Pop Out Window Restoration
imtb
imtb is offline
PostPosted: Wed May 14, 2014 9:09 am    Post subject: Reply with quote
Coud someone post a pic of the seal installed on the body?
BulliBill
BulliBill is offline
PostPosted: Wed May 14, 2014 9:45 am    Post subject: Reply with quote
I did not use an adhesive on the seals attached to the door frame. The flatter side rests against the pop-out frame, the curvier side of the seal faces toward the interior of the cab. I'll look to see if I shot any close-up photos of the installed seal in my build thread.
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
BulliBill
PostPosted: Wed May 14, 2014 9:50 am    Post subject: Reply with quote
Here is the only photo I shot showing that seal on the door frame, perhaps you can see the curved side facing in...
Bill
otis_bartleh
otis_bartleh is offline
PostPosted: Wed May 14, 2014 10:26 am    Post subject: Reply with quote
Bill
What's up with the pop out opening the wrong way? Shouldn't that one be opening forward?
-Adam
'59 Mango Bus
'69 Bug
mandraks
mandraks is offline
PostPosted: Wed May 14, 2014 10:57 am    Post subject: Reply with quote
otis_bartleh wrote:
Bill
nothing wrong here, this is a crewcab
regards
Uli
otis_bartleh
PostPosted: Wed May 14, 2014 10:58 am    Post subject: Reply with quote
Ahh, that explains that. Very Happy
-Adam
'59 Mango Bus
'69 Bug
Darth Wolfsburg
Darth Wolfsburg is offline
PostPosted: Wed Nov 26, 2014 5:46 pm    Post subject: Pop out measurments Reply with quote
Does anyone have the accurate measurements for the pop out glass?
I bought glass that was advertised as taken from a pop out bus, but it is about 1/4 inch too big for my pop out frames.
EDragnDean
EDragnDean is offline
PostPosted: Wed Nov 26, 2014 6:29 pm    Post subject: Reply with quote
18 1/4 by 14
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
BarryL Premium Member
BarryL is online now
PostPosted: Wed Nov 26, 2014 7:39 pm    Post subject: Re: Pop out measurments Reply with quote
Sounds like you got sold "stationary glass" that got popped out of a bus.
If it is, you should be able to resell it.
Breckskier
Breckskier is offline
PostPosted: Mon Dec 01, 2014 11:23 pm    Post subject: Reply with quote
Pop out outer frame Rubber needs to bend out towards exterior, so it lays flat when window is pulled closed. So does that mean, long side without the groove faces down / towards interior? I guess a picture would help..
BreckSkier
67 13w Deluxe-"St. Pete" the Airport Jet Bus
65 13w Deluxe-"St. Nikolas"
67 912(911.5 Outlaw build spring 2015), 90 C4Cab. Formerly: 59 DD, 78 SuperB, 81 911Cab, 82Vanagon, 81Vana & other German / US stuff..
Breckskier
PostPosted: Mon Dec 01, 2014 11:27 pm    Post subject: Reply with quote
jjjjack wrote:
Can someone confirm for me that this is correct?
Thanks!
Never mind. I looked back & found this.
BreckSkier
Darth Wolfsburg
PostPosted: Tue Dec 09, 2014 9:07 pm    Post subject: Re: Pop out measurments Reply with quote
BarryL, I'll be posting it for sale soon. They are good pieces of glass
21-window
21-window is offline
PostPosted: Sat Dec 13, 2014 1:33 pm    Post subject: Reply with quote
Does the seam (where the rubber is joined) in the seals go at the top (12 clock position) or bottom?
I see bullibill has his outer pop out seams at the top can't tell on the others, is this correct?
do all three seams go in the same spot?
EDragnDean
PostPosted: Sat Dec 13, 2014 2:11 pm    Post subject: Reply with quote
Placed mine at 12. Imagine anything other than a corner would work fine.
Breckskier
PostPosted: Sun Dec 28, 2014 5:48 pm    Post subject: Reply with quote
Ping.... The worst sound.
I believe when the old screw were drilled out, they didn't line up properly. So when I tried to get new screws in, it pulled the frame too tight & ping....
I guess it happens.
BreckSkier
EDragnDean
PostPosted: Sun Dec 28, 2014 6:05 pm    Post subject: Reply with quote
That blows, 18 windows and I guess I was lucky...
mandraks
mandraks is offline
PostPosted: Sun Dec 28, 2014 9:27 pm    Post subject: Reply with quote
instant privacy glass
regards
Uli
Breckskier
PostPosted: Sun Dec 28, 2014 10:16 pm    Post subject: Reply with quote
Ha! For sure. The other 11 went well so far...
BreckSkier
dualport
dualport is offline
PostPosted: Sun Mar 15, 2015 3:17 pm    Post subject: FWIW West Coast Metric inner glass seals Reply with quote
I don't know if the WCM inner glass seals I got were in "mid run" but some were very tight (had to stretch all the way around) and some were almost too loose.
Conrad @ Air Coolers VW Gang http://aircoolers.org
Air Coolers Google Map of clubs, services and shops: https://goo.gl/3KM4wm
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
StockNazi
StockNazi is offline
PostPosted: Sun Mar 15, 2015 6:49 pm    Post subject: Reply with quote
Has anyone used the top half of a rusty pop-out to fix the rusty bottom of another? Is is worth the trouble?
You could build a quick wooden jug to keep the window opening the same size. Cleaning out the outter seal channel groove could be difficult.
Any imput appreciated.
WANTED:
Westfalia privy tent poles(silver painted / pre-59)
58 Westfalia roof rack and cabinet knobs
Page 6 of 10
