mototard Samba Member
Joined: August 08, 2003 Posts: 66 Location: Tuscaloosa Al
Posted: Sun Aug 03, 2008 3:42 pm Post subject: More postitve wheel offset or narrowed beam |
I notice that everyone is running narrowed beams to lower and run wider/taller tires. Would using a wheel with more offset do the same? My 67 bug looks like 55mm to 60mm offset would easily clear the shock towers.
I have a set of 16x7 with roughly 57mm (2 1/4")offset. I can set them on the stock drums and they will clear the shock towers and tie rods. Problem is my beam is not installed in the bug yet. (doing pan off) I will be running stock wideth fenders with adjustable beam. I will also be getting rid of the drums for disc drill for 5x100mm. Tires are 190 50 16 which are shorter than the current 155 80 15. Anyone running this much offset on a stock wideth beam? _________________ MOTOTARD |
WVbugman Samba Member
Joined: February 03, 2005 Posts: 68 Location: Petersburg, WV
Posted: Mon Aug 04, 2008 9:49 am Post subject: More positive wheel offset or narowed beam |
Narrowed beam if you want to tuck your tires under your fenders. While your tires may barely clear , they'll hit when turning. If you decide to try it , drop your front just an inch or so to level it out and use shocks that will bottom out before your tires hit your fenders.
I measured my tire clearance on my 70 with 195/50r16 on 16x6, 42 mm offset wheels, 2inch narrowed beam and dropped spindles. The extra 15mm offset doesn"t make up for narrowed beam. Be sure your 16 x7 wheels clear when turning , mine rub on the wheel weights when turning {i'm changing to stick on weights on top of my rims}. |
Posted: Mon Aug 04, 2008 3:46 pm Post subject: |
What part is rubbing your weights? The 16x7s I have almost rub the shock tower everything else is above the bead on the rim. Guess I'm going to have to mock it up and see that way I can tell how narrow I can go. But as of now the 16x7s have 1/4" between the tire and the shock tower. I already have center stick on weights so that is not a problem. How far away from your shock tower are you? And how far under the outside fender lip is tire? Also do you have any pics of this setup? _________________ MOTOTARD |
RafCarre12 Samba Member
Joined: January 06, 2008 Posts: 1019 Location: Glen Rock, NJ
Posted: Tue Aug 05, 2008 5:43 pm Post subject: |
I have 16x7's in front and 16x8's in back of my type 3. Both wheels have an offset of et53mm with 25mm adapters. The fronts have a little bit of the narrowed look I think...
_________________ Type 3 Fasty |
Posted: Wed Aug 06, 2008 4:19 am Post subject: |
Very sweet square back. Always wanted one. _________________ MOTOTARD |
Franklin's VW Werks Samba Member
Joined: November 25, 2002 Posts: 138 Location: Pacific Northwest
Posted: Wed Aug 06, 2008 9:29 am Post subject: |
That offset is pretty high - I'd be really suprised if that just worked out of the box.
You're likely going to have to play with spacers as well as probably get a narrowed beam. What looks right off the car is rarely what works when actually installing.
Like you alluded to, you've got to watch both the clearance inside as well as outside at the fender. Weighted fit is a ton different than unweighted fit. _________________ Franklin's VW Werks
Service and Parts for the Pacific Northwest and Worldwide.
Custom Narrowed Beams, Wilwood/Porsche Brake Kits, Roll Cages and More!
On MySpace
SBS #24 |
