galencurrington Samba Member
Joined: March 16, 2004 Posts: 426 Location: bowling green, ky
Posted: Wed Feb 01, 2017 11:52 am Post subject: Re: What parts are '68 only? |
i just saw that cip1 is finally selling the top 68 only reservoir now that is super kool. i have seen a ton of busted ones. _________________ "asking and getting are two different things" |
74volksrodwv Samba Member
Joined: September 02, 2014 Posts: 68 Location: Nitro, WV
Posted: Thu Feb 09, 2017 12:50 pm Post subject: Re: What parts are '68 only? |
dillon70 wrote: |
Mine is a 9/68 bay and it seems to have a little bit of both gauge sets posted above.
mine is 5/20/68 and its got a little of both too just the opposite
_________________ 1960 euro beetle
1964 beetle (for sale)
1970 beetle (sold)
1973 beetle(deceased)
1967 13 window deluxe
1968 deluxe bus
1973 bus(sold)
1978 westfalia(deceased)
1979 deluxe westfalia(sold) |
kkrol Samba Member
Joined: June 13, 2008 Posts: 80 Location: Lorain, Ohio
Posted: Mon Feb 20, 2017 8:57 am Post subject: |
Basilbomb wrote: |
thanks, but only need one. i even have an over-priced mint '69 bay clock i would swap for one!
if you think the locks are hard to find, what about the escutcheon plate around it - the trim that mounts on the outside of the door around the key plunger.
i've never seen one and have no idea what they even look like! |
I have 68 single cab. The locks for the treasure chest look to be identical to the 26L 086 locks. It looks like the PO tried to drill out the lock mechanism and it theycan only be opened with a screw driver. Is there any way these mechanisms can be repaired or replaced so they can be opened with a key? |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2295 Location: Millwood, Wa
Posted: Mon Feb 20, 2017 10:04 am Post subject: Re: What parts are '68 only? |
Has chrome '68 emblems been discussed? I think sometime after '68 they went stainless. Here is a nice '68 chrome emblem, on an original patina'd Bus, I assume original to this Bus.
_________________ ---
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
woofer Samba Member
Joined: September 18, 2008 Posts: 107 Location: England
Posted: Sun Apr 02, 2017 2:35 pm Post subject: |
busdaddy wrote: |
Long-roofs wrote: |
srfndoc wrote: |
Are the drums on a 68 one year only? Someone said this and I hadn't heard that before. That could be a real issue as those need to be replaced on a semi-regular basis (mine are good right now). Also, anyone have a photo of the side plate of a 68 transmission with the acorn nuts. Just curious if mine is the original. |
Yes, '68 rear drums are part number 211.501.615F.... G would be '69-'70 |
So that would make the backing plates different too? |
Posting as I read through thread just looked at my drums on my newly purchased Jan 68 single cab got the F part number in them and single lip backing plates _________________
Lionhart94010 wrote: |
IMO life is too short for some restorations… |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Thu Apr 06, 2017 4:48 am Post subject: Re: What parts are '68 only? |
I might have found another oddity, the CV joints have a cap on the inner side of the joint & the joint has a relief machined into it to accommodate the cap.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
richparker Samba Member
Joined: November 24, 2011 Posts: 6985 Location: Durango, CO
woofer Samba Member
Posted: Thu Apr 06, 2017 3:36 pm Post subject: Re: What parts are '68 only? |
i haven't pulled my drive shafts and cv joints out yet but somehow in my mind they look a little smaller than my 71? am i just mistaken? _________________
woofer Samba Member
Posted: Thu Apr 06, 2017 3:38 pm Post subject: Re: What parts are '68 only? |
looking at another thread looks like they were a 68 only part to stop dilution of the cv joint grease if the seal in the gearbox went _________________
airschooled Air-Schooled
Posted: Thu Apr 06, 2017 9:01 pm Post subject: Re: What parts are '68 only? |
I have heard of the caps on early '69 buses as well.
Interesting thought on the output seal theory. I would like to know who else had them just on the inner joint.
www.airschooled.com |
Posted: Thu Apr 06, 2017 11:44 pm Post subject: Re: What parts are '68 only? |
They were on both ends of my axle. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Tcash Samba Member
Posted: Sat Sep 02, 2017 2:10 pm Post subject: 1968 Aftermarket Brake Fluid Fill Reservoir Installation |
Trashman wrote: |
Long needed fix went down today. A lot of you guys know, especially you 68 owners, that the upper brake fluid reservoir on a 68 is a one year only part. And if you know that, you might also know that this part isn't reproduced, until just recently. Cip1 sells a replacement 68 only brake fluid reservoir and I finally ordered one this past week and got it on today. Here are some pics of my old one compared to the new one. As you can see, my old one is all cracked and has a huge hole in it. Safe to say it wasn't holding any fluid and there isn't any amount of jb weld that could have change that.
