Autocrossing the 58 rag
Page: Previous  1, 2, 3 ... 31, 32, 33 ... 41, 42, 43  Next
OTO X58
OTO X58 is offline
PostPosted: Tue Feb 05, 2013 8:14 am    Post subject: Reply with quote
Henrip wrote:
OTO X58 wrote:
Henrip wrote:
OTO X58 wrote:
Henrip wrote:
Where I can find this part to get the negative camber? :oops:
Thanks in advance!
I don't believe they're available anywhere. You would have to cut and weld a set of trailing arms. And I wish I could provide more information such as measurements, but I did not personally build them.
If you don't need as much camber, you can get the extra eccentric adjusters, and that should get you about one degree. Of you could also dimple a set of bottom torsion springs further to the outside, so that the lower arms stick out of the beam a bit at the bottom.
I usually buy in cip1 and cb, but I can not find the extra eccentric adjusters there.
Thanks for your replay Oto
Here they are:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D131%2D498%2D319%2DKIT
http://www.machine7.com/product.php?xProd=794
I just want to mention that these are only for a ball joint beam, not an early link pin beam. Link pin is a little harder to get camber out of.
I was thinking they are oversize... Thanks for the help!
Be careful! Sorry, I edited my earlier post, because I don't think the CIP listing is the EXTRA eccentric adjuster. I think it's just the OEM style. Aircooled.net does have them, along with many others. I believe both Bugpack and Empi have them available.
-Thomas
RIP HBB 10.10.84 - 12.25.09
Autocross 1958 Rag Build - Subaru Swap!
1957 Gazelle Beige Ghia find
Fowl3r
Fowl3r is offline
PostPosted: Tue Feb 05, 2013 2:01 pm    Post subject: Reply with quote
This bug is awesome!
JWP80
JWP80 is offline
PostPosted: Tue Feb 05, 2013 2:33 pm    Post subject: Reply with quote
OTO X58 is right. Many suppliers sell the stock style adjusters.
I have the offset version which came from my local bug shop, they were made by Bugpack
Here is the "offset" eccentric
Here is an oe version. notice the hole is not as close to the edge. Be sure to check this on the tapered end, not the next end.
gostros
Mr. Obvious
gostros is offline
PostPosted: Wed Feb 06, 2013 12:42 am    Post subject: Reply with quote
Great update Thomas. Glad to hear you're recovering well.
MarshallGTi
MarshallGTi is offline
PostPosted: Thu Feb 07, 2013 2:13 am    Post subject: Reply with quote
this is a really cool little toy Very Happy
It is an ingenius solution to a problem that should have never existed in the 1st place...
I like my ride quality, it makes my girls titties bounce...
My Bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=542130&highlight=
My mk2 16v http://www.vwclub.co.za/phpbb3/viewtopic.php?f=11&t=126669&p=1298235#p1298235
Mike Fisher
Mike Fisher is offline
PostPosted: Thu Feb 07, 2013 12:07 pm    Post subject: Reply with quote
Bring it North for a http://eescc.org/EESCC2013Schedule.cfm hill climb or autocross some day. Cool
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
OTO X58
OTO X58 is offline
PostPosted: Mon Feb 25, 2013 12:59 pm    Post subject: Reply with quote
Replacement engine is installed:
I hope it runs! hahaha
I found this one on Craigslist here in town, for $100.... so it's more than iffy.
I'll post more progress this weekend, hopefully with some progress on the turbo header built and the Accusump mounted.
-Thomas
OTO X58
OTO X58 is offline
PostPosted: Mon Mar 04, 2013 4:31 pm    Post subject: Reply with quote
Tons of update pictures from this weekend!
Jeff built a turbo header for my bug this weekend. By the end of next weekend, the exhaust and charge pipe will be done.
Up on the lift at 40thirteen, getting some real work done!
First step, make some flanges for the heads, and for the turbo inlet:
-Thomas
vaughn bros.
vaughn bros. is offline
PostPosted: Mon Mar 04, 2013 4:32 pm    Post subject: Reply with quote
Man this such a F'n wild ass car. I love lookin back at this thread.
OTO X58
OTO X58 is offline
PostPosted: Mon Mar 04, 2013 4:41 pm    Post subject: Reply with quote
Next, he positioned the turbo, using about a thousand zipties. We wanted to put it approximately where it was going to hang, so that we could plan out where everything will have to go (exhaust, charge pipe, oil lines, etc..)
