dredward Samba Member
Posted: Sat Aug 02, 2008 10:13 am Post subject: where do v/bk and brown wires go on fuel sending unit? |
The fuel sending unit has a violet/blk wire and a brown wire going to it. What wire goes where on the fuel sending unit plug: what one goes right and what one goes left?
These wire were prev. cut(not by me). Some one spliced 2 blk wires at the plug so i am unsure of their orientation. The 1.8t swap is damb near done and this is one of the things i am working on before i bolt in engine/ trans asembly. Thanx in advance. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Sat Aug 02, 2008 12:54 pm Post subject: |
Do you have a Bentley? the answer is in there...
Ground is the brown wire and the Gauge wire is the violet/black.
Posted: Sat Aug 02, 2008 1:38 pm Post subject: thanx for reply. |
I have bently. I hoowever can't figure out orientation because sender is situated in tank on car. Faceing the driver side wheel well what wire goes where? I'll try and figure it out from pic but thus far i cant. Thanx for reply. |
Dogpilot Samba Member
Posted: Sat Aug 02, 2008 1:47 pm Post subject: |
As a suggestion, get your meter, check and see if one pin is common to the body of the unit. If not, then it is shielded from the metal. The other test is to hook it up one way, and look at your gauge. If it reads backwards (full when empty) the hook it the other way. It is a resistor with a wiper to pick off position. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Posted: Sat Aug 02, 2008 1:50 pm Post subject: I got it thanx |
I figured it out thanx |
Posted: Sat Aug 02, 2008 2:41 pm Post subject: |
Gad you got it - above I thought you had a better angle on seeing it, you did ask which one went right and which went left. |
Posted: Sat Aug 02, 2008 5:29 pm Post subject: |
Thanx for pic . I felt like an idiot i didn't figure it out from one look.... |