The new one looked great upon initial inspection, but when I went to go switch the old one out for it it wouldn't fit over the metal tube. I noticed that the opening wasn't round like the original, so I did a little bit of trimming to fix that and it slid right on and the old threads on the locking collar matched up with the new ones on the reservoir no problem. Happy camper with this one! |
rustfree1967bug Samba Member
Joined: November 16, 2006 Posts: 3436 Location: minnesota
Posted: Sat Jan 27, 2018 12:26 pm Post subject: Re: What parts are '68 only? FAQ |
Anyone have a clue as to what m code 091 is? Just picked this '68 deluxe up.
_________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
IDA's...well... they talk dirty -MURZI |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Sat Jan 27, 2018 12:51 pm Post subject: Re: What parts are '68 only? FAQ |
10 5
508
525
21
425
091
095
119
UT
2211
522807
8156924
Uncode my M-Plate
Forum signature link to my M-Plate
M-Plate content
Model Type 2 (T2) mod. 221(1) :
- Microbus
- 7 seater (arrangement 2-2-3)
- Sliding door right
- LHD
Chassis number 228156924
Serial number 156 924
Modelyear 1968
Planned production date May 10 ,1968
Type of engine Type 1 (B5) - 1584cc, 35 kW (47 bhp DIN)
Type of transmission Manual 4-speed gearbox
Paint color 522807 - Unknown special color
Interior color (doorpanels and seats) 522807 - Unknown special color
Destination Picked up by first owner at the factory in Germany, meant for US-market
M-CODES
M-CODE Description Concerned models From chassis number To chassis number
095 Car radio model "Wolfsburg" (MW, LW and tapedeck connection) -
119 Eberspacher BN4 petrol heater whith outlet in load/passenger compartment 211-244
2x2 2 300 000
119 Eberspacher BN4 petrol heater whith air recirculation connection and outlet in load/passenger compartment 211-244
271-274
2x3 2 000 001 2x3 2 300 000
119 Eberspacher BN4 petrol heater 211-238, RHD
2x4 2 000 001 2x9 2 300 000
425 Collection of M-Codes: M 020/089/507/511/524 (1968-1969) - 2x8 000 001 2x9 300 000
020 Speedometer and odometer in Miles 211-274
089 Laminated windscreen (1969-1979) - 2x9 000 001 2x9 2 300 000
507 Vent wings in cab doors 211-235
261-274
511 Padded instrument panel (LHD only) 211-271
524 Sealed beam headlamps, dual circuit brake control, back-up light and side marker reflectors (LHD) without emergency light system 211, USA, Canada
241, USA, Canada
265, USA, Canada
2x9 000 001 2x9 999 999
524 Sealed beam headlamps, dual circuit brake control, back-up light and side marker reflectors (LHD) with buzzer for ignition-starter switch 211, USA, Canada
241, USA, Canada
265, USA, Canada
2x0 2 000 001 2x2 2 000 000
524 Sealed beam headlamps, dual circuit brake control, back-up light and side marker reflectors (LHD) 211, USA, Canada
241, USA, Canada
265, USA, Canada
2x2 2 000 001
508 With vent wing in passenger compartment opposite sliding door 221-244
2x1 2 300 000
508 With vent wing in sliding door and in all windows in the opposite side panel 221-244
2x2 2 000 001 2x7 2 300 000
508 Sliding window in the side panel opposite the sliding door 271
274
2x2 2 000 001
508 With vent wing in the Double Cab door and in the opposite side panel 265-268
2x2 2 000 001
525 Three-point safety belts front, left and right and lap belts in passenger compartment 211-265, USA, Canada
UNKNOWNS M-CODES
091 _________________ nothing |
Posted: Sat Jan 27, 2018 1:32 pm Post subject: Re: What parts are '68 only? FAQ |
Thanks! Anyone have any clues on 091 or seen it before? _________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
roland Samba Member
Posted: Sun Jan 28, 2018 2:04 pm Post subject: Re: What parts are '68 only? FAQ |
091 is listed as “whitewall tires” in the split bus m-code listing. Could very well be the same as the radio code, the 425 and a bunch of other ones are unchanged between split busses and bays... _________________ Also, vanagons! |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Sun Jan 28, 2018 2:36 pm Post subject: Re: What parts are '68 only? FAQ |
Good call on the whitewalls. I wonder if the tires on it now are OG. It makes sense that a couple of split codes could have held over on the transition year.
If not whitewalls, maybe it is a fat fingered M092 - Lower rear end gearing for mountain driving? |
roland Samba Member
Posted: Mon Jan 29, 2018 1:18 pm Post subject: Re: What parts are '68 only? FAQ |
easy way to find that out is to get under the bus and have a look at the gearbox code. But i doubt it, don't see VW making many mistakes in their M-plate codes.. _________________ Also, vanagons! |
Posted: Mon Jan 29, 2018 4:42 pm Post subject: Re: What parts are '68 only? FAQ |
I would think that too, but there are a couple VIN mistakes on the forum. |
