Stupid exhaust hardware question
vanagonforever
vanagonforever is offline
PostPosted: Sun Jul 27, 2008 6:10 am    Post subject: Stupid exhaust hardware question Reply with quote
I'm replacing my full exhaust system today on my 83.5 1.9L WBX. Yesterday I removed the old rusty bits and today I'm putting in the van-cafe kit. The problem is that I've got a lot of hardware, no instructions, and I'm concerned that I'll choose poorly when I'm bolting all this stuff back together. I was hoping that the number of the different nuts and bolts would give things away but I'm failing to see the pattern. So...
1) Where do I need to use the locking nuts?
2) Where do I need to use the wavy washers?
3) Where do I use the long bolts?
4) Where do I use the studs?
Finally, is there a trick to removing my old O2 sensor. I've just about stripped the nut trying to get that thing out. If not is that something that my FLAPS might actually have in stock? I typically do the mail order thing but I'd hate to keep the van dry docked for another week while I wait for a simple sensor.
Thanks so much for helping a n00b out!
1986 2WD 2.1L WBX Vanagon Weekender
1983.5 1.9L WBX Vanagon Westfalia
Dant
Dant is offline
PostPosted: Sun Jul 27, 2008 6:32 am    Post subject: Reply with quote
If you can get to a dealer or find someone with ETKA, an illustration can be printed. It shows all the pieces parts exploded view.
I just did a print screen of it and pasted it into paint...can I attach files using the Samba's "PMAIL"?
If someone can tell me a good way to get this llustration out of ETKA and into SAMBA we could help this guy out.....
90 Carat
97 Jetta GLX
87 GL (nobody wanted it)
91 Syncro (Stripped,Plain Jane,fixed vent windows,no tach) also rusty. Hurray for me!
vanagonforever
PostPosted: Sun Jul 27, 2008 6:39 am    Post subject: Reply with quote
Hey thanks so much for doing that. I sent you a pm with my email address if that helps at all.
tencentlife
tencentlife is offline
PostPosted: Sun Jul 27, 2008 8:53 am    Post subject: Reply with quote
Easy enough to call the vendor and have them run you thru the intended use of the hardware they supply. VC is very helpful on customer service, in my experience. I know it's Sunday, but if you haven't figured it out by tonight, give them a call in the AM.
Shop for unique Vanagon accessories at the Vanistan shop:
Experience is kryptonite to doctrine.
sagebus
sagebus is offline
PostPosted: Sun Jul 27, 2008 10:17 am    Post subject: Reply with quote
Go to the website, www.van-cafe.com , click on the exhaust for your year van and then the hardware kit. It tells you which bolts and nuts to use where. I used this for my new exhaust install, it is all good now and sounds great. Good luck ! Oh, on the OXY sensor I got one from Auto Zone $18.95 .
1984 Vanagon GL, Wolfsburg Westy 1.9 ltr
tencentlife
PostPosted: Sun Jul 27, 2008 11:11 am    Post subject: Reply with quote
Good to know!
Jamos
Jamos is offline
PostPosted: Sun Jul 27, 2008 12:34 pm    Post subject: Reply with quote
Yeah, I was going to say, on the van-cafe website under each piece of hardware, they do a pretty job explaining what each bit should be used for.
http://www.van-cafe.com/vanagon_parts.jsp?ct=11540435&pa=pct&pct=249315255
that should help you separate all your pieces out.
On the sensor, I'd recommend buying one of those small, cheap propane torches and heating up the oxy base. It should come out then if you haven't stripped out the corners too much.
'86 Wolfy Westy Weekender
2020 Audi Q5
OilNBolts
OilNBolts is offline
PostPosted: Sun Jul 27, 2008 6:11 pm    Post subject: Reply with quote
Try to use a six-point tool on the o2 sensor. A twelve point will round too easily. Autozone should also have the appropriate oxygen sensor socket; if not, NAPA will. And, as Jamos suggested, add heat.
Current fleet: Vanagons, two '88 GLs and an 89 Bluestar. Beetles, '63, '64, '72 convertible. Plus, four Subarus and three Prius. Too many cars.
vanagonforever
PostPosted: Mon Jul 28, 2008 6:51 am    Post subject: Reply with quote
Thanks for the tips on the O2 sensor. I ended up getting a new Bosche universal sensor for $17.95 at the local Autozone. Also that tip on the descriptions from van-cafe was even more helpful than the diagram turned out to be.
Sadly though my exhaust project is still incomplete. Thanks to several rain delays throughout the day I ended up not getting everything back together until well after dark. At that point I cranked the engine and... sigh... listened to the rhythmic chugging of a leaking exhaust. I pin-pointed the source of the leak with my hand and quickly realized how silly I was to bolt the curved piece to the manifolds last (even after I got the muffler strap on). I should have realized that all that struggling I was doing to get the bolts through would result in a less than ideal connection but hey, live and learn. So some time this week I'll have to disconnect the muffler strap and get a better fit to the manifolds.
