carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Fri Aug 15, 2008 10:49 am Post subject: Runs so cool in the 100+ Heat? Dog house cooling? |
2nd 1974 Thing, Rolf. Just had all fuel lines replaced-tank is clean and no sediment, tuned up, valve job, Brakes, Belts, Battery, New tires, exhaust.....all of the necessities. I fill the tank every other time with Supreme. Runs great cold, but, if I shut it down prior to 20-30 minutes of Freeway or around town running, Rolf just does not like to start back up with ease.
I had the same issue with my previous, less mechanically perfect 1974 Thing (11 years ago) and it seems to me that someone advised that the Doghouse Cooling on 1974's especially, makes them run cold blooded even in really hot weather. My question is, Does anyone else have this issue? Rolf runs sweet in cooler weather. Oil types make a difference and what are you all running for oil in the summer and winter. I am in Portland Oregon.
Last night I stopped off for various sundries after work after driving only 2 miles and it took awhile to get it started again. Seems almost like it was flooded. Finally starts but runs rough upon startup. That is after fielding 6 peoples questions and talking about what a cool and rare car the Thing is. kinda embarrasing.
Common issue? Any recommendations or workarounds?
Thanks in advance for your comebacks!
Jeffrey
Carterzest _________________ Happiness=Portland, Oregon in the rearview mirror!
spam38 Samba Member
Posted: Fri Aug 15, 2008 11:14 am Post subject: hard starting |
its possible that the fuel in the carb is boiling and flooding the car ihave the same problem and i just hold it to the floor when it happens the grade of gasoline now days boils more quickly the in the days of leaded gas you can also try opening the engine hatch and see if that helps out and then you can be sure its boiling fuel |
Posted: Fri Aug 15, 2008 11:23 am Post subject: Re: hard starting |
spam38 wrote: |
Funny, it does seem that it starts easier when you hold the pedal to the floor, which, for me, is counterintuitive as I have always just pushed the pedal down 1/2 way to set the choke when cold and then let the car idle high until it warms down. Do not think I ran it long enough to have the fuel boiling? How would you check to see if the fuel was boiling....
thanks for the input... _________________ Happiness=Portland, Oregon in the rearview mirror! |
thinghunter Samba Member
Joined: May 18, 2004 Posts: 403 Location: North Texas
Posted: Fri Aug 15, 2008 11:27 am Post subject: |
On all my stock VWs it seems like it depends on engine temp how I need to start the engine(seems like I got most of this out of an old owners manual). If cold(first start of the day) push gas pedal to floor and release then turn key(seems to work everytime). If recently shut off and still hot(like prob within 30 mins) don't touch gas pedal just turn key. If still warm but has been sitting a while(this is when it seems like it has the most trouble starting) I have to turn the key while slowly depressing gas pedal. I think in the later case the warmer the engine is the harder it is to start and you should probably try the second method first. |
Posted: Fri Aug 15, 2008 11:39 am Post subject: |
thinghunter wrote: |
Good stuff. Thanks for your input! _________________ Happiness=Portland, Oregon in the rearview mirror! |
alg Samba Member
Joined: April 24, 2006 Posts: 134 Location: Webberville, TX
Posted: Fri Aug 15, 2008 2:27 pm Post subject: |
If you read the VW 'users guide' for the U.S. 73 and 74 Thing, it clearly states that when the engine is warm you need to put the pedal almost to the floor and hold it there while starting.
My Thing is completely stock and I do this everytime I start it warm.
(I live in Central Texas where it is 100f for months on end)
Again, the procedure is for a stock Thing. If you have a different/bad carb or ignition, or you have a leak in the throttle shafts then this may not work.
alg |
Posted: Fri Aug 15, 2008 5:29 pm Post subject: |
alg wrote: |
alg |
Thanks...I have downloaded an owners manual recently but since I have owned and operated so many ACVW's, I got complacent and didnt think of looking at that. Makes sense - Warm= pedal to the floor....seems that is the only way you can get it to start, it is tight and fresh so I just wanted to consult the Sambanista's to be reassured! I hate flooding my car's!
Thanks for the reply! _________________ Happiness=Portland, Oregon in the rearview mirror! |
Eric Goodman Samba Member
Joined: August 04, 2008 Posts: 269 Location: California
Posted: Fri Aug 15, 2008 5:47 pm Post subject: Cold/Warm start |
I have the exact problem with my 1973 thing. Runs great all day and when it is hot (So Cal 100+ now) after driving all day the car will not start. I just looked in the manual as suggested and will try this next time. Will post more info or would like to know if this works for you... |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Sat Aug 16, 2008 9:18 am Post subject: |
Here's another tip... I've seen lots of mis-adjusted chokes over the years. Typically adjusted too "tight". As such the choke it too far closed too early on a still hot engine. The choke should be mostly open after a half an hour in 100 degree heat. This can be seen on the left side of the carb, the arm on the choke cam directly relates to the choke plate angle. The choke can be adjusted by rotating the choke heater can, after loosening the three small screws on the right side. Rotate the top of the can towards the rear to loosen the choke.
I do this twice a year, once in the winter (tighten the choke) and again in the summer (loosen). _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
Posted: Sat Aug 16, 2008 11:20 am Post subject: |
uberautowerks wrote: |
I do this twice a year, once in the winter (tighten the choke) and again in the summer (loosen). |
Thanks so much. That totally makes sense. Gonna drive it to work tonight and run it around for a bit before and I will try that tip out.
