westy circuit breaker source?
kshbaja
kshbaja is offline
PostPosted: Tue Jul 29, 2008 5:04 pm    Post subject: westy circuit breaker source? Reply with quote
Is the circuit breaker a common circuit breaker that can be found in an electrical supply store? Is GW the only source? $20 seems a bit excessive.
Lanval
Lanval is offline
PostPosted: Tue Jul 29, 2008 5:40 pm    Post subject: Reply with quote
More info would be helpful here ~ Van year/model, and what you intend to do with the circuit breaker. Most anything that can be done with a Vanagon (westy or otherwise) has been done, so if you explain what you want to do in detail, you're likely to get an answer in detail.
As an example, I installed an aux battery with a 6 circuit fuse box to run everything behind the seats on the aux when isolated. Is this what you're after? Are you re-doing the 120v circuit at the foot of the bed? If so, why even bother? How often do you use 120v? I replaced mine (GW version) and have yet to solder it in, or use it.
Best,
Lanval
kshbaja
kshbaja is offline
PostPosted: Tue Jul 29, 2008 5:49 pm    Post subject: Reply with quote
Sorry about that. I was referring to the stock circuit breaker of a 1986 Westy. It sits just forward of the rear bench seat on the driver side. Full stock electrical configuration. I just want to replace it as the button on mine is snapped off.
Lanval
Lanval is offline
PostPosted: Tue Jul 29, 2008 6:30 pm    Post subject: Reply with quote
I just paid Go Westy. Still, I don't see how a 120v circuit breaker in a van is any different from a house... I can't recall if the rating is marked on the old one. I'm sure the manual says, or somewhere in the manuals (OEM or Aftermarket) it should indicate what the breaker trips at. Once you're there, I guess you could go to any home supply place and try to replace it.
Electrical experts care to comment?
Best,
Lanval
terryg
terryg is offline
PostPosted: Tue Jul 29, 2008 7:14 pm    Post subject: Reply with quote
I'm guessing that the circuit breaker is there due to some RV electrical code applied to Westies. 120v breakers make sense in RV because there are multiple circuits so you would not have the whole RV to loose power because the coffee pot shorted out. But the Westy only has one circuit, so if anything happens all power is lost anyway. The other silly part is that if you plug into a campsite or the plug on the side of your garage, they are both already protected with circuit breakers so you really don't even need one. There might be some scenario where the Westy circuit breaker would be useful, but it would entail a van load of 120v appliances and/or some poorly thought out added wiring/extension cords. I'ld take it out and spend $3 on wire nuts and a pretty blank plate to cover the hole.
82WestyMan
82WestyMan is offline
PostPosted: Tue Jul 29, 2008 11:21 pm    Post subject: Reply with quote
terryg wrote:
... I'd take it out and spend $3 on wire nuts and a pretty blank plate to cover the hole.
Or do what I did...
used that place for a dedicated (and labeled) outlet from my inverter...
upper = "Shore Power"
lower = "Inverter Power"
"The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine
bucko
bucko is offline
PostPosted: Wed Jul 30, 2008 3:59 am    Post subject: Reply with quote
Go to Home Depot, Lowes, or any good hardware store. Buy a GFI (ground fault interrupt) and new cover. GFI's are used in 110/120V home applications where water and electricity are an issue (bathroom, kitchen, outside outlets). Much, much better protection than the breaker that came stock.
They are found where the electrical outlets, boxes, and such are located at these hardware stores.
I would not recommend this...no protection to you if you use an electrical hookup at a campground. You cannot count on the campground hookups being "up to code".
Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181
Captain Pike
Captain Pike is offline
PostPosted: Wed Jul 30, 2008 5:18 am    Post subject: Reply with quote
Bingo______Add protection not remove it.
Parrots,parrots everywhere but none ever stopped to think.
GET A FRAKIN BENTLEY__ Don't post without one.
