BellePlaine Samba Member
Posted: Mon Apr 27, 2015 7:32 pm Post subject: Re: Calibrating VDO 80psi 2 Post Oil Pressure Sender |
Tcash wrote: |
How did you calibrate it? If you don't mind me asking?
Thanks You
Tcash |
Not at all. I got the idea from a thread on the Split forum. Pry0man took one apart and showed how he calibrated the sender.
http://www.thesamba.com/vw/forum/viewtopic.php?t=449841&highlight=vdo+sender
I was going to hire him to calibrate mine when I discovered I had a co-worker who's husband works for Simco Electronics where they can calibrate these kind of things. I sent him a stock oil pressure sender, the VDO gauge, and the dual pole sender (which I had already dremeled the cover off). There was a problem with the sender's original spring as it would read inconsistent/variable pressures so he replaced that spring and had it calibrated and the idiot light switch adjusted.
I haven't yet tried it out of course but the idea is avoid the problem of a flickering oil light of a hot engine at idle or T in the stock sender.
Eskimotom wrote: |
Hey Chris & Kerrianne, Eskimo Tom checking in... |
Hey Tom! Good chatting with you tonight. Let's get together sometime. _________________ '75 Riviera
Whether you are a novice or know your way around an ACVW, a day with Amskeptic is money well spent. My mechanical ability/knowledge/bus is always better after Colin visits.
http://www.thesamba.com/vw/forum/memberlist.php |
Tcash Samba Member
Posted: Mon Apr 27, 2015 3:17 pm Post subject: Calibrating VDO 80psi 2 Post Oil Pressure Sender |
BellePlaine wrote: |
One more thing; I had a dual pole VDO oil pressure sender calibrated and the idiot light switch modified to go off at 4 psi, which is closer to stock then as it was.
Unfortunately, I don't have a photo if it mounted to the engine but here's photo of the guts.
I opened the cover carefully with a dremel cutting wheel.
Thanks You
Tcash |
Eskimotom Samba Member
Joined: May 18, 2007 Posts: 40 Location: Lake Wobegon MN
Posted: Mon Apr 27, 2015 1:29 pm Post subject: |
Hey Chris & Kerrianne, Eskimo Tom checking in, I bring home my 71 Sportmobile home tomorrow AM from the Cities.
It has the same style pop top but without the cap over the cab.
Give me a call, I'm a bay window owner once again. I miss my 76 which went to someone in South Dakota about 7 years ago. |
Posted: Mon Apr 27, 2015 6:04 am Post subject: |
I can't speak for others but I find that putting the bus away for the winter help re-engergize my motivation for projects. If I had to drive this thing year-round, I'd probably hate it.
Also, I hire Amskeptic each year to help me with my projects; lately I've viewed his visit as deadline of which to have my projects completed by. That way I can use him as a double-check/fine tune. A day with Colin is like a day at VW school. When the professor comes around, I want to have my term project ready to present. _________________ '75 Riviera
Marya Samba Member
Joined: August 31, 2004 Posts: 353 Location: Portland, OR
Posted: Mon Apr 27, 2015 1:35 am Post subject: |
You are amazing, for so many reasons. I'm so, so impressed. So are you an engineer or what?! And where you get the energy, focus, drive... I just can't imagine. You make me feel like the laziest, stupidest (!) waste of a human being!!! Type Z, that's me! _________________ 1970, Riviera, 1600 cc type I [single port] |
Posted: Sun Apr 26, 2015 8:33 pm Post subject: |
It's been years since I've updated this thread so here's the latest.
Last summer, on a camping trip a few hundred miles from home in Northern Wisconsin, the cam shaft got sloppy with the cam shaft gear causing us to finish our vacation in a rental car.
I was contemplating having an engine rebuilt or doing it myself when I found this engine for sale from aeromech.
It's a used engine with unknown hours and sat for years in a shop. It had been rebuilt at some point but not by aeromech. Anyway, the compression and flywheel endplay was great and I even saw a YouTube video of it running.
So as soon as we had some nice Minnesota weather, I dropped my old engine.
And cut a well for a new CHT sender ring and swapped the Progressive for stock fuel injection.
I took the pressure plate off and discovered that everything was a rusty mess.
This is a 215 set up and the disc from my old engine is a 210 so I don't really want to reuse it. I've sent the flywheel and pressure plate out to be glass-bead blasted and I just ordered a new disc. Question; once I get this flywheel/pp back, should I take it to a machine shop to have it checked for balance?
I'm also sitting on my thumbs thinking about what should be done, if anything, to these galley plugs since they are out in the open. JB Weld and move on, I guess.
Besides preparing this engine, I'm doing other projects. I've installed OP and OT gauges (already had the CHT gauge).
And I wired these aux gauge lights to the headlight switch via a Radio Shack resistor because I wanted to reduce the load on my original headlight switch.
Some more information about that project here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...p;start=20
While I was at it, I installed double 87 headlight relays and rewired the headlights from the starter to the lamps. I included a fog light circuit to use sometime in the future.
Another question; should I run 8 amp fuses on all wires: power from the starter to the relays, and power from the relays to the headlamps?
