lastchancevw Samba Member
Joined: August 26, 2008 Posts: 190 Location: Southeastern Mass
Posted: Tue Oct 21, 2008 9:21 pm Post subject: |
I recently worked on one of these locks- not the one in my picture, but one that was pretty corroded, and I was having problems moving the bolt of the lock, and could only get it free with a little propane torch.
It didn't seem to hurt the lock (though it burned away the penetrating oil I had squirted in there), so it might help you get that little screw out. |
Orangeena Samba Member
Joined: February 06, 2008 Posts: 133 Location: Berkshire - UK
Posted: Wed Oct 22, 2008 12:36 am Post subject: |
lastchancevw wrote: |
Thanks lastchancevw. I will give that a go.
Incidentaly this screw is on the bottom of a UK spec bus. They must have re-used the same handle for right and left hand doors. This may explain the corrosion on mine as any water that got in would hang in a drip at the bottom of the lock and corrode around the vital screw.
Cheers
Max _________________ 1973 Bay in L20B
- Originaly a panel van
- Partial Westy Interior
- Viking Spacemaker roof
- Slider of a donor bus
- Doors imported from Australia
- 22nd Owner ! |
Posted: Wed Oct 22, 2008 10:27 am Post subject: |
Eureka Lastchancevw! You cracked it. Heat is the solution!
My first attempt just looked like I was going to trash the screw, but a few taps on the screwdriver with a small hammer defined the slot a little better.
Then by heating the area around the itty-bitty screw to 'too-hot-to-touch' and then using the watchmakers screwdriver held in a vice-grip to give leverage, whilst leaning my (not insubstantial) weight on the end, I finaly managed to get the blasted thing to turn about a quarter of a turn.
This gave me hope, so I added a spash of WD40 (no naked flames at this point!) and persevered....and it worked. Out she came
I can now follow the tutorial on rekeying the lock.
Many thanks
- 22nd Owner ! |
Posted: Wed Oct 22, 2008 2:25 pm Post subject: |
Well I may have spoken too soon.
Sure enough the screw is out.
But still nothing budged. So I looked at the pics you folk have put up here to help me and 'persuaded' the deadlock to come out by tapping it back and forth whilst drowning it in WD40 and heating it up again, and eventually it shifted and came out, but with a worrying small bit of extra metal embeded in its jaws.
The barrel still refuses to budge.
I suspect the bit of metal is a key component here and I have screwed the whole lock.
Any thoughts?
- 22nd Owner ! |
Posted: Wed Oct 22, 2008 5:39 pm Post subject: |
Orangeena wrote: |
Any thoughts?
Max |
Ah.. UK.. that explains why the right side- up/wrong side down is backwards..
Hmm.. take some pictures and let's see if we how badly off you are.. If you get to the point that the lock or the handle is screwed, I might have some orphan sliding door handles with locks that you can use instead.
If you're trying to move the bolt part (the part that the barrel itself pushes, you probably can't move it at all unless the barrel comes out (which I take it didn't move)
If you had some metal bits come out- and they weren't part of the bolt, then it was probably the cog (?) on the end of the barrel, which is off center a bit and moves the bolt when you turn the lock (when the right key is in it).. If you broke that off, you;ll probably need another sliding door lock barrel, and I don't think they're the same as a door lock or rear door latch lock.
Yeah.. I probably should have warned you that you can't really budge the deadbolt without taking the barrel out at least 1/4 of an inch.
I'm not an locksmith, I only sort know this because I cannibalized some locks and figured out how to swap out the wafers.. At this moment I dare not do anything with an ignition lock (I can't even figure out how to get them out!) |
Posted: Thu Oct 23, 2008 1:36 am Post subject: |
Lastchancevw thanks for the kind offer of the handles, but I suspect shipping might be complex.
I did not know about that cog, although it makes perfect sense. However there was no way that deadbolt was going to slide anywhere, it was SOLID. I used a drift and it came out reasonably easily, presumably with that cog held in its jaws. You can see what may be the cog in the photo's, it is the lighter round bit.
Listen, I am not worried about any damage that I may have caused. I couldn't use this lock before as I have no key for it. I now know that even if I had had a key made there is NO WAY that deadlock would have slid anywhere in a hurry (so that saved me some time & money). I needed to get the barrel out to get a new one in there so I had to go through this process. If it means I need a whole new handle then sobeit. The chrome is a bit pitted anyhow. I have learnt loads about doing the job along the way, so no harm there.
I would still like to get the barrel out, just so I know how it works. Any further suggestions as to where I should push/pull to get it out?
Cheers
- 22nd Owner ! |
Posted: Thu Oct 23, 2008 1:56 am Post subject: |
I'd say at this point, reach for your propane torch, and heat up the handle where the barrel goes in.. this might expand the outer part and break the bond between the tumbler and the handle barrel
the only way I'd think you could get it out is to screw a fairly large screw into the lock slot and try to yank it out that way. You'll do a number on the tumbler, but since the cog is broken, it won't matter.
If it comes out, you might be able to salvage some of the wafers, but I don't think it can be used if the cog is busted off.
As long as the bolt moves freely enough and the chrome you see is still ok, you can probably use the handle just fine with another tumbler, as long as it turns and does what it's supposed to. I'd day sand the heck out of th corroded parts and maybe get some silver paint on it, just to make it move pretty freely.. though I'm not sure if there are any anti- corrosion measures you can take on that sort of metal.
