shortening clutch cable?
90volts
90volts is offline
PostPosted: Sun Jul 20, 2008 5:22 pm    Post subject: shortening clutch cable? Reply with quote
i have seen this a few places. how exactly is it supposed to work?
i took mine out today. this is how mine was done previously.
looks like it was a cable thsat was cut in two, some cable cut out, straight cut end from the cluster through this clamp along with the end portion, side by side, tightened down and then the threaded end goes as normal.
hoping to get it done by saturday for a show, so any help would be appreciated. thanks.
joescoolcustoms
joescoolcustoms is offline
PostPosted: Sun Jul 20, 2008 5:45 pm    Post subject: Reply with quote
I have done a bunch almost like yours, except I use three of these same clamps. Two facing one direction and the third in the middle facing the other direction. I have run them against a Kennedy stage two PP and no stretching/slipping. This way you can still use the stock wing nut.
UnKlear Racing TAT 2020
Bad News Racing 2018 NORRA 1000 3rd in class, 120/270 overall
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
90volts
90volts is offline
PostPosted: Sun Jul 20, 2008 5:58 pm    Post subject: Reply with quote
what type of clamp is it exactly then? maybe i'll just do that. its been working for as long as i've had it (5-6 years) with no issues and it was easy to remove. thanks
BL3Manx
BL3Manx is offline
PostPosted: Sun Jul 20, 2008 6:03 pm    Post subject: Reply with quote
In the picture you posted of the cable ends, the top one is for the clutch cable. A nut(which isn't shown) is threaded on the thick flat section, past the eye, almost to the point where it changes diameter The cable with the original threaded section cut off, is threaded though the eye in the flat section then bent double, away from the nut. The nut is tightened back against the bent over section of cable.
It will work for a year or so then the cable will snap. You need to learn how to double clutch to get home.
The best solution is to get a cable shortened by these guys.
http://www.push-pull.com/index.html
joescoolcustoms
PostPosted: Sun Jul 20, 2008 6:11 pm    Post subject: Reply with quote
90volts
The one in your picture is just a standard cable clamp. I purchase them at either my local hardware or at Lowes. Because or rust issues, I try to get either stainless ($) or galvanized. The later ones cost about $ 1.89 each on my last buggy build this spring.
aquamanx
aquamanx is offline
PostPosted: Sun Jul 20, 2008 6:26 pm    Post subject: Reply with quote
I had trouble with the cable slipping out of the clamp when done like yours. If you have enough cable, loop each end together and clamp the loops never had any problems that way.
Kinda hard to see but this is the only pic I have.
Longbody build http://www.thesamba.com/vw/forum/viewtopic.php?t=266189&postdays=0&postorder=asc&start=0
04 aqua buggy - sold
72 orange buggy - sold
72 green longbody buggy - aka Shrek
68 Manx future project
ManxBug
ManxBug is offline
PostPosted: Sun Jul 20, 2008 7:54 pm    Post subject: Reply with quote
That's how mine was done too. But I have one of those Empi kits for backup if it ever breaks.
Air Riders, VW Club
90volts
90volts is offline
PostPosted: Mon Jul 21, 2008 4:55 pm    Post subject: Reply with quote
yeah...not just an adjustment! Shocked there was my scratching noise.
vdubyah73
vdubyah73 is offline
PostPosted: Mon Jul 21, 2008 5:25 pm    Post subject: Reply with quote
Thats how I did mine in 2003 no problems to this day ............knock on wood!
burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34'
kustoms
kustoms is offline
PostPosted: Mon Jul 21, 2008 6:06 pm    Post subject: Reply with quote
Ya know, The next time you go for a drive it will fail.
Google this.
"Bread and Circuses"
And wondering what the heck happen to my Samba post count?!?
Tom Thompson
Tijuana Kustoms Inc. (TM)
1-516-338-8746
www.tjkustoms.com
GetPsycho
GetPsycho is offline
PostPosted: Mon Jul 21, 2008 8:32 pm    Post subject: Reply with quote
This is how I did mine.
SOME MORNINGS IT'S JUST NOT
WORTH CHEWING THROUGH THE
LEATHER STRAPS!!
madmike
madmike is offline
PostPosted: Tue Jul 22, 2008 4:50 am    Post subject: Reply with quote
Stock length cable, Loop it, install 2 cable clamps, Done,no cutting needed,Madmike
65 Baja
68 VolksRod Coupe(sold)
Porsche/Laser 917(sold)
'Black Ice'Drag Buggy 1915 'Turbo'
Mid-Engine Dragster 2332 w/IDA's(gone)
'White Out' 76 Drag bug 1915 or 2276 'Turbo'
70 MicroBus 2110 w/40 IDF's
I build my own Motor's & transmission's
vdubyah73
PostPosted: Tue Jul 22, 2008 5:14 am    Post subject: Reply with quote
That is why I thumped myself in the head after typing that. You know I can be a knothead at times.
90volts
90volts is offline
PostPosted: Tue Jul 22, 2008 5:18 pm    Post subject: Reply with quote
this bend int he clutch cable normal? haven't been able to get the threaded end through it. the story is, all tubes are cut in the tunnel. dropped the shift rod to get back there. threaded end comes out of the front half tube, i align it into the rear portion. threaded part goes fully in then stops. i have no leverage to really shove it. i think it is getting stuck at this bend.
cut the bad cab;e to get it out. PO may not have been able either, the cable was cut then clamped to the threaded end remember? the cab;e will go through no problem without thread. also tried threaded end from rear to front and got stuck as well. i wanted to get a properly sized cable but if its not going through its a waste of cash.
vdubyah73
PostPosted: Tue Jul 22, 2008 7:37 pm    Post subject: Reply with quote
Just cut it and clamp it fer crying out loud. The clamps pictured are the same type used to hold cables as thick as your leg together. These clamps are used on tow truck cables, roll off container truck winches, cranes, tug boat cables and prolly aircraft carrier arresting gear cables. You guys think to much.
MURZI
MURZI is offline
PostPosted: Tue Jul 22, 2008 7:59 pm    Post subject: Reply with quote
Yeah...but this looks waaaay cooler. Laughing Laughing Laughing
Cool, slick, bitchen, all dat
62 vert
2276
Timís welded heads
45 Dells
A1 sidewinder
Fk44 cam
calebmelvin
calebmelvin is offline
PostPosted: Tue Jul 22, 2008 10:16 pm    Post subject: Reply with quote
I had the same problem trying to feed the cable through the tube on mine, I ended up cutting an clamping as others did just to stay sane. Give it a snip, double loop it for insurance...
Caleb
'66 Manx | My Wanted Ads
90volts
90volts is offline
PostPosted: Tue Jul 22, 2008 11:40 pm    Post subject: Reply with quote
figured i would try to thread it through. oh well, snip it is then. thanks all.
Oil_Eater
Oil_Eater is offline
PostPosted: Wed Jul 23, 2008 6:43 am    Post subject: Reply with quote
+1 here. This absolutely won't work if you go with a higher performance clutch/pressure plate set-up.
One clamp worked OK for my 1300 6V. When I switched to a 1600 12V pressure plate and clutch, one clamp slipped. I added another two clamps, just to be sure I didn't get stranded.
Finally, when I went to the Subaru engine with the stage II KEP pressure plate and clutch, I went with a custom shortened cable.
Hope this helps,
Jay
nightmanx11
nightmanx11 is offline
PostPosted: Wed Jul 23, 2008 7:22 am    Post subject: Reply with quote
I gave up completely and went the hydraulic clutch setup. No problems since
