Tower Rat 95B Samba Member
Joined: July 15, 2008 Posts: 405 Location: Kingston N.Y. New York
Posted: Tue Aug 05, 2008 4:52 am Post subject: Remote spin on oil filter |
Anyone have a remote spin on oil filter? Where did you buy it? Do you have a pic? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Tue Aug 05, 2008 5:35 am Post subject: |
I used to have one, part of my external oil filter/oil cooler kit from 1976. But I didn't like the location (messy, crowded), now use a Maxi 2 combined pump/filter kit, from Claude's Buggies (now CB Performance). _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Tue Aug 05, 2008 12:58 pm Post subject: |
http://geersengineering.com/OilFilter.htm _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
rkeller Samba Member
Joined: February 15, 2007 Posts: 169 Location: Wake Forest, NC
Posted: Sat Mar 21, 2009 5:21 am Post subject: |
Empi remote oil adapter; Bugpack mounting bracket and a good oil filter (see posts about oil filters). Stainless steel braided teflon lines 1/4" straight at the pump, 3/8" swivel at the filter. I used one 3/8" x close nipple with a 3/8" elbow and a 3/8 x 1" nipple with elbow for the other line so I could tighten them up without hitting each other. No leaks at the filter but the oil pump is seeping a little.
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Mar 21, 2009 5:54 am Post subject: |
Don't forget to put the valve cover back on... _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
bon2198 Samba Member
Joined: August 04, 2008 Posts: 1969 Location: Nashville, GA
Posted: Sat Mar 21, 2009 6:37 am Post subject: |
Russ Wolfe wrote: |
Don't forget to put the valve cover back on... |
hahahahahahahahahahahahahaha _________________ 1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
"It's better to be hated for what you are than loved for what you are not"
At the end of the day it's YOUR car so do what YOU want to it. |
Posted: Sat Mar 21, 2009 8:16 am Post subject: |
Check out the rockers. Not sure what brand, got them from A.J. Simms who did my heads. Really happy with them, super easy to adjust. They are 1.25 ratio's and look similar to Porsche 356/912 rockers I've seen. |
