Pbotsonis Samba Member
Joined: January 09, 2008 Posts: 506 Location: Parker, Colorado
Posted: Sun Aug 17, 2008 2:50 pm Post subject: Thing Glove Box Door and Bamboo Tray |
Do you have to move the map light? Drill any holes? What about for the bamboo tray under the dash? Does that mount easy? _________________ Price does not include PayPal fees. Text is the fastest way to reach me |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1681 Location: Nebraska
Posted: Sun Aug 17, 2008 10:00 pm Post subject: |
It really depends on which door you end up with. Some use the same mounting holes that the dash pad uses. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Mon Aug 18, 2008 12:19 am Post subject: |
I had a look at a Thing last month and the map light has to go to install the factory glove box door. The latch and it's receiver are right where the light is.
kubelmann Samba Member
Posted: Mon Aug 18, 2008 4:12 am Post subject: |
That is a picture of the rare factory glove box door that was produced for the hotel Things used in Mexico. From my research that part was never issued for US or European Things only the hotel models in Mexico got those so guests could secure valuables in the box. |
kuhl 181 Samba Member
Posted: Mon Aug 18, 2008 4:33 am Post subject: GloveBox Cover |
This the one the Thing Shop offers it's a little pricey but works well. It mounts in same holes as safety pad and require only 2 small holes drilled which are in back of glovebox area. Sounds like a commercial but it works great, it locks and the radio and it's wiring is in it's own compartment and you don't have to move the Map light
Bruce Samba Member
Posted: Mon Aug 18, 2008 9:31 pm Post subject: |
kubelmann wrote: |
I've seen a LOT of these doors on Mexican Safaris. Too many to have been only used on hotel cars. The locals down there told me it was 78 and later cars that got them. _________________
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Mon Aug 18, 2008 10:07 pm Post subject: |
I believe that all mexican made things had them after '75. The German military type 181 did not come with them but their civilian models did. |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Tue Aug 19, 2008 10:09 am Post subject: |
I installed the full glove box door from The Thing Shop on mine many years ago.
http://www.thethingshop.com/detail.asp?PRODUCT_ID=181GB
The Thing Shop wrote: |
Designed from an original VW glove box door and made to fit the US Delivery Things. Looks like the other panels on your dash when painted to match. Easy to install. $135 |
The edges are rolled nicely and it has an inner wall - it's got some thickness to it. It's good quality and it's stood up well for years. I had to move the map light to install it, and in order for the body to properly catch the latch, the metal where the map light mounts need to be bent in a bit (not really visible). I've yet to make this bend, and the box just sets shut. With the very visible keyhole and obviously heavy construction (steel door with piano hinge), everyone thinks it's locked and stays out of it. It hides clutter well. _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
Bruce Samba Member
Posted: Tue Aug 19, 2008 10:55 pm Post subject: |
Designed from an original VW glove box door ....... |
That is a LIE! The original VW glove box door is in the pic I posted above.
I wouldn't even call the Thing Shop's door a reproduction, it is a totally different design. _________________
sdwalter Samba Member
Posted: Wed Aug 20, 2008 7:52 am Post subject: |
Bruce wrote: |
I wouldn't even call the Thing Shop's door a reproduction, it is a totally different design. |
OK, so where can we purchase an original VW glove box door? Does someone sell these? |
Posted: Wed Aug 20, 2008 8:14 am Post subject: |
They are one of the elusive Thing parts. There was a guy in Mexico City that was selling some. Another Thing pal and I both bought one. The condition of both of them were less than perfect. |
74 Cosa Samba Member
Joined: June 06, 2006 Posts: 535 Location: The Midwest
Posted: Wed Aug 20, 2008 11:06 am Post subject: |
The aftermarket doors are nice.......if you don't paint them. I painted mine to match the vehicle and the paint chips at the hinge. Tolerance to tight at hinge point. I also had to move the light to the rear of the glove or storage box. |
surfarii Samba Member
Joined: November 26, 2006 Posts: 307 Location: Hawaii
Posted: Wed Aug 20, 2008 12:13 pm Post subject: |
I had to slot the holes on the hinge and latch to get the door to fit. I also ground down and re welded one side to shorten the width so it fit right.
I moved the map light under the dash behind the I Pod . It works great there.
I also added a rubber bumper on the top of each side of the box so it doesn't chip paint and when it does close the top does not lean in more than it should.
Overall It looks like a factory option to me but it wasn't a bolt on and I was disappointed with all of the mods I had to do for the price I paid.
Surfarii |
pjmacua Samba Member
Joined: May 22, 2003 Posts: 199 Location: Cantal, France
Posted: Wed Aug 20, 2008 12:33 pm Post subject: |
Al Capulco wrote: |
Hello
The civilian models got the glove box door during 1975 in Europe.
For this models, the map light is replaced by a square flat light from the VW Golf (Rabbit), located on the dashboard.
Pierre-J M. |
Nikkoleto Samba Member
Posted: Sat Oct 03, 2009 5:35 pm Post subject: Original Glove Box |
I have the same glove box setup minus the lock (which I need) as Bruce has. Can anyone tell me what other parts I need to install it in my 73? |
Bruce Samba Member
Posted: Sun Oct 04, 2009 3:34 pm Post subject: |
The lock and striker can be found in any 74-79 Super Beetle. _________________
Posted: Sun Oct 04, 2009 3:46 pm Post subject: Bruce |
thanks |
SilverThing Samba Member
Posted: Sun Oct 11, 2009 12:18 pm Post subject: |
pjmacua wrote: |
Al Capulco wrote: |
Hello
Pierre-J M. |
The factory glove box door is listed as being introduced on chassis 185 2009 284 _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Tue Oct 13, 2009 12:48 am Post subject: |
i have the bamboo parcel tray...cant believe it just sortta hangs there! have the front speaker panels to support the edges. its loaded with odd clutter and hold on the dirt roads nicely! get the speaker panels (sans speakers) from the thing shop, and get the tray from another source for much less money! my two cents! |
Smog Samba Member