What kind of metal is the handle made out of anyway? Is it some sort of aluminum alloy? |
Posted: Thu Oct 23, 2008 2:29 am Post subject: |
OK I will get the torch out again tonight and go for it.
Watch this space.
Cheers
- 22nd Owner ! |
Lucas Grams Samba Member
Joined: July 19, 2005 Posts: 399 Location: watsonville
Posted: Tue Nov 11, 2008 8:09 pm Post subject: |
the search function is my friend! Does any one have a 71-79 front door cylinder up for grabs? |
kevin11 Samba Member
Joined: March 12, 2004 Posts: 828 Location: Arlington,Texas
radicalthrasher Samba Member
Posted: Mon Jan 12, 2009 8:35 pm Post subject: |
RAD! i'm going to try to make all my locks work on the same key. i just bought a 1971 bay and i have 4 keys the ignition will go off anykey (want to fix), the front passenger, driver, sliding and engine bay doors have no working key. right now i have the locked from the inside the driver and passenger doors and rolled down the passenger window slightly and have locked it go the sliding door with a bike u-lock. ...hah.. anyway thanks for the tutorial, i will post results. |
Blaize Samba Member
Joined: November 01, 2005 Posts: 188 Location: Winchester U.K.
Posted: Tue Jan 13, 2009 11:15 am Post subject: |
Seems I should add what I know here. VW used the same basic tumbler right up to the last of the cabrios. there are only 4 different wafer profiles and as those last few cabrios are still in the dealerships for service VW will still sell you a tumbler wafer kit (I think, last time I got a set was around 2003). the kit they sell has 5 small ziplock bags. One of each type wafer and one of just the little springs. You get in the region of 25-30 of each so once you buy this you and everyone you will ever meet will be set for re keying vw bus locks. I am a dealer tech and I am still using the set I bought in 03 and I have PLENTY left.
I dont know for sure how much it is but well under $20 when I got mine. and it means you can replace the wafers with the right size rather that remove the ill fitting ones. It is trial and error to find the right combo but as long as you keep it in 4 little piles it doesnt take that long (as you can imagine).
Nothing wrong of course with the op's method, I think we can all agree that the door lock tumbler is only going to stop the most casual theif and even then only having one wafer in there instead of 6 will be the same really from a functional standpoint. But for those of you that still think of paying a locksmith to do it "right", now you know you can too. _________________ there is a very fine line between "patina" and rusty. |
c4l3b Samba Member
Joined: August 15, 2007 Posts: 467 Location: Springfield Missouri
chrisradioman Samba Member
Joined: September 20, 2007 Posts: 4873 Location: Swansea (Sunny Penllergaer) Wales UK
Snoop Bob Samba Member
Posted: Sat May 16, 2009 10:16 am Post subject: |
jtauxe wrote: |
I just recently completed a lock and mechanism overhaul, and have some suggestions to add. First off, I did the mechanisms, and I had a locksmith do the locks (all four) for about $100. I would have tried it myself if I had seen your post! But anyway...
The local locksmith frowned upon the use of graphite, and shuddered at the idea of grease for a lock lubricant. He said that grease would get gummed up with dirt and crud over time, and that graphite would do the same. He swore by teflon, and I must say it has worked beautifully.
There is a teflon-in-a-spray can for getting into hard-to-reach places. It has some liquid vehicle that evaporates, leaving a nice coating of teflon over everything. This I found at the local hardware store.
Another thing he turned me on to (and which I found on eBay) is powdered teflon. I now have a small bottle of it, which will be good for several lifetimes! This stuff you use like you would graphite, but it is much cleaner and more slippery.
So, my suggestion is simply to pass on the locksmith's advice: Use Teflon for a lock lubricant!
And, man, is it nice to have four matching locks that work smoothly! |
I have a friend whose father is/was a locksmith. His advice was the same as far as not using grease or graphite. We are in FL and the humidity and crap just gums up the locks. He knows what he is talking about, and I follow his advice. Teflon sounds good to me. |
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 556 Location: Anaheim, CA
Posted: Sun May 17, 2009 9:32 pm Post subject: |
Thanks for all the info. I just re-keyed the ignition to match the doors, and now have one key for everything. (I have already fitted an engine lid lock and re-keyed this). This was on the 'to do' list, but was hastened when I lost the ignition key. From the slide-show it is an easy job with the key, but a bit of a git without. I took it to a local locksmith who was able to sort it for a reasonable sum. They had tried before to remove the lock barrel without a key, but decided it was much quicker/easier/cheaper to make a key to pull the lock barrel out.
I will be getting several spares cut on genuine blanks at the next show the guy shows up at.
Al _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
damage565 Samba Member
Joined: November 29, 2008 Posts: 47 Location: Atlanta, GA
Posted: Mon May 18, 2009 4:49 am Post subject: |
How can I get the lock cylinder out of my front door handles without a key. I only have the ignition key, and no door keys. Do I have to by new handles? |
1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2452 Location: Acton, Ontario, Canada
Posted: Mon May 18, 2009 5:27 am Post subject: |
damage565 wrote: |
It comes out without a key. Just remove the handles and there is a screw that releases the the spring and arm from the tumbler. Be care when you pull the cylinder out because the wafers are spring loaded. _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
Posted: Sun May 24, 2009 11:27 pm Post subject: |
I have a treasure chest lock, which is locked, and I don't have a key. Any advice would be appreciated. |
Posted: Sun May 24, 2009 11:39 pm Post subject: |
As I search more... I find more... |
