myersmanxed Samba Member
Posted: Fri May 05, 2017 2:14 pm Post subject: Re: Hardware sizes |
Where can I get M10-1.5x30 bolts with a 14mm head? These are used on the rear wheel oil seal holders on my buggy. Can't seem to find these anywhere. These are KAMAX 10K.
If anyone has some for sale, please let me know. Stupidly stripped the heads on mine.
Any help is greatly appreciated. |
Bob Loblaw Samba Member
Joined: August 17, 2008 Posts: 865 Location: Vancouver Island, Canada
Posted: Fri May 05, 2017 2:44 pm Post subject: Re: Hardware sizes |
Part# 311.501.325
A quick Google shows used ones for sale at Aircooled.net and Karmannghia.com
Or I can get brand new OE VW bolts out of the classic centre in Germany. About $5 ea. _________________ sent from a phone using poor grammar and spelling |
c21darrel Samba Member
avoll Samba Member
Joined: September 04, 2014 Posts: 119 Location: Ottumwa
Posted: Sat Sep 02, 2017 2:26 am Post subject: Engine Deck lid bolt |
Anyone know what the bolt is that connects your deck lid to the bus? Its a 78 trasport bus.
Takes one bolt on the left side.
Thank you in advance. |
HITE Samba Member
Joined: October 10, 2017 Posts: 41 Location: Virginia
Posted: Thu Dec 21, 2017 4:52 am Post subject: Re: Hardware sizes |
Looking for the odd size screw that goes into the head for the air deflectors. (Underneath betweeen the push rods and head itself on 411 motor for bay window bus) Anyone know size for search? |
Victordlt43 Samba Member
Joined: February 14, 2017 Posts: 2 Location: Long Beach
Posted: Thu Feb 01, 2018 11:15 pm Post subject: Re: Hardware sizes |
Can anyone tell me what size is the front lower shock mount on a lower 64 or later trailing arm? I’m guessing 10mm but not sure of tread pitch |
tandemtwins Samba Member
Joined: December 15, 2018 Posts: 35 Location: Williston, FL
Posted: Sat Mar 16, 2019 4:41 pm Post subject: Re: Hardware sizes |
The nut and/or bolt on my 73 Beetle's distributor clamp is stripped. Is there a standard nut and bolt size for a replacement, or do I just need to buy the whole clamp assembly? |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Mar 16, 2019 6:46 pm Post subject: Re: Hardware sizes |
The bolt is captured in the clamp so it won't spin when you tighten the nut. If never tried to remove one, but I'd imagine it would be difficult to do and ruin the clamp.
Grab a new clamp. They are pretty cheap. You can get a OG one from the classified here.
The clamp just needs to be snug, not torqued down tight enough to bend the crap out of it or strip the nut. I find so many bent up and I can't figure it out. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Sat Mar 16, 2019 6:53 pm Post subject: Re: Hardware sizes |
tandemtwins wrote: |
The bolt is a M6, not sure of the length.
if you replace the clamp get a original German and not aftermarket. The aftermarket ones are soft and then tend to bend and alter the timing.
If you can't find one locally, PM me as I have a bunch of them. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Mar 20, 2019 5:44 pm Post subject: Re: Hardware sizes |
Does the screw that holds the points in a 009 distributor have a name, or size designation, to where I might find a replacement in a local hardware store? (The groove on the head of the screw is starting to round... and I'd like to replace the screw with a new one before trouble strikes!) |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Thu Oct 31, 2019 7:34 pm Post subject: Re: Hardware sizes |
I've never been to this part of the forum but hopefully this info helps.
This applies to a 77 type IV engine but it could cover other type IV model years.
Sizes are either exact or the closest sizes currently available new. Most hardware can/was purchased from boltdepot, belmetric, and fastenal.
Nuts and bolts
Clutch pressure plate
- 8mmx18.5mm 1.25 @6 hex tap
Engine mount
- 8mmx20mm 1.25 @4 serrated flange (fastenal #11115901)
Plenum-case mount
- 8mmx83?mm 1.25 @2 hex tap
EGR
- 6mmx10mm 1.0 @2 pan head
EGR valve
- 6mmx16mm 1.0 @2 hex tap
EGR valve to plenum
- 6mmx55mm 1.0 @2 Allen head cap
Throttle body
- 6mmx25mm 1.0 @2 pan head
EGR/exhaust
- 8mmx30mm 1.25 @2 hex tap
Heat exchanger left
- 6mmx14mm 1.0 @1 serrated flange (fastenal # 11115895-16mm # 111115894-12mm)
Booster fan
- 6mmx15mm 1.0 @2 hex tap
Fan guard
Alternator bracket
- 8mmx18mm 1.25 @2 hex tap
Fan housing
- 6mmx20mm 1.25 @8 pan Phillips
- 8mmx16mm 1.25 @1 hex tap
- 8mmx45mm 1.25 @2 hex tap
- 8mmx45mm 1.25 @1 hex
- 8mmx30mm 1.25 @3 hex tap
Starter bolt
- 10mmx70mm 1.5 @1 hex
Exhaust EGR side
- 8mmx20mm 1.25 @1 hex
Engine carrier bolts
- 8mmx65mm 1.25 @4 hex
Bumper
- 10mmx25mm 1.5 @4 hex tap
Fan hub
- 8mmx30mm 1.25 @1 serrated flange
Transmission (fastenal # 11115903)
- 10mmx75mm 1.5 @1 hex
Transmission mount
- 10mmx45mm 1.5 @2 hex
CV bolts
- 8mmx48mm 12 point
Cooling tin
- 6mmx12mm 1.0 @1 hex tap (fastenal # 0128747)
Cylinder cooling tin
- 5mmx12mm 1.0 @2 hex tap (fastenal # 1138543)
Oil temp plate
- 6mmx10mm 1.0 @2 hex tap (fastenal # 11113804)
Valve lifters
- 7mm nut @8 (fastenal # 0161929)
- 6mm square nut @4 (fastenal # 0161910)
Thermostat
- 8mmx10mm 1.25 @1 hex tap (fastenal # 11552374)
Engine case top
- 8mmx88mm 1.25 @1 hex
- 8mmx93mm 1.25 @1 hex
Alternator tin
- 6mmx30mm 1.0 @1 hex tap (fastenal # 0153965)
Control flaps cable holder
- 4mmx8mm @1 hex tap (fastenal # 0162373)
- 4mm square nut
Fan housing cooling flaps (non stock item and a mod to keep flaps from falling off)
- 1/8" spring e-clips x4 (fastenal # 0401249)
Stud length for cross over pipe
28.5mmx8mmx1.25 _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Mon Nov 04, 2019 6:47 am Post subject: Re: Hardware sizes |
I don't have a type IV engine, but I love bolts and thread sizes. Totally awesome!! I grew up in an old hardware store and sorted thousands of nuts, bolts and screws as the owner would have his helpers dump them in trash cans when they bought out a store. It would take me a full year to sort but a lifetime of education. Unfortunately the majority were US sizes still I loved it.
