Lanval Samba Member
Posted: Wed Jul 30, 2008 10:13 am Post subject: |
Wolfe,
I know I've seen at least one pic of a vanagon with an enclosed shower in it, but it was a high top. The shower was placed directly behind the driver's seat, and would thus probably work with the pop top.
I'm thinking that you could do it and leave the top of the shower open, or create a little mesh hat to put on when the top is up.
It would require moving the sink/stove setup, but there are enough options theres to make that doable.
The plus of having the shower in that location is you can drain through the grey-water hole to a tank installed underneath the westy. Move the stove and sink across the aisle to behind the passenger seat, ala Bay Window style, with your LP tank under the sliding door.
BTW, putting the LP tank under the driver's side sucks; doesn't bother me here in SoCal, but if I was in Oregon, and had to get out into the rain to turn on the gas, I'd be somewhat unhappy. Thus being able to turn on the LP from inside would be a nice move for some.
As for the shower itself, a plastic shower basin with a framework of PVC pipe holding plastic shower curtain liners would work, and be relatively low weight. If you want it fold-up/take-apart, that could be done fairly easily that way as well.
Best,
Lanval |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
Posted: Wed Jul 30, 2008 10:15 am Post subject: |
wolfej1 wrote: |
Good idea - however I am still faced with the dilemma of how to hang it inside without drilling into the poptop. |
Couldn't you hook it to the skylight opening, and adjust the length of the four ropes accordingly?
I think this is a very cool idea. _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
wolfej1 Samba Member
Joined: August 15, 2005 Posts: 679 Location: North Royalton, Ohio
Posted: Wed Jul 30, 2008 10:25 am Post subject: |
Lanval wrote: |
Wolfe,
Best,
Lanval |
I think the PVC pipe idea has some real merit I was not thinking in that way but it makes very good sense. Additionally - I am using the floor from an old one person shower stall - it is plastic and it fits perfectly in the van. I suppose I could fab up some junctions in that to install the pvc pipes and that would be it. No need to hang anything and it would be easier.
I never would have thought of that - as I was stuck on the hanging idea |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Wed Jul 30, 2008 10:33 am Post subject: |
What about a peice of conduit and a couple of these? http://www.anver.com/document/vacuum%20components/vacuum%20cups/cups-flat.htm You could stick them to the fiberglass luggage rack when needed. I understand not wanting to drill anyholes. I have been toying with the idea of a flat cover for my luggage rack to see if I get an improvement in road noise and mpg. If it works, I would consider installing dzus tabs to hold it in place. They require drilling holes in the fiberglass to work. _________________ ☮️ |
Posted: Fri Aug 01, 2008 10:19 am Post subject: |
wolfej1 wrote: |
Lanval wrote: |
Wolfe,
Best,
Lanval |
No need to install mounts in the floor - I drilled 4 holes in the floor unit that i just set the PVC pipes into. I cut the pipes into 3' sections and tie together with junction fittings, this way it is easier to store. Then I bought a dark shower curtin that I hook around the top rails. Stable and easily assemble/disassembled.
Since I have not finished the tank unit part yet and I have a trip planned this weekend I am going to use the 2 gallon sprayer method for the water supply. Just set the sprayer unit on the stove counter and hang the hose over the top of the shower rail. Tested it out and it is pretty good. Got a full shower in without having to pump the sprayer again and there was still half a tank left. Nothing got wet inside the van When everyone has had their shower I will just disassemble the unit, and put everything underneath the van til the next shower is needed. Setup time is about 5 minutes. Also, the shower curtain is used as the table cloth, just put it on the table and wipe it off.
Then for kicks I filled the sprayer, pumped it up good, and emptied the tank without having to pump again. Granted the pressure was not that great at the end, but it was still usable. For the sprayer I used one of those expensive units that are made of metal and are for applying deck stain and other chemicals.
Of course if we are in an isolated are there is no need for this setup
I will post some pics when I have a chance.
Regards,
Wolfe |
Lanval Samba Member
Posted: Sat Aug 02, 2008 11:14 am Post subject: |
"I love it when a plan comes together..."
Best,
Lanval |
Posted: Wed Aug 20, 2008 10:54 am Post subject: |
wolfej1 wrote: |
wolfej1 wrote: |
Lanval wrote: |
Wolfe,
Best,
Lanval |
UPDATE:
I reduced the weight and hassle with regards to the enclosure:
I built a 2.5'x2.5' frame from pvc pipe which i rest on the half opened upper bed and the roof area directly behind the latch for the pop top. Put the curtin rings on this and just let them hang down into a plastic mortar container that i bought from lowes (recommended from another user). This is better because it is easier to empty the water and the components store easier as there is no big floor unit and less pvc pipes. Also much lighter and easier to setup and dismantle. The only downside is that the enclosure is not as high as the old one and there is a bit less elbow room inside. However the benefits outweigh the negatives IMHO. |
tsombrero1 Samba Member
Joined: June 13, 2006 Posts: 288 Location: Seattle, WA
Posted: Wed Aug 20, 2008 11:59 am Post subject: |
Hey, I did this too! Works great. I used a "Dirty Dog" collapsable tub to stand in-- it smooshes down flat when you're not using it. I don't remember where I bought it but they seem to be available online:
_________________ Tennessee Sombrero
1988 Westy, Syncro-nated
2003 Aprilia Caponord (now with Jif)
Atari 2600
1970 Earthbound Humanoid |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3101 Location: ABQ NM USA.... Except when not
Typhon2222 Samba Member
Joined: October 24, 2009 Posts: 363 Location: Berkeley, CA --> Berlin, Germany
Posted: Thu Jul 14, 2011 11:59 pm Post subject: |
tsombrero1 wrote: |
Hey, that "Dirty Dog" collapsible tub is a great idea for showering in! I was thinking I'd have to use a mortar tray or something like that, but this seems lots easier, and the dimensions are perfect for inside the van.