Unfortunately, I did end up trimming the H apron a bit. I didn't really want to do this, but since the apron is really hammered from some past accidents, and since it won't be visible from the top side, I didn't mind.
I wanted to end up with the 3" tip sticking out of one of the exhaust cutouts. And it just turns out that the other cutout will show the wastegate rod on the turbo. That wasn't really the plan from the beginning, but now that it's done I love it! haha
-Thomas
OTO X58
OTO X58 is offline
PostPosted: Mon Mar 04, 2013 4:49 pm    Post subject: Reply with quote
OK, here's the good part!!
(back filling the tubing with welding gas, to get a cleaner and stronger weld! that clear hose was coming from the bottle, the tape and foil were used to seal the tubing)
As it will sit this week, waiting for the turbo installation to be done this coming weekend:
And I just love this picture so much, that I am going to go back with my good camera to get a better high-resolution shot:
-Thomas
thatdirtykid
thatdirtykid is offline
PostPosted: Mon Mar 04, 2013 4:57 pm    Post subject: Reply with quote
This thread is awesome. Every time I check back I am surprised by the turn the beetle has taken. Well done
chickengeorge
chickengeorge is offline
PostPosted: Mon Mar 04, 2013 7:35 pm    Post subject: Reply with quote
Nice work!
gostros
Mr. Obvious
gostros is offline
PostPosted: Mon Mar 04, 2013 7:46 pm    Post subject: Reply with quote
chickengeorge wrote:
Nice work!
hell yeah, nice work!
Jon65
Jon65 is offline
PostPosted: Mon Mar 04, 2013 7:49 pm    Post subject: Reply with quote
That's an insane job. Great work.
OTO X58
OTO X58 is offline
PostPosted: Mon Mar 04, 2013 8:54 pm    Post subject: Reply with quote
Nice work!
Nice work!
Thanks everyone!!! I am genuinely glad you're enjoying the thread. Even with the budget restrictions keeping me from doing everything I want to do, I'm definitely enjoying building the car. The positive comments really help, especially when things break or go wrong and I get a little discouraged.
Jeff does amazing work. He's built so many amazing things that they just sort of effortlessly roll off his hands now. If you ever get a chance to have him work on your car, I encourage you to hang out and watch him work. I'll keep taking too many pictures, to help share that experience.
-Thomas
OTO X58
OTO X58 is offline
PostPosted: Thu Mar 07, 2013 9:10 am    Post subject: Reply with quote
The exhaust is almost done!
Check this out, Jeff makes his own V-Band exhaust clamp o-rings, out of aluminum welding rod:
He basically just twists the rod around a pipe of the same diameter, cuts it to length, then welds the ends to make a ring. This saves a ton of cash over buying fancypants v-band clamps and gaskets. All of this stainless, including the clamps, is bought from a local Stainless Distributor that sells mostly to the food and dairy industry. The guys at the distributor always look at us a little funny when we drive up in loud turbo cars instead of beat up work trucks. LOL
This coming weekend, we should have it up and running. Jeff still needs to make the charge pipe going up to the throttle body, and the intake pipe going to the air filter. I need to figure out where that Accusump is going to be mounted, and get all the proper fittings and oil lines.
-Thomas
Corinthiano
Corinthiano is offline
PostPosted: Thu Mar 07, 2013 10:51 am    Post subject: Reply with quote
It's beautiful. You guys are dangerous.
[email protected]
vwlownslo69@hotmail.com is offline
PostPosted: Thu Mar 07, 2013 2:11 pm    Post subject: Reply with quote
x2
OTO X58
OTO X58 is offline
PostPosted: Sun Mar 10, 2013 3:17 pm    Post subject: Reply with quote
Done and running! It smelled great, with a fresh tank of E85. Unfortunately, one of my used STI injectors is faulty, so I need to find another set before I can drive it and street tune it. But at least I got to hear it come to life!
Because the turbo is so close to the plastic, I added an aluminum heat shield to the timing belt cover. The apron might burn a little too, but I'm OK with that right now. It'll just add to the fauxtina!
It's kind of hard to see in the picture, but there is an exhaust hanger at the back of the muffler. It is set up so that once the V-band clamp is taken off, the hanger rod can slide out of the mount, so that the exhaust is really easy to take off with no nuts and bolts!
The added ground clearance will be awesome. I didn't put the exhaust tip through the apron cutout as I had originally planned, because of the air cleaner placement.
-Thomas
Page 32 of 43
