kingsfanrob Samba Member
Joined: December 24, 2007 Posts: 126 Location: San Dimas
Posted: Thu Jul 31, 2008 6:40 pm Post subject: Lowering the rear |
I am doing a search as you read...I am looking for a quicker answer. I am going to lower the rear of a 64. 205 60's on 5 spokes. I do not want a lot of camber, do I adjust the "outer" splines? I looked at the pic's thread on tire set up and it confused me more. I figured 2 notches or the spring plate drop extensions. I will continue to read threads but your input should be helpful. Thanks. I will be posting an add for repop alloys soon so be on the look out. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Thu Jul 31, 2008 6:54 pm Post subject: |
Two outer notches will give you a lot of camber. One outer notch will do and you'll have to remove your bump stops as well. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
outer or inner? |
Joey Samba Member
Posted: Thu Jul 31, 2008 6:55 pm Post subject: |
outer.
I did the +5 & -5 on my '65:
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Fri Aug 01, 2008 5:01 am Post subject: |
If you only want to go down a little, you won't need the extensions.
The extensions are only needed if you are going extream. _________________ Mother Nature is a Mean Evil Bitch! |
Joey Samba Member
Posted: Fri Aug 01, 2008 9:21 am Post subject: |
I'm not to keen on having to cut off the lower shock mount. I don't do nothing that can't be reversed back to stock ....but that's just me. _________________ Joey
ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
Posted: Fri Aug 01, 2008 9:24 am Post subject: |
56ovalbug wrote: |
I'm not to keen on having to cut off the lower shock mount. I don't do nothing that can't be reversed back to stock ....but that's just me. |
I just put the extensions on my car. even though you have to cut off the shock tower its not that big of deal easily replaceable to bring back to stock.What I liked about them is that I got the look I wanted and didnt have to mess with the spring plates. If I ever want to go back to stock Ill just put new ends on the axel tubes. here are pics of my car with the extentions. http://www.thesamba.com/vw/forum/viewtopic.php?t=294170&start=80 _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build |
Posted: Sat Aug 02, 2008 9:05 am Post subject: |
alright guys, I have finally finished reading all of the threads, and man do you guys offer a lot of info. Now I am stuck becuase I am not sure of the look I want now. Cal Look with stock rear or slammed. Which method gives me more clearance for the exhaust. I would hate to mash on the peddle only to have my exhaust stay at the light. |
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1184 Location: Dallas, GA
Posted: Sat Aug 02, 2008 9:19 am Post subject: |
go with one outer spline, you'll be happy. I run 205 60's on my '67 with it down one outer spline. No clearance problems with the tires and still have some reasonable clearance for an aftermarket exhaust.. oh and free
I can't figure out the argument for the drop extensions.. They claim it so they don't have to mess with the spring plates. At the same time, their defense for cutting off the lower shock mount is that the end casting is replaceable. I don't know about you, but re-indexing the spring plates is a LOT easier than trying to swap out the end casting on an axle tube. I think everyone is just jumping on the bandwagon and haven't ever tried to do either of the procedures. So that logic doesn't really add up for me... Now if your going for super slammed, then there is some benefits with the drop extensions to help keep the toe on the rear in check, but I digress..
Re-indexing your spring plates is not difficult and there is a ton of tech info and step by step instructions online to help you out _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
Joey Samba Member
Posted: Sat Aug 02, 2008 12:35 pm Post subject: |
Vee Dub Nut wrote: |
Re-indexing your spring plates is not difficult and there is a ton of tech info and step by step instructions online to help you out |
Exactly. One hour for the first side (learning curve) and half hour for the other. Change the bushing while you're in there. And, if one side is lower than the other you can fine tune it - can't do that with just the drop extensions. _________________ Joey
