avocado_tom Samba Member
Joined: June 18, 2007 Posts: 235 Location: Pittsburgh, PA
Posted: Mon Apr 24, 2017 8:09 pm Post subject: Re: Pop Out Window Restoration |
rennie wrote: |
I believe they are M3.5 x .6 for the original size. If you have to re-tap them then M4 is what works.
I rang WW since I couldn't locally find the 3.5 for the hinge screws (which i didn't have to re-tap). They tossed them in an envelope for $2 and I had them in two days.
On their site they sell both the 3.5 and the 4... but what you'll use depends if you re-tap. |
Thanks!!! |
Posted: Mon Apr 24, 2017 9:21 pm Post subject: Re: Pop Out Window Restoration |
Just to be clear, is it M3 with a thread pitch of 0.5 and a length of 0.6 (cm?)?
Or M3.5 with a length of 0.6 cm?
Or M3.5 with a thread pitch of 0.6 (which sounds odd) and a length of...? |
rennie Samba Member
Joined: October 06, 2016 Posts: 246 Location: Orange County, CA
Posted: Mon Apr 24, 2017 9:46 pm Post subject: Re: Pop Out Window Restoration |
The last one as I recall, as I couldn't find any length locally between 3 and 4.
After writing that sentence, I went back to early posts in this thread and the OG poster stated "original tap size is 3.5mm x .6 pitch"... so my memory isn't 100% shot yet. Now if I could just find my glasses! Oh, they're on my head...!
Posted: Mon Apr 24, 2017 9:54 pm Post subject: Re: Pop Out Window Restoration |
rennie wrote: |
After writing that sentence, I went back to early posts in this thread and the OG poster stated "original tap size is 3.5mm x .6 pitch"... so my memory is 100% shot yet. Now if I could just find my glasses! Oh, they're on my head...! |
Thanks! (and well done!) |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Fri Jun 30, 2017 10:41 am Post subject: Re: Pop Out Window Restoration |
Have I said how much I love using woodworking clamps to build a pop out window? I finally ventured out into the workshop to tackle this part of my build. I drilled and tapped 4 frames, build 2 in no time using these clamps. Have any of you used clear glide on the rubbers to aid them sliding into place?
Frame to glass and frame to body seal as well. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Fri Jun 30, 2017 11:16 am Post subject: Re: Pop Out Window Restoration |
DubStyle wrote: |
Frame to glass and frame to body seal as well. |
Woodworking clamps are the way to go on the pop-out assembly for sure. On my last window install I used vasoline on everything which worked very well. _________________ Brandon |
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 899 Location: Las Vegas, NV
Posted: Tue Sep 26, 2017 5:27 pm Post subject: Re: Pop Out Window Restoration |
I have a question about removing the outside seal from the small channels. I live in the desert where it gets really hot 110 degrees in the summer. The window seals on my double cab might still be the original ones from 1959 and the rubber is petrified. I started to work on one pop out window today and the rubber is so hard you have to use a tiny screw driver and a mallet to hammer and do sections 1/8 inch at a time. It seems almost like I am chiseling out concrete. I spent 2 hours and did about 1/2 of one frame, does anyone know of a better way to get the extremely sun baked petrified seals off? I am trying to use the original paint window frames so it is not an option to just buy new frames.
_________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
CaLiBus Samba Member
Posted: Tue Sep 26, 2017 5:31 pm Post subject: Re: Pop Out Window Restoration |
I used light heat from a small propane torch. it should work for petrified rubber? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Tue Sep 26, 2017 5:32 pm Post subject: Re: Pop Out Window Restoration |
I have done this on a couple AZ Buses and it's basically how you mentioned.
