bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Mon Jul 28, 2008 4:36 am Post subject: 84 Westy AC install |
I have the Air conditioning setup that was used in the early 80's (mine is an 84 westy). It has the evap/blower fan motor in the rear upper shelf of the camper cabinet (this unit is the one that blows the cold air at the back of your head). A previous owner removed the evap/blower and condensor, along with the AC wiring harness, and I've since replaced the evap/blower and condensor from parts bought here from fellow Sambies. Here's my delima: the Bentley (around page 97.134ish) has the 83-84 AC wiring diagram for the front part of the harness (wiring to new fuses, radiator fan, etc). Some of the wiring color codes do not match my harness. The harness I have came off of an 83.5 or 84 westy. I'm aware that these AC unit's were installed by the dealership, so kits are going to differ. My wiring assembly has 3 relays; one for the evap/blower fan that triggers off of the AC fan/temp switch located on the dash. This trigger (green wire) also feeds the relay for the radiator fan. Then there's a relay for the AC clutch. I'm just looking for confirmation of wiring colors and such. There's also a black "box" that has wire positions 1-8 (I'm assuming this is the "temperature circuit"), that does not match the Bentley as to assignments and color code. Two of it's 8 positions has two grey wires that eventually run to the rear, and then to a pair of "stiff" grey wires that connect to a red cap (resembles heat shrink). I'm assuming this is some sort of temperature probe that is inserted into the evaporator to detect temperature?
Has anyone documented the color codes for these early (82-85) years? _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
mmdingman Samba Member
Joined: July 18, 2007 Posts: 49 Location: Metro Detroit
Posted: Sat Sep 27, 2008 7:49 pm Post subject: me too |
i was hoping that someone had responded to this... I've just purchased a 85 weekender that... ...I now find out... ...that someone has retrofitted the A/C. Ah! It's on my list to confirm the wiring and solder the connections. but information is vague. Have you found a system diagram (relay locations, etc)? I'm sure that you know that Bentley starts with 86 for their a/c section. _________________ 85 Wesfalia Wolfsburg (2009ish - present)
87 Syncro Hardtop (1997 -2010ish) |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Sun Sep 28, 2008 6:51 am Post subject: Re: me too |
mmdingman wrote: |
i was hoping that someone had responded to this... I've just purchased a 85 weekender that... ...I now find out... ...that someone has retrofitted the A/C. Ah! It's on my list to confirm the wiring and solder the connections. but information is vague. Have you found a system diagram (relay locations, etc)? I'm sure that you know that Bentley starts with 86 for their a/c section. |
Vanagon Bentley pages 97.137 and 97.138 have the 84-85 A/C wiring diagrams.
Mark |
