Dash lights don't come on..........Anyone?
Johnagon
Johnagon is offline
PostPosted: Fri Jul 18, 2008 1:37 pm    Post subject: Dash lights don't come on..........Anyone? Reply with quote
Hey folks, I got into my van the other evening and noticed that when I put the lights on that the dash(instrument) lights didn't come on. Along with that the ciggy light didn't come on either. I figure they are on the same line. The lighter did work and I did check the dimmer position/adjustment. The fuses check to be good by eye. The lights worked fine and I did not notice anything else wrong.
Before I start pulling out the dash..........I was just wondering if there is somewhere I should look first. Like , this may be one of those known v-dub electrical problems ?
Thanks, John
'85 Westfalia
'95 Sonoma pick-up
tosu
tosu is offline
PostPosted: Fri Jul 18, 2008 1:52 pm    Post subject: Reply with quote
When I first got sucked in to buying a westie, <g>
my dash lights didnt work, I picked up a switch at a wrecking yard that was the cure.
84 westfalia
sometimes towed behind our
67 MCI bus conversion.
PDXWesty
PDXWesty is offline
PostPosted: Fri Jul 18, 2008 1:56 pm    Post subject: Reply with quote
sounds like it's a fuse.
Franklinstower
Franklinstower is offline
PostPosted: Fri Jul 18, 2008 2:10 pm    Post subject: Reply with quote
Don't forget to make sure the dimmer switch is turned all the up.
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
PDXWesty
PDXWesty is offline
PostPosted: Fri Jul 18, 2008 2:17 pm    Post subject: Reply with quote
Check to make sure the fuses are in the correct slots. I mistakenly put one in an empty slot then wondered why my sh*t didn't work. The fuses were all good but one was in the wrong place.
RichBenn
RichBenn is offline
PostPosted: Fri Jul 18, 2008 11:11 pm    Post subject: Reply with quote
I've had two bad dimmer switches. The first was simply bypassed, so the dash was always on. The second only works when all the way up.(pretty much same as bypassed) Look into it if no fuses are blown.
Rich
berge13
berge13 is offline
PostPosted: Sat Jul 19, 2008 5:28 am    Post subject: Reply with quote
If those simple fixes don't work, it may be that a connector has come loose in the cluster. I wouldn't think you would have to remove the whole dash, just the cluster shroud.
"If someone believes in you, well that is just the greatest thing in life..."
Berge;1972
85 WBX GL
Prior:
59 Ragtop
66 Barndoor
71 TinTop Westy
69 Karmann Ghia
62 Bus
83.5 Vanagon
foodeater
foodeater is offline
PostPosted: Sat Jul 19, 2008 7:30 am    Post subject: Reply with quote
You may want to check the blue foil. the jackass PO of my van did some shoddy electrical work on my van and burned out the part of the foil that goes to the dash lights. I'm going to fix this when I take the dash out to fix the front heater motor. It was a long cold winter in my vanagon, since the aforementioned jackassPO also bypassed the rear heater
89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
Johnagon
Johnagon is offline
PostPosted: Sat Jul 19, 2008 12:05 pm    Post subject: Reply with quote
I just checked the fuses. It's funny, I had a BLADE fuse blown. Put a new one in and moved the dimmer dial around and POP ! It blew again ! I swapped in a spare switch(presumably good) and proceeded to blow another fuse after moving the dimmer. I figure I'm now looking for a chaffed wire now. But which one??? Beautiful !
'85 Westfalia
'95 Sonoma pick-up
pete000
pete000 is offline
PostPosted: Sat Jul 19, 2008 11:33 pm    Post subject: Reply with quote
I would start with the blue ribbon. Then move to the light switch. Sounds like your in for some fun...
My dash lights fried tonight when I put in junk aftermarket LED bulbs...
1990 Vanagon RS 2.1
1967 Deluxe 21 window
Koni Shocks
H & R Red Springs
Addco Sway Bars Front-Rear
18 X 7.5 and 18 X 8 OEM Porsche Wheels
Recaro Power-Heated seats
