Kosmo Samba Member
Posted: Thu Aug 14, 2008 11:22 am Post subject: Wipers Where to buy? What size? |
All,
I need new Wipers or refills for them. Can I get them at local FLAPS?
The seem really small and dainty compared to todays cars.
What do you recommened before I end up scratching my windshield. |
GregKnod Samba Member
Joined: April 11, 2005 Posts: 376 Location: San Jose, CA
Posted: Thu Aug 14, 2008 12:00 pm Post subject: |
Almost any auto parts store has those little electronic look-up machines that allow you to find wiper blades for for VDUB. _________________ '73 Westy Weekender sharing the garage with a '66 Ocean Blue Beetle (daily drivers are out in the weather) |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4520 Location: Oklahoma City, OK
Posted: Thu Aug 14, 2008 2:09 pm Post subject: |
Original size was 16" |
visibleink Samba Member
Joined: May 03, 2002 Posts: 1668 Location: Austin, Texas
Posted: Thu Aug 14, 2008 2:33 pm Post subject: |
busman78 wrote: |
Yep, find replacments at any auto parts store.
Anyone try a bigger size? _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
<-- Helga, she slammed her dub in '53 and adjusted valves with her teeth |
pb24ss Samba Member
Joined: June 30, 2005 Posts: 1665 Location: sitting around the fire with the bluegrass band - colorado
Posted: Thu Aug 14, 2008 2:50 pm Post subject: |
visibleink wrote: |
Anyone try a bigger size? |
Nope. The passenger side on already hangs off the windshield where it's curved at the bottom. Longer blades would look kinda silly I think. |
kinsey Samba Member
Joined: March 08, 2007 Posts: 101 Location: victoria, canada - henderson, nevada
Posted: Thu Aug 14, 2008 3:10 pm Post subject: |
I noticed that with the passenger side too.
The wiper doesn't hit the glass all the way.
Has anyone tried using a smaller wiper on that side???
Kinsey _________________ IT'S NOTHING THAT A FEW DAYS
IN "THE KEYS" WOULDN'T FIX
Islamorada Blue- '78 bay window
"The Spirit of Margaritaville" |
Posted: Thu Aug 14, 2008 3:13 pm Post subject: |
I only advised as to the original size, I use 15" for both sides, never did like the overhang. |
pb24ss Samba Member
Posted: Thu Aug 14, 2008 3:19 pm Post subject: |
shorter wipers will leave larger areas of the windshield untouched. vw used the size they did for a reason.
Posted: Thu Aug 14, 2008 3:53 pm Post subject: |
Yea, you will lose a 1/2" top and bottom. Personally I found no ill effect in changing the length, I also feel I get a better wipe. |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Thu Aug 14, 2008 4:24 pm Post subject: |
kinsey wrote: |
Kinsey |
Normal. |
Djembejim Samba Member
Joined: April 20, 2008 Posts: 282 Location: Memphis, TN
Posted: Thu Aug 14, 2008 8:07 pm Post subject: |
You can get new wipers at target _________________ 1973 Bay Window - Maggie the Magical Mystery Bus
"If you find yourself lost in the woods--F it--Build a house. You will improve your predicament significantly." |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Thu Aug 14, 2008 8:44 pm Post subject: |
I have found that the rear wiper blade from the 1st series of Mercedes ML suv works perfect. MB part number 163 820 05 45
Part number P7030-276063 here: http://www.importeccatalog.com/
Nice thing about them: they last a long time and they do not scratch the glass when the rubber lip falls off..... like cheapo Trico and Anco do. |
1977_L63H_P27 Samba Member
Joined: January 17, 2006 Posts: 2345 Location: Bristol, Tennessee
Posted: Fri Aug 15, 2008 4:59 am Post subject: |
Also if you buy the, ugh, Target or other bargain basement type blades they're usually made of plastic. They don't bend as well as the original steel, nor do they hold the correct tension on the glass (i.e. a bad wipe). I ordered the Anco steel blades from O'Reilly Auto Parts. The part number was 91-16. Nice blades . Peace! _________________
busdaddy wrote: |
...and try a few chubby ones until you find one you like.
1977 Westfalia P27
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Fri Aug 15, 2008 5:13 am Post subject: |
I always wash my bus with the sunroof open!!!
I just went to my local FLAPS (Advanced Auto) asked them, they looked it up, found some in stock and I've been good since!! _________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
russwiththebus Samba Member
Joined: September 25, 2007 Posts: 930 Location: Chattanooga, TN
Posted: Fri Aug 15, 2008 5:17 am Post subject: |
I usually buy Bosch 16" wipers and they work great. The last pair I got were actually designed for rear windows, didn't notice until I had put them on and looked at the package. But I don't see what the difference is. |
locoqueso Samba Member
Joined: September 16, 2006 Posts: 57 Location: Lost somewhere in Illinois
Posted: Fri Aug 15, 2008 6:35 pm Post subject: |
kinsey wrote: |
Has anyone tried using a smaller wiper on that side??? |
Mine came with 15" and they popped loose every so often when used. They seemed to be just short enough to slip off. No problems with that after swtiching to 16". _________________ 1978 Westfalia Campmobile (P-21) VW T2 2.0L F.I. |
greenbus pilot Samba Member
Joined: March 14, 2008 Posts: 1285 Location: Wisconsin: Rustbelt, USA baby!!
Posted: Fri Aug 15, 2008 11:56 pm Post subject: |
I like Bosch Micro Edge, in the 16" flavor, but where do you buy refills?
Not ONE FLAP , nor Wally World, sells refills any more. They gladly sell you a Bosch Icon for $14.95, but, hey, no refills- buy another one next time! You could get refills all over town, but not anymore. I found refills online, but really, who wants to pay double, with shipping?
BTW-
Hey look, mister. We serve hard drinks in here for men who want to get drunk fast, and we don't need any characters around to give the joint "atmosphere".
LOL- I love that episode!! _________________ Sent from a white van down the street. |
Desertbusman Samba Member
Posted: Sat Aug 16, 2008 12:21 am Post subject: |
greenbus pilot wrote: |
Not ONE FLAP |
Ran into the same problem a few months ago. Couldn't believe it. The only part that ever needs replacing is the rubber refill. No need to buy the whole darn thing. It's so dry here that frequently the blades will never see a rain drop in their life time. However they might dry rot in just a few months. A lot of time, between the bug and the bus, I take them off and keep them stored inside so they last longer. The length of the refill doesn't matter just so that it is as long or longer than we need. Easily cuts with scissors. For my bug I had always bought ones double the length and then cut them in half.
Anyone know of where and how to get refills? Paying $15 dolars for the un-necessary blade is throwing money to the wind when only a $2 refill is needed. Is it just some dumb marketing ploy for the manufactures and distributors to force us to help line their pockets? Maybe in the future when we go to buy a tire they might only sell them mounted on a new wheel with a new hubcap. _________________ 71 Superbug
71 Westy |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Sat Aug 16, 2008 8:16 am Post subject: Wipers Where to buy? What size? |
I use 16 inch, Swedish made, SWW wash/wiper blades, with hollow blade rubbers, fed by a flexible rubber hose, which evenly distributes the windscreen-washer water over the glass.
These can be purchased by mail-order, direct from SW Washwiper AB, in Stocksund, Sweden.
http://hem.passagen.se/zelus
Try the following link, for yet more 1968~79 VW Type 2, front & rear, window wiper & washer upgrades:
http://www.thesamba.com/vw/forum/viewtopic.php?t=186468&highlight=washwiper+blades _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