I remember someone telling me that the 74's were over designed in the cooling department due to the earmuffs(Thanks to Ralph Nader!) and the doghouse cooling...I also seem to remember that when the engine is totally warm and the mechanism on the doghouse cooling is all the way open, the car can cool down too quickly, thus, the choke adjust tip.....
Wish I understood the mechanics of the doghouse cooling system a bit more so I could not sound so non-mechanical/non-technical! Oh yeah, thats why I am asking questions here.
Thanks so much again! _________________ Happiness=Portland, Oregon in the rearview mirror! |
Posted: Sat Aug 16, 2008 3:27 pm Post subject: |
What I've been told is the ear muffs are to keep exhaust fumes out of the fresh air heater system. This makes since since the 73 Things didn't have the muffs or a fresh air heater. What also sells me on this is the vents are in the top of the muffs, if it was for better cooling I would think they would be on the front to force more air in. Also, my 73 doesn't have any problem with overheating in the 100+ weather so I would wonder what would make them think they needed better cooling. |
Posted: Sun Aug 17, 2008 7:01 pm Post subject: |
Just noticed when looking at the carb adjustment this afternoon that my rear deck lid seal is nowhere to be found! That could be a big part of the problem too HUH?
Where to purchase.....TTS? any suggestions appreciated. That also explains the annoying intermittent rattle I get when I drive with the top up and doors on........Good to have found that! The rear deck lid is solid but rattles a bit and I am certain that the full rectangular seal fitted in place will alleviate that issue.
Jeffrey _________________ Happiness=Portland, Oregon in the rearview mirror! |
Skorzeny's G Ride Samba Member
Joined: July 10, 2007 Posts: 291 Location: Gods curse on humanity...The Arizona Desert
Posted: Sun Aug 17, 2008 8:15 pm Post subject: .. |
On starting 2 pumps and the third goes to the floor. Turn the key and slowly depress the pedal until is starts. Starts every single time in 110 degrees after driving. _________________ ...70 type 181
...59 Beetle
...62 beetle baja (new) |
Posted: Sun Aug 17, 2008 9:42 pm Post subject: Re: .. |
Skorzeny's G Ride wrote: |
On starting 2 pumps and the third goes to the floor. Turn the key and slowly depress the pedal until is starts. Starts every single time in 110 degrees after driving. |
I tried it with the pedal almost all the way to the floor after it was warm and it started right up. I will also try this method as well. It is funny, in 1997 when I loaned my car to my brother, he could not get it running after it was warm and all of your tips are helping me refresh my memories on all the tricks. thanks so much. I sold my 1974 Thing in 97 and just got back into one in February 2008. So nice to be back!
Now, the rear decklid seal....is that a major issue........gotta fix it as the rattling decklid is annoying! _________________ Happiness=Portland, Oregon in the rearview mirror! |
7thing3 Samba Member
Joined: April 05, 2003 Posts: 473 Location: Cleveland, OH
Posted: Mon Aug 18, 2008 5:14 am Post subject: Rear Seal |
Until you get a seal take a tennis ball and cut a slit and put it on the latch mechanism. Not sure about the cooling effect but it should stop the annoying rattle. |
Posted: Mon Aug 18, 2008 7:58 am Post subject: |
Could the seal make that happen? I have not drove mine yet to try the starting info and see if it helps the car start when it is hot. My lid seal is fine, but I do have a few holes in the seal around the engine... I read in old post that you had to remove the engine to replace. Any fix for the holes? Thanks. |
Posted: Wed Aug 20, 2008 9:58 am Post subject: |
The missing decklid seal won't cause over heating issues. Rattles yes. Now the compartment seal, between the engine and the body, is another story. A missing compartment seal will cause overheating.
Also the stock cooling system works great, neither over cooling nor under cooling when adjusted properly AND with all it's bits in place. Your starting issues are typical of a hot engine, not a cool engine. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
stevehenderson Samba Member
Posted: Wed Aug 20, 2008 12:33 pm Post subject: |
I don't think your car will over cool unless your thermostat is broke did you check it.
"what are you all running for oil in the summer and winter."
Run Brad Racing Oil--Jake Raby recommended and it and it works great in AC motors. It has highest--1,500 ppm Zinc (Zn) and 1340-1400 ppm Phosphorus (P) content.
Contact them directly via there web site, http://www.bradpennracing.com/ ,and they will email you telling you the nearest distributor #. Then call the distributor who will give you the # of the local retailer. It is abut $4.00 a quart if you buy a case. |
Posted: Wed Aug 20, 2008 10:58 pm Post subject: |
When I got my car the old owner said he was using 30W oil all year (So Cal). I have not had it changed yet, it has only been a few months. |
Posted: Wed Aug 20, 2008 11:13 pm Post subject: |
Oil won't make much of difference in starting but he asked what we run. Allot of modern brand oil is not so good for ACVW because it no longer has stuff EPA dose not like much anymore. Brad Penn has a 10W30.
I have to floorboard my pedal and turn it over 3-5 sec ever time after it's first started. I have not been able to fix this--tried many things. It fires instantly after setting a long time. I was told to check the fuel level after running the carb--but mine seems fine. I guess I'll try a different carb one of these days. |
