Chassis Sandblasting Questions
u118224
u118224 is offline
PostPosted: Tue Jul 22, 2008 6:44 am    Post subject: Chassis Sandblasting Questions Reply with quote
I have a 1973 Standard Beetle. I am disassembling it in order to restore it. I do not particularly want to remove the rear suspension plates and torsion bars. Can these remain on the chassis when sandblasting, without any adverse effects?
69 Jim
69 Jim is offline
PostPosted: Tue Jul 22, 2008 9:12 am    Post subject: Reply with quote
I wouldn't suggest it, sand gets everywhere. The pan needs to be completly disassembled. I had to run the water hose through the tunnel for quite a while to remove all the residue on the last one I did. If you are doing a restoration, the rubber bushings should be replaced anyway.
It is not really that hard to do and the finished product will handle much better. If you read up on how to do it, just remember when you unload the springplates, take a picture of the position where they are hanging. This takes all the guess work out of the reassembly and makes the job much easier. Good luck.
pbenn
pbenn is offline
PostPosted: Tue Jul 22, 2008 3:30 pm    Post subject: Reply with quote
Yes. Sand will also get in the torsion tube and the tunnel and the front floor cross channel.
I actually hung mine vertically and used gravity for a 50/50 kerosene/water wash, with the big rear tranny mounts unscrewed for the drain. It was too much work and didn't get the cross channels.
If I ever did it again I'd use a shop-vac for about a day first, before trying the wash method. If you do unscrew the rear tranny mounts you're going to have to clean the fine threads carefully inside the rear horns.
tobyte1
tobyte1 is offline
PostPosted: Tue Jul 22, 2008 4:36 pm    Post subject: Reply with quote
Check into soda-blasting. It is a lot less invasive than sand. I have had great results. Around here, a guy will come to your place and blast a whole car for $500-800 depending on the car and how bad it is.
u118224
u118224 is offline
PostPosted: Wed Jul 23, 2008 6:14 am    Post subject: Reply with quote
Thanks for the replies, I appreciate it! For those of you who did sand or soda blast the chassis, did you remove the diagonal suspension arms?
Also, how did you address the chassis to body sealing strip that runs around the perimeter of the chassis? I presume it must be removed, but does anyone sell a suitable replacement for it?
Thanks again for your help.
69 Jim
69 Jim is offline
PostPosted: Wed Jul 23, 2008 9:22 am    Post subject: Reply with quote
Try here for the body seal: http://www.wolfsburgwest.com/wwd.cfm
Depending on your budget, powder coating the pan comes out very nice. Looks factory clean.
clarkbre
clarkbre is offline
PostPosted: Wed Jul 23, 2008 9:52 am    Post subject: Re: Chassis Sandblasting Questions Reply with quote
In general, if you're taking it apart to get things blasted, take everything apart. I am in the process of restoring a '73 pan and had it blasted and then applied POR15 to it. Every part that bolted, clipped, or clamped to the pan was taken off in order to get the best coverage from the sandblaster and paint.
For me, it's a detail thing. Had I not taken the suspension apart or had left the front beam on, I would know in the end that there were areas that weren't freshened up because I was lazy. It will be a better quality restoration if you disassemble everything and start fresh with all new parts.
After blasting and paint, the first thing I did was replace the shift rod busing and worked my way out from there.
Also, I will disagree with 69Jim about powdercoating. Although it looks nice and is durable, I found that POR15 is a better product. It is much cheaper (1 quart will do 2 coats top and bottom of the pan), prohibits rust, dries just as hard as powder coating, if it ever does chip it is easy to touch up, and is resistant to battery acid. Either way you go, it will really help prolong the life of your pan.
volksbug70
volksbug70 is offline
PostPosted: Wed Mar 08, 2017 11:06 am    Post subject: Reply with quote
I'm going to be blasting my chassis soon and am considering the different media options. I've heard that soda isn't as abrasive as other options - how well did it handle rusty areas on the chassis?
~Dave (Brother of Matts70Bug)
1970 Beetle
Undergoing Full Restoration as of February 2017!
Steve22
Steve22 is offline
PostPosted: Wed Mar 08, 2017 11:25 am    Post subject: Reply with quote
technology has changed since 2008, check into dustless blasting.
'65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter
TX-73
TX-73 is offline
PostPosted: Wed Mar 08, 2017 1:56 pm    Post subject: Re: Chassis Sandblasting Questions Reply with quote
Agree, it's all in the details. even to removing bolts before you paint.
I wanted to add that I've used Rust Bullet with very good results. You can also reduce it slightly for better coverage and flow. I did a 73 F-150 chassis with it, great results. Eastwood sells a ceramic engine paint that is pretty durable as well. I used their dark Ford blue color for some of the chassis components for a little contrast. Lots of good materials out there. That chassis was blasted with Black Diamond grit from Tractor Supply.
My 1973 Standard Beetle Build SOLD
Click to view image
