gregb Samba Member
Posted: Tue Jul 15, 2008 7:09 pm Post subject: Piece of fuel flange in Engine Block... HELP |
I was trying to replace the fuel pump flange that goes into the Engine block and a little piece (1/2" or so) broke off and fell inside. The crank and everything turns fine, - should I be worried?
I figured it will just grind up and I can change the oil after a few km's or so since its only plastic. If it was a nut or bolt I would obviously have to split the case.
Thanks! |
63karmanng Samba Member
Posted: Tue Jul 15, 2008 7:38 pm Post subject: |
Yea you might wanna try to get that out of there..... _________________ I don't think that the voltage matters because the gauge is mechanical. |
mharney Samba Member
Posted: Tue Jul 15, 2008 8:02 pm Post subject: |
Does the engine have an oil filter? If not, you better get it out of there for sure. You can probably find it with a coat hanger or something after you drain the oil. |
Bill271 Samba Member
Posted: Tue Jul 15, 2008 8:55 pm Post subject: |
Mark the only way your gonna find it is to pull the oil pump, think about it................... |
gregb Samba Member
Posted: Tue Jul 15, 2008 9:10 pm Post subject: |
Bill271 wrote: |
If I pull the oil pump, wont I just be staring at the Cam gear or is there going to be more room to fish around for the piece? |
Posted: Tue Jul 15, 2008 9:14 pm Post subject: |
Well when you look at case the cam gear is blocked away from the crankcase, if you got rude with that piece it might be down below but if not itll be behind the pump, by the way its called rynlite |
gregb Samba Member
Posted: Tue Jul 15, 2008 9:20 pm Post subject: |
Bill271 wrote: |
Thanks Bill, under further inspection and the help of a flashlight I can see the little bastard on the other side of the oil pump. It just sitting on the ledge under the dizzy gear. I cant reach it for the life of me, tried coat hangers and screwdrivers, etc. Can I pull the dizzy gear out with little hassle or does more stuff have potential to fall in? I've never taken out the dizzy gear with the case together. |
Posted: Tue Jul 15, 2008 9:23 pm Post subject: |
You can pull the drive out but remember it has shims underneath it that are almost tool grade steel lose 1 and ................get a shop vac and tape it up to a small piece of hose and suck that bitch out |
Posted: Tue Jul 15, 2008 9:24 pm Post subject: |
Bill271 wrote: |
Oops.. you caught me slackin. lol!
Thanks for clearing that up. Sorry Greg. |
Posted: Tue Jul 15, 2008 9:30 pm Post subject: |
Is that a 1200 or 1500 i cant tell the diff .....theres no turbo..... that would be me right there |
gregb Samba Member
Posted: Wed Jul 16, 2008 8:38 am Post subject: |
Bill271 wrote: |
I think pulling the drive out will give me access to that little bastard. I'm just worried about these shims you speak off. I may be better to just grind up that piece and leave the drive be. I'll give it some thought...
The motor is from a 73 beetle, 1600cc dual port. |
Posted: Wed Jul 16, 2008 9:47 am Post subject: |
If you can see it, get some of those claw grabbers and fish it down there and try to get it that way. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Wed Jul 16, 2008 5:05 pm Post subject: |
just for reference:
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
