67 Tail light ground location
turbotype1
turbotype1 is offline
PostPosted: Thu Apr 16, 2020 8:22 am    Post subject: 67 Tail light ground location Reply with quote
Anyone know where the ground wires for the tail lights on a 67 connected to the body from the factory?
It's been 8 years since I took this thing apart and can not find where they were screwed to the body anywhere.
I know I can drill a new hole anywhere, but was wondering were the factory connection was located....
Thanks....Pete
117harv wrote:
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru
64 all original for the misses
Clara Premium Member
Clara is offline
PostPosted: Thu Apr 16, 2020 8:36 am    Post subject: Re: 67 Tail light ground location Reply with quote
They ground through a tab onto the inside of the body. 67s did not come with a wire ground, those are later taillights. If you want a wire ground (which often works better) you need to drill a hole. There is not a factory ground wire tab location for the taillights.
On the right side you can use the battery ground location.
srfndoc
srfndoc is offline
PostPosted: Thu Apr 16, 2020 8:52 am    Post subject: Re: 67 Tail light ground location Reply with quote
If your 67 has reverse lights you can swap out for a later body that has a ground tab built in and use that to ground your taillights. As Clara mentioned, the lights almost always work better by adding a ground.
Evan's Spreadsheet for Bus RPM, based on gearing & tire size (ODS Format)
"The world is in no hurry for another painted bus."
-Maurice
turbotype1
PostPosted: Thu Apr 16, 2020 9:12 am    Post subject: Re: 67 Tail light ground location Reply with quote
Thanks for the replies.
Mine is an early 67 (Nov 66) and does not have back up lights. The tail light housings do have a tab on them for a ground wire. The harness that i got came with 2 separate ground wires .... Time to do some drilling I guess.
Thanks again....Pete
PostPosted: Thu Apr 16, 2020 9:26 am    Post subject: Re: 67 Tail light ground location Reply with quote
On my '63 I have later buckets with a ground tab and I grounded it to the battery negative cable bolt on the right side with a large ring connector.
The left side has a wire running alongside the harness that runs side to side above the decklid so there are already clips there to hold it in place.
Not my Bus but like this but with a ring connector instead of jamming the bare wires in there:
PostPosted: Sat Apr 18, 2020 4:03 pm    Post subject: Re: 67 Tail light ground location Reply with quote
I took a pic today of my Bus and how I did it:
