rattle it loose at the stub axle and finally my 3 arm drum puller. I slammed on it for 1 hr and 15 minutes before I got the drum off. What a PITA!!
So the jack hammer was the trick and PB Blaster is some good stuff, think I'll PB Blast my SO-42 table leg and see what happens. I was dissapointed with the performance of Kroil, expensive too. |
fizzbang Samba Member
Joined: September 07, 2003 Posts: 196 Location: Oregon
Posted: Thu Jul 17, 2008 5:51 pm Post subject: |
Here's my home built drum puller:
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Fri Jul 18, 2008 3:20 pm Post subject: |
I've read that loosening the nut, reinstall the cotter pin (nut still loose) and driving around the block will loosen a stuck drum. |
Posted: Fri Jul 18, 2008 8:35 pm Post subject: |
TimGud wrote: |
Yup, BTDT, and over 500 miles later it was still stuck!! _________________ In Stereo, Where Available! |
kombisutra Samba Member
Joined: October 02, 2003 Posts: 4127 Location: San Anselmo, 10 miles North Of San Francisco
Posted: Sat Jul 19, 2008 3:31 pm Post subject: |
[quote="joe comfort"]Well I finally got it off!! I used PB Blaster and let it soak, then I used a Bosch 60 lb jack hammer to rattle it loose at the stub axle and finally my 3 arm drum puller. I slammed on it for 1 hr and 15 minutes before I got the drum off. What a PITA!!quote]
Absolutely amazing and true. I worked on this impossibly stuck drum and nearly broke my 3 leg puller. This is the only drum I've failed at getting off, even Ronnie chickened out, likely not wanting to mar his 100+ to 100+ drum pull ratio. Only the seals are getting replaced as the RGB seems ok, despite the outer bearing definately getting hot as hell.
The spacer behind the drum was also impossibly stuck, so today Joe heated it generously, and it ultimately proved welded on the stub axle too, as no amount of careful, then abusive methods could loosen it. Soooo, we resorted to very carefully spinning a thin wiz wheel helically through the top 80-90% depth of the spacer, then splitting the spacer at that cut with a cold chisle.
Yeah, I'm thinking about the carnage of the accident when the stub axle breaks because it was heated to high hell too, but I've never heard of a 46mm stub axle breaking. Have any of you guys heard of a 46mm stub axle breaking under normal conditions either? That this one likely has lost some of it's strenghth from being heated, let's just pay attention to the reliability of if over time. |