In the time it takes to post___learning your BENT and trying a solution???WTF?
hiram6
hiram6 is offline
PostPosted: Wed Jul 30, 2008 7:01 am    Post subject: Reply with quote
Double bingo. I changed the outlet near the back seat into a GFCI outlet and correctly wired the under-sink outlet to it, so it's protected as well. I then bought a blank outlet cover to go over the bottom opening where the circuit breaker had been, but modded it into a 12V oulet.
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
PDXWesty
PDXWesty is offline
PostPosted: Wed Jul 30, 2008 9:55 am    Post subject: Reply with quote
**READ** **READ** **READ** **READ** **READ** **READ**
A GFCI outlet is NOT a circuit breaker. I repeat: IT IS NOT A CIRCUIT BREAKER. It does not protect against current overload. It protects against ground fault and short circuits only. The circuit breaker is there ahead of the outlet to protect the wiring from melting if you plug in a greater load than the wiring can handle. You run the risk of fire if you don't have a circuit breaker ahead of ANY type of outlet. A GFCI will not trip on current overload. If you plugged in a 15 amp load or greater (1800 watts) to the outlet without the breaker, you could melt the wires and start a fire.
**Please do NOT remove the breaker and just wire a GFCI outlet. You will lose all protection to the circuit.**
If you want, you can add a GFCI outlet to protect against shorts, but you still need the breaker ahead of it.
dpdunrite
dpdunrite is offline
PostPosted: Wed Jul 30, 2008 8:57 pm    Post subject: grainger whole sale and supply Reply with quote
kshbaja
Check grainger wholesale and supply the only thing differant is the one from CARLING TECHNOLOGIES is rated at 32vdc where as the one in the slot is rated at 50vdc
http://www.grainger.com/Grainger/items/4VA78
http://www.carlingtech.com/products/index.asp
You mite be able to talk to carlingtons tech support to verify that this will work. For $2.77 this mite be worth the call and easy fix.
good luck
dp
"Fritz" 88 vanagon westfalia 2.1 wbx
"Frank" 89 Kawsaki Mule 450cc twin
"Tony" 00 B21 Kubota
"Niles" 85 xj6 Jaguar Sauveriegn
"Al" 07 Cheverolet Silverado Z71 LT crewcab
"Soney" 78 18' Sunrunner runabout
"Kelly" Wife
"Kirby" Black Lab
"Bear" Black cat
bucko
bucko is offline
PostPosted: Thu Jul 31, 2008 5:04 am    Post subject: Reply with quote
I totally agree with you in that the breaker VW (or westfalia) installed is acting like the circuit breakers we have in our homes. However, I figured the GFCI also works as a circuit breaker too, as it trips and kills the flow of current if it jumps past 20 amps (or whatever rated GFCI you bought). Is this wrong thinking? Please educate me if I'm wrong.
As to wiring, my Westy (and I believe all of them do) have the standard household gauge 3 wires (white, black, and ground), and should handle 20 to 30 amp draw.
Dogpilot
Dogpilot is offline
PostPosted: Thu Jul 31, 2008 8:20 am    Post subject: Reply with quote
You can still achieve the dual use on the outlet. I made my duplex outlet into two simplex units. You can achieve this with virtually any 110 socket. THere are two tabs on either side, the connect the upper to lower socket. If you break this tab (which it is designed to do, by bending) then the two are separate circuits. So I wired the lower one to the normal shore power circuit, and the upper one is wired to my hidden inverter.
Yes GFI's are cool for shocks and such, but no circuit protection. A breaker is a breaker. That said, there are ratings for voltage, current and rate of trip. Some trip on a surge of load, some wait a bit. So if you get one of equal load rating, voltage and trip rate you would be fine. The big problem is form factor, most are designed for mounting on rails now. So you are kind of paying for uniqueness again.
