Trevor P Samba Member
Joined: January 21, 2004 Posts: 863 Location: Saskatoon, SK, Canada
Posted: Thu Jul 24, 2008 11:48 am Post subject: Hood hinges and struts |
Anyone using the small gas strut on their oval hoods? I was planning on using the later hinges and replacing the springs with the struts however the later hinges interfere with the front quarters when closed. I'm assuming this is due to width differences between the oval cowls and the later cars. I was thinking about modding the original hinges with a reccess/pivot to accomadate struts.
Anyone have another trick on making these work? _________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
mallred Samba Member
Joined: November 01, 2006 Posts: 266 Location: Spring Creek, Nevada
Posted: Fri Jul 25, 2008 8:20 pm Post subject: |
I did that modification on my "57.
Used the later hinges and gas struts.
I just had to weld a tab on for the lower strut mount.
I had no front quarter clearance problem.
_________________ Mark Allred
'64 Resto Custom Bug - Daily Driver
'57 Sunroof Bug - Endless Project
Living beneath the Sagebrush Canopy |
Bruce Samba Member
Posted: Fri Jul 25, 2008 8:26 pm Post subject: |
If possible, you should install your gas spring with the rod down. That keeps the seal from drying out and leaking the gas. _________________
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sat Nov 19, 2011 7:12 pm Post subject: |
I don't have a clue, RareAir, and I don't remember who I bought them from, but they look identical to these.
http://www.jbugs.com/store/merchant.mvc?Store_Code...2d39353432 _________________ Mark Allred