So there's the Spring 2015 update. The 002 5-rib transmission input shaft seal is leaking so I have to replace that. And then as soon as I get the flywheel situation sorted out I think that I'll be driving again soon. _________________ '75 Riviera
vdubman71 Samba Member
Posted: Thu Aug 26, 2010 8:13 am Post subject: |
I know this thread has been dead for about 4 months, but just wanted to say what a great job you have done on this bus. I'm a home brewer too and thought yout keg idea was awesome! Also the swivel seat! Thats one mod I want to do ASAP. Good work happy camping! |
Posted: Wed May 05, 2010 8:02 am Post subject: |
Thanks, but I can't take credit for the idea. If I was to do it again, I would not have cut out the base of the luggage rack but just the sides to the fit the tire. Holding it down with the footman loops would have probably worked just fine.
And hey, since I've dusted off this thread, let me show you what else I've been up to:
I cut out my passenger bulkhead and had a swivel seat base and the triangle gusset welded in. Over the winter I repadded a set of late Westy seats to install. Now I have a swivel seat and more importantly, extra seating room for my four-person family.
kampalm Samba Member
Posted: Tue May 04, 2010 10:25 pm Post subject: |
I have been wanting to get my spare off of the front of my bus and I really like how it turned out for you though I think I would go with cargo straps hooked to re-inforced footman loops. That is a great inovation! _________________ 74 Riviera, 1800 type IV, Weber Progressive (and proud of it), SVDA |
skid Samba Member
Joined: January 16, 2009 Posts: 1329 Location: Vancouver, BC
Posted: Tue May 04, 2010 1:21 pm Post subject: |
I really like that spare tire mod you did! _________________ '71 Westfalia |
chazz79 Samba Member
Posted: Tue May 04, 2010 12:44 pm Post subject: |
that looks good overall. I've been trying to come up with some place to put a spare for my riviera conversion. I don't want to hang anything off the nose of my bus. The shape of your cut out is probobly enough to keep the tire secure. I'd find a cargo net out of an suv in the bone yard and cut it down to fit your footman loops in the rack. _________________ One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster |
Posted: Tue May 04, 2010 9:30 am Post subject: |
barefootwestie wrote: |
Certainly a great looking install. My concern would be the weight of the tire on the roof in a central point, instead of spread out over a larger area...along with the JBWeld. But, it does look clean. |
Not because of any great engineering on my part, but by chance, the tire does not rest its weight on the mount. The entire weight of the tire is on borne by the luggage rack/roof. The mount just keeps the tire down. I had the same concern as you about denting my roof with weight of the tire which is kind of why I liked using the fuel line as a spacer/bushing.
Stuart wrote: |
i like it! how much did you pay originaly for the busses each? how much have you spent? |
If I post it here, my wife might find out! I will say that the Riviera I got for "free" as the previous owner wanted to see it go to a good home. Other then the body being fairly rust free, the Riviera wasn't worth much at the time though. The interior was completely shot with rodent damage and the engine had seized from sitting still for 22 years. _________________ '75 Riviera
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Tue May 04, 2010 9:10 am Post subject: |
Stuart _________________ Stuart Zickefoose
206-841-7324
[email protected] |
barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1551 Location: Johns Island, SC
Posted: Tue May 04, 2010 8:58 am Post subject: |
Certainly a great looking install. My concern would be the weight of the tire on the roof in a central point, instead of spread out over a larger area...along with the JBWeld. But, it does look clean. _________________ My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia |
Posted: Tue May 04, 2010 7:54 am Post subject: |
I think that I was more optimistic about JB Weld then realistic. In hindsight, I agree that there are better options. I kind of like your strap idea. In the meantime, the tire is fitted moderately tight in its home.
Thanks, but don't worry about the steering coupler. I finished that job up long ago. _________________ '75 Riviera
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51112 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue May 04, 2010 7:19 am Post subject: |
Well, here's another mod to check off of my list:
I like it!, but those JB welded mounts do nothing for me, you're entirely counting on how well the paint is stuck to the roof, could end badly. I'd run a couple of bungees over it for insurance myself, or a hinged metal strap with a safety pin or bolt on the loose end.
It's been a while since I did a steering coupler but i'd guess the spacer goes in the center, I'll try to have a look at one today. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue May 04, 2010 6:54 am Post subject: |
My wife hates it, my neighbor hates it, but I love it. I'll admit, cutting up my luggage rack took more chutzpah then I normally carry with me but I did it for two reasons: I feel spare tires mounted to nose is dangerous to my knees (I'm 6'7"), and I never was crazy about the appearance.
Because my bus is a Riviera conversion, its luggage rack is fairly deep. When the tire lays down flat inside, you can just barely notice that it is there.
It's mounted via stainless steel nuts that I JB Welded to the roof.
The nose mount needed some elevation so I found some new fuel line to act as bushings/spacers.
My OTHER neighbor had some of this U-Channel edging lying around which worked perfectly to dress up and protect the new shape of the luggage rack.
So now, I have a clean nose onto which I'll place a VW emblem.
Cheers! _________________ '75 Riviera
Posted: Tue Dec 08, 2009 7:33 am Post subject: |
Winter projects; here is my seat frame bottom after some time using a brass wire wheel to remove the crusty rust from the springs. I'll have to use a piece of sandpaper to get the parts that my wheel couldn't reach.
And maybe some soapy water or GooGone to clean the inside of the base.
Posted: Thu Sep 03, 2009 2:40 pm Post subject: |
You guys are so nice, thanks. BTW, Bus Depot got back to me and miss-shipped the wrong coupler. They are making it right.
But what about that spacer? It that important? It must be but I only found one spacer and I just don't know if it goes over or below the coupler? _________________ '75 Riviera