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
PDXWesty
PDXWesty is offline
PostPosted: Thu Jul 31, 2008 9:21 am    Post subject: Reply with quote
Just use a circuit breaker....they're cheap.
http://www.westmarine.com/webapp/wcs/stores/servle...sNum=14180
(reading)
GFCI is an electrical wiring device that disconnects a circuit whenever it detects that the electric current is not balanced between the phase ("hot") conductor and the neutral conductor. Such an imbalance is sometimes caused by current leakage through the body of a person who is grounded and accidentally touching the energized part of the circuit
GFI's are designed to prevent electrocution by detecting the leakage current, which can be far smaller (typically 530 milliamperes) than the currents needed to operate conventional circuit breakers or fuses (several amperes). GFIs are intended to operate within 2540 milliseconds, before electric shock can drive the heart into ventricular fibrillation, the most common cause of death through electric shock.
In the United States, the National Electrical Code, requires GFCI devices intended to protect people to interrupt the circuit if the leakage current exceeds a range of 46 mA of current (the trip setting is typically 5 mA) within 25 milliseconds. GFCI devices which protect equipment (not people) are allowed to trip as high as 30 mA of current. In Europe, the commonly used RCDs have trip currents of 10300 mA.
Residual current detection is complementary to over-current detection. Residual current detection cannot provide protection for overload or short-circuit currents.
So...It measures the current in the two wires to make sure they are equal. It does not protect against short circuit or overload.
Captain Pike
PostPosted: Mon Aug 04, 2008 6:16 am    Post subject: Reply with quote
Keep the standard pulg, replace the breaker with a GFI breaker. Ground fault AND over current protection.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Mon Jan 20, 2020 12:52 am    Post subject: Re: westy circuit breaker source? Reply with quote
Hi all.
Anyone found a suitable 15 Amp breaker at their local hardware or home depot type store?
Thanks
Neil.
1981 Westy air cooled to 15 ABA swap: http://tinyurl.com/y9n4xob8
50 ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
shagginwagon83
shagginwagon83 is offline
PostPosted: Mon Jan 20, 2020 10:39 am    Post subject: Re: westy circuit breaker source? Reply with quote
Perfect timing. I am also in the market for a new circuit breaker as I'm relocating mine to be hidden in my Westy.
My research has showed Blue Seas makes circuit breakers. I don't know if they make it, but I would love to have a remote control circuit breaker.
Edit:
I found one. Its a 20amp model.
Home depot has a 15amp model.
Brandon
"Jo Ann" - 1983.5 Ivory Westfalia 1.9L 2wd
120aH aux, 200w rooftop solar, 130w portable
Dometic CFX50W fridge
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Jan 20, 2020 10:48 am    Post subject: Re: westy circuit breaker source? Reply with quote
Maybe this?
https://www.amazon.com/dp/B00DH35VZQ/ref=twister_B01LYLZ9U4?_encoding=UTF8&psc=1
Vanagon Nut
PostPosted: Mon Jan 20, 2020 11:13 am    Post subject: Re: westy circuit breaker source? Reply with quote
crazyvwvanman wrote:
Maybe this?
Thanks Mark. Just ordered a starter motor from amazon; too late to include that part! lol. Wink
Hadn't thought to look up via "DC" as per breaker you linked to.
The existing breaker appears to have push on connectors that are very well insulated. I see amazon has these with push on connectors
https://www.amazon.com/Blue-Sea-Systems-Connect-Ci...amp;sr=8-3
https://www.amazon.com/RKURCK-125-250V-Circuit-Ove...6e7b0f409c
Neil.
VE7TBN
Vanagon Nut
PostPosted: Tue Jan 21, 2020 1:50 pm    Post subject: Re: westy circuit breaker source? Reply with quote
Neil.
I'm going to order both to compare quality, at least visually.
I'll post images later but it looks like both of these breakers are quite similar in size to what I assume is an OE westfalia breaker in my '81 Westy. It still works but was hard to reset last time it blew and may be getting flakey (has a bimetallic strip? Its seen too many heat cycles?)
Blue sea Push Button Reset Only Quick Connect Circuit Breaker - 15 Amps
7056
RKURCK 125-250V AC 50V DC Push Button Circuit Breaker 15Amp Thermal Overload Protector L1 Series Manual Reset Thermal Circuit Breaker 15A
Didn't bother looking for image of Blue Sea part showing same but this shows what *looks like* a flat portion on threaded shaft
VE7TBN