ivwshane wrote: |
Nuts and bolts
Engine mount
Plenum-case mount
EGR
EGR valve
EGR valve to plenum
Throttle body
EGR/exhaust
Heat exchanger left
Booster fan
Fan guard
Alternator bracket
Fan housing
Starter bolt
Exhaust EGR side
Bumper
Fan hub
Transmission mount
CV bolts
- 8mmx48mm 12 point
Cooling tin
Oil temp plate
Valve lifters
Thermostat
Engine case top
Alternator tin
- 4mm square nut
28.5mmx8mmx1.25 |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
papichuito Samba Member
Joined: July 28, 2009 Posts: 165 Location: Radcliff, KY 40160
Posted: Fri Nov 22, 2019 4:38 am Post subject: Re: Hardware sizes |
What about the bigger bolts and nuts? Like the flywheel, axle castle nuts, spindles, etc,,,,,,,,,,,, I cat find that anyware. _________________ Jesus Roman |
joem32380 Samba Member
Posted: Wed Jan 15, 2020 3:08 pm Post subject: Re: Hardware sizes |
58-66 beetle
pedal to tunnel bolts: M10x30 1.50 pitch |
wagohn Samba Member
Joined: June 24, 2014 Posts: 740 Location: United States
Posted: Sun Oct 04, 2020 10:09 am Post subject: Re: Hardware sizes |
Anyone know the size of the bolt that bolts the exhaust bracket to the left side of the engine, under a 76 VW Transporter?
We had a super annoying engine rattle at 1500 rpm every time we changed gear. Turns out this missing bolt allowed the bracket to vibrate against the engine.
Thanks! _________________ 1976 VW Transporter, 2.0 FI Engine |
Flat4BRM Samba Member
Joined: February 26, 2018 Posts: 22 Location: California
Posted: Sun Jan 23, 2022 5:25 pm Post subject: |
roy63 wrote: |
here is a question, what is the thread and pitch on the heater control knob on a 63 sedan? mine was damaged by my blaster. I have been unable to find much on this topic. |
I'd like to have this info as well. I've got a new control knob assembly and everything works great, but the new knurled cap nut barely goes down halfway (tried the old one and it's the same story). I'd like to chase the threads to clean everything up. This info would be greatly appreciated. _________________ - Most car projects are like stray dogs..you want to keep them all and never let any of them go.
- Built, not bought.
- Street is neat...support your local street rodders!
1966 L41 113 | 1965 L456 151 | 1963 L380 113 | 1954 L227 113 | 1949 L51 11A |
Posted: Thu Jan 27, 2022 6:18 pm Post subject: Re: Hardware sizes |
roy63 wrote: |
UPDATE:
So I found out the size of said heater control knurled nut:
M20 x 1.0
Hope this helps. _________________ - Most car projects are like stray dogs..you want to keep them all and never let any of them go.
scubasteve321 Samba Member
Posted: Sat May 28, 2022 11:03 am Post subject: Re: Hardware sizes |
Anyone know the screw size to attach the regulator to the bus body? lost mine aggghhh
Early bay 71
edit; ended up using number 8 by 1/2 inch sheet metal screws, they bit pretty good once tightened down _________________ 1971 Campmobile Tin-Top
1971 Campmobile Pop-Top
1974 VW Bus |
aa390392 Samba Member
Posted: Thu Jun 16, 2022 9:23 am Post subject: Re: Hardware sizes |
Anyone know of the size that fasten the glovebox on an Oval?
Thanks _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Scorpio101 Samba Member
Joined: December 02, 2023 Posts: 1 Location: Seattle WA
Posted: Sat Dec 02, 2023 11:39 am Post subject: Re: Hardware sizes |
Hi
I have 1981 VW Rabbit pickup which I'll convert from fuel injection to carb I I have the mainfold for weber should I buy Carburetor IDF 40 / 36/32 ? |