Question for ya: if you've just taken a shower and you've got 2 gallons of runoff water sitting in this thing, can you easily move it outside the car to empty it? I read it has carrying handles, but am wondering how strong they are.
Thanks lots. _________________ Basil — '88 Dove Blue Westy. |
taigagreen Samba Member
grandpa pete Samba Member
jimf909 Samba Member
Posted: Thu Jun 02, 2016 8:03 am Post subject: Re: Hot Water Idea |
I recently got a Boss Water Heater. I'm super-pleased with the design, quality and output of the product. After providing a bucket of water, all it takes is the push of a button to get near-instant hot water. Cleaning up after a day on the trail has never been so easy or comfortable. Plus, getting adequate solar to heat water in the PNW is not a reasonable expectation 300 days a year.
Highly recommended...
http://www.amazon.com/Mr-Heater-BOSS-XCW20-Basecamp-Operated/dp/B011TRLWIG _________________ - Jim
Abscate wrote: |
Old_Ben_Gun Samba Member
Joined: December 18, 2012 Posts: 30 Location: Spanaway Washington
Posted: Sun Jul 03, 2016 3:28 pm Post subject: Re: Hot Water Idea |
Im surprised that 2014 saw the last post on this topic. Im a Vanagon fan and after living aboard sailboats for six years It's amazing no one is or has adapted their technology to the Van. Camping world offers a portable, small light weight propaned fired instant on water heater. At present Im imagineering the instalation into the back side of the aft cupboard. With the aft hatch lifted the heater can be fired up. A propane suply can come from either a portable bottle or plumbed from the old fridge/stove bottle. Water wan come from either the 7 gallon enclosed tank of from a 5 gallon external jug via a boat system demand style water pump. Im just getting the corage together to cut into the closet and free up same space. A permanent mount instant on system can be done for under $500. Shower compartment is a portable Tent like structure from Bass Pro Shop. Oh and a suction cup towel rack on the aft window. If anyone wants pictures please message me on FaceBook Douglas Young Tacoma Wa or E mail at [email protected] |
Posted: Sun Jul 03, 2016 11:02 pm Post subject: Re: Hot Water Idea |
Old_Ben_Gun wrote: |
There are several threads on what you describe. As for me, I prefer (love!) the Boss XCW-20. It's simple and mobile. I often don't want my shower near the van and I don't want to lose the interior storage space (I carry the heater in a roof top box).
Page 2...
http://www.thesamba.com/vw/forum/viewtopic.php?t=422965&postdays=0&postorder=asc&start=0
A better thread...
http://www.thesamba.com/vw/forum/viewtopic.php?p=8038516 _________________ - Jim
Abscate wrote: |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Mon Jul 04, 2016 6:08 am Post subject: Re: Hot Water Idea |
grandpa pete wrote: |
If you have concerns about bacteria in your water supply there is a baby bottle disinfectant . |
Get some clean new pennies and throw them in your water tank. They could even be dirty pennies, but ones you cleaned seems much better idea.
The water pipes in a house are copper. Cooper pipes will kill 99% of the bacteria in the water in roughly 2 hours of the water sitting in the pipe.
https://en.wikipedia.org/wiki/Antimicrobial_properties_of_copper |
Posted: Mon Jul 04, 2016 6:19 am Post subject: Re: Hot Water Idea |
Californio Samba Member
Posted: Mon Jul 04, 2016 4:12 pm Post subject: Re: Hot Water Idea |
Seems like you could wrap some soft copper tubing around your coolant pipes, plumb to a pump and reservoir, and have plenty hot water, at least as long as you're driving. |
Posted: Mon Jul 04, 2016 9:20 pm Post subject: Re: Hot Water Idea |
Californio wrote: |
Along these lines you could get a small marine heat exchanger and run your coolant through one side and pump the house water through the other side. You would definitely have water the same temp as the engine coolant so you would have to regulate the flow for temperature control otherwise your going to get some burns.
For the sake of easy installation you could put the heat exchanger under the bench seat where the rear heater is since you have the holes in the body for the heater. Next you'd need a another water tank for cold water!
"Sen-dure" is one company in Fort Lauderdale that has been making small heat exchangers for years. |