One thing that helped me was to use a razor blade to slice the rubber along its length. A lot of times this let me slide or pull out large thin pieces all at once, once I got one end of a slice popped out of the channel with a tiny screwdriver. _________________ How to Post Photos
rennie Samba Member
Posted: Tue Sep 26, 2017 5:40 pm Post subject: Re: Pop Out Window Restoration |
ronjonlasvegas wrote: |
I have a question about removing the outside seal from the small channels. I live in the desert where it gets really hot 110 degrees in the summer. The window seals on my double cab might still be the original ones from 1959 and the rubber is petrified. I started to work on one pop out window today and the rubber is so hard you have to use a tiny screw driver and a mallet to hammer and do sections 1/8 inch at a time. It seems almost like I am chiseling out concrete. I spent 2 hours and did about 1/2 of one frame, does anyone know of a better way to get the extremely sun baked petrified seals off? I am trying to use the original paint window frames so it is not an option to just buy new frames. |
I only have one pop out but had the very same issue with the OG seal. I didn't try it but just now thought about heat gunning to make it softer (if possible) then cut it up in the channel with a carton cutter or thin, small tip slotted screw driver. Blue sky, I know. I ended up breaking/cutting mine up that way in the channel (sans heat gun) and guided it to the corners where I could wedge some of it out. |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Tue Sep 26, 2017 5:48 pm Post subject: Re: Pop Out Window Restoration |
Hey Ron, I tried everything, razor blade, pick, thin flat screw driver, even jabbed myself in the hand OUCH
So on mine, my pop outs came straight from Yuma Arizona so I know exactly what you mean. Petrified black coal. I used my cut off wheel (whiz wheel) and went completely around the window frame dead center over that hard ass petrified rubber. my cut off wheel blade was kind of thick so by the time I broke completely through the old rubber, I could literally shake them and one side would fall out, then the other side would fall out. Basically I was splitting it into two strips and the void of rubber I cut down the center of the frame made an open 'aisle way' so the rubber acted like when people get off an airplane once it lands if that makes any sense _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Posted: Tue Sep 26, 2017 6:08 pm Post subject: Re: Pop Out Window Restoration |
Thanks you all for the helpful tips, I will try out these methods. I have a heat gun, razors and a grinder with a cut off wheel. _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
western auto Samba Member
Posted: Tue Sep 26, 2017 8:33 pm Post subject: Re: Pop Out Window Restoration |
Skim wrote: |
So on mine, my pop outs came straight from Yuma Arizona so I know exactly what you mean. Petrified black coal. I used my cut off wheel (whiz wheel) and went completely around the window frame dead center over that hard ass petrified rubber. my cut off wheel blade was kind of thick so by the time I broke completely through the old rubber, I could literally shake them and one side would fall out, then the other side would fall out. Basically I was splitting it into two strips and the void of rubber I cut down the center of the frame made an open 'aisle way' so the rubber acted like when people get off an airplane once it lands if that makes any sense |
good idea with the cut off wheel, I used a hammer and small screwdriver to shatter the rubber yielding many pieces in my eyes, I will have to try the grinder on all this Yuma crispy rubber |
Alex1976 Samba Member
Joined: April 11, 2005 Posts: 97 Location: Atascocita, TX
Posted: Sat Oct 21, 2017 2:22 pm Post subject: Re: Pop Out Window Restoration |
I'm currently restoring my pop outs as well but I'm not sure if I installed them properly. Sorry, despite owning my bus forever, I'm still a bit of a newb so please excuse my questions that probably have a simple answer I couldn't find.
I've been posting my progress on my bus thread (here's where the pop out window portion starts - https://www.thesamba.com/vw/forum/viewtopic.php?p=8576909#8576909) but this is where I'm running into a snag. I've dry fit the seal to the body and put the windows in. I'm not sure I installed it correctly though, as it's extremely difficult to open the windows. Could someone look over what I've done? Did I do it correctly? Do they eventually "loosen up" or did I mess up by putting the wrong thing somewhere the wrong way?
_________________ 1966 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=678279
Follow me on Instagram, where I post a lot of bus progress. https://www.instagram.com/quietlyscheming/
“Don't be a dick.” --Wheaton's Law, Wil Wheaton |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
Posted: Sun Oct 22, 2017 10:03 am Post subject: Re: Pop Out Window Restoration |
EDragnDean wrote: |
Did you put baby powder on the outside of the seals? And can't tell if your frame on the body is raw... Is there paint? |
I didn't put any baby powder on the outside of the seals. The windows are extremely difficult to open to the point I'm concerned I'll break them trying to open them.
The body painted with primer. Did I install the seals properly? Are they supposed to be that tight initially? _________________ 1966 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=678279
marius71 Samba Member
Joined: July 22, 2012 Posts: 22 Location: Switzerland
Posted: Sun Mar 11, 2018 10:37 am Post subject: Re: Pop Out Window Restoration |
I am making my pop-out windows. My original rubbers look different. They don't have the lip going over the frame surface. That will have another look afterwards. The black rubber line will be more visible.
Also the base looks way thicker than the ww part. I hope they don't fall out...
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Sun Mar 11, 2018 10:46 am Post subject: Re: Pop Out Window Restoration |
Original German was like the top photo of WW rubber. The stuff in your thumb top and bottom photo looks more like the squeegee on top of the front doors window frames.
What WW rubber is in the bottom photo? |
Posted: Fri Mar 30, 2018 10:00 am Post subject: Re: Pop Out Window Restoration |
It's the same parts, just taken the picture from the opposite side. |
btdt Samba Member
Joined: November 07, 2017 Posts: 3 Location: Grand Lake Oklahoma
Posted: Wed Apr 04, 2018 11:21 am Post subject: Re: Pop Out Window Restoration |
Has anyone tried rivets versus welding the pop-out hinge in place? I have a DC that is no where need OG and new pop-outs will open towards rear so seems less strain on hinge. All body work is done and my mig is toast, not to mention engine is out and will have to trailer for the welding. Hate to purchase a new welder to secure two hinges. Has anyone welded it with stick? |
