orangebychoice Samba Member
Posted: Fri Jul 11, 2008 2:29 pm Post subject: Replacement for '67 fuel gauge? |
I can't afford nos right now, is there a compatable fuel gauge for my bus. I need a 12v replacement, pretty much anything compatable, size or color isn't an issue, I need to know how much gas I have! I'll figure out a place for a weird guage for now! _________________ 1967 Kombi
...Comfortably Numb... |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Fri Jul 11, 2008 3:10 pm Post subject: |
Not sure, but I think a common 6v bus fuel gauge will work just fine. You'll need a 12v bulb for the light. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
chrome Samba Member
Joined: March 21, 2003 Posts: 746 Location: back in NorCal
Posted: Fri Jul 11, 2008 3:51 pm Post subject: |
ive used plenty of 6volt gauges with 12 volt systems and never had any problems, just use a 12 volt bulb _________________ 65 21 window
57 T1 ragtop
58 ghia vert
68 fastback
73 Thing
74 Thing
54 chevy 210
63 mercury meteor wagon |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Mon Sep 01, 2008 4:34 pm Post subject: |
If you want a 6 volt gauge to last longer on 12 volts, put a 100 ohm 1 watt resistor in series with the power lead. Radio Shack has them. Be sure to insulate the bare wires! |
Ragman The Sambinator
Posted: Tue Sep 02, 2008 3:34 pm Post subject: |
dstefun wrote: |
Is this necessary? How long do 6V gauges take to burn out running 12V? |
Posted: Tue Sep 02, 2008 4:14 pm Post subject: |
Ragman wrote: |
dstefun wrote: |
Is this necessary? ? |
Necessary? Maybe not. Recommended? Yes. VDO added an 82 ohm 1 watt resistor internal to the gauge when they went to 12 volt. Even Bay bus gas gauges up to the mid-70's or so have the 82 ohm resistor in the gauge. 100 ohm resistors are just much easier to find than 82's.
Ragman wrote: |
Time is relative. How long does it take to blow an engine? Maybe 20 seconds, maybe never. |
BlastMasterMannyFresh Samba Member
Joined: November 21, 2001 Posts: 6102 Location: #31peach
Posted: Tue Sep 02, 2008 6:40 pm Post subject: |
since we're in the subject, I have a 6 volt gauge in my 67 and for the longest it would only make it up to about 3/4 of a tank when I filled up then work its way down slowly and by the time it got to the R I would still have about a lot of gas left in the tank, this year I replaced the ground thinking it was weak, immidiately it jumped to full tank which got me all wet in my pants bc I did have a full tank of gas at the moment, well aperantly I havent used any gas this year bc it's still on full and not moving, could it be the sender that's messed up? or perhaps the gauge messed up? or a combination of both? |
wanta23 Samba Member
Joined: March 31, 2007 Posts: 534 Location: At The Beach
Posted: Tue Sep 02, 2008 6:56 pm Post subject: |
How can I tell the difference between a 6 and 12 volt? _________________ '66 13 window camper
www.makaibuildinginspection.com |
Posted: Tue Sep 02, 2008 7:06 pm Post subject: |
wanta23 wrote: |
How can I tell the difference between a 6 and 12 volt? |
6volts has a a 6v stamped in the back, 12 volt would have a 12v |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Tue Sep 02, 2008 7:54 pm Post subject: |
My DC has a ghia guage. Same diameter. Of course, it isn't shaped to fit the bus dash. But I bet you could swap the rings or just leave it, like I did mine. The only people who notice are the stock Nazi's anyway. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Wed Sep 03, 2008 11:10 am Post subject: |
mannys66 wrote: |
When you replaced the ground wire, did you accidentally ground both brown wires at the tank? Short brown wire at the sender goes from sender mounting screw to body ground, long brown wire goes from sender terminal to the gauge.
At the sender, unhook the long brown wire from the gauge to the sender terminal, NOT the short brown wire from the sender mounting screw to the body. With the key on, the gauge should now read empty. If it doesn't, the wire is grounded somewhere between the gauge and the sender, or the guage could be grounded internally and then you have to replace the gauge. Check the wiring first. If the gauge still reads full at this point, remove the brown wire from the gauge and it should drop to empty. If not, bad gauge. If you took it off, be sure to put the wire back on the gauge before the next check.
If the gauge drops to empty on the above check, ground the wire you removed from the sender terminal to the body. With the key on, the gauge should read full. If that works, then your gauge is fine and the sender is bad or just stuck. Since you have to pull the engine to pull the tank to remove the sender, you might as well replace it with a new one. $39 from Chris Seeger @ L5VW in Salem. The sender is the same for 6V or 12V, just the gauge is different.
http://www.thesamba.com/vw/classifieds/detail.php?id=614029 |
bushaus Samba Member
Joined: November 18, 2007 Posts: 809 Location: Long Beach, Calif
Posted: Wed Sep 03, 2008 11:51 am Post subject: |
Once again Dave, you're answering questions that are swirling through my head.....thanks _________________ 1967 13 window walkthru bus
1965 Karmann Kabriolett beetle
hitest wrote: |
Even if completed, the abarth's gonna belch spluey all over your Eriba. |
Posted: Thu Sep 04, 2008 6:30 am Post subject: |
dstefun wrote: |
mannys66 wrote: |
thanks for the tutorial, I know where to start now. |
