ebrekhus Samba Member
Posted: Sat Jun 19, 2021 6:52 am Post subject: Bolt size for rear wheel bearing cover |
Anyone know the size of the bolts for the rear wheel bearing cover on a 63 bug? I’m replacing seals and it has mismatched bolts and I want to replace with correct bolts. Thanks |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sat Jun 19, 2021 7:41 am Post subject: Re: Bolt size for rear wheel bearing cover |
99.997% sure they are 10mm x 1.50 pitch. The issue is the factory VW ones have a small 14mm hex to allow tool clearance to tighten them. You can either search out og ones in the classifieds, or use socket Allen headed bolts. Most 10mm bolts you’re going to find at a common hardware store are going to have a 17mm hex you won’t be able to get a socket on. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Sat Jun 19, 2021 7:56 am Post subject: Re: Bolt size for rear wheel bearing cover |
Great idea. Ace Hardware.
I've used such for upper left engine mount on later engine cases. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Ovally Samba Member
Posted: Sat Jun 19, 2021 9:29 pm Post subject: Re: Bolt size for rear wheel bearing cover |
Thanks! Exactly what I was looking for. |
Posted: Sun Jun 20, 2021 6:49 am Post subject: Re: Bolt size for rear wheel bearing cover |
ebrekhus wrote: |
I personally have never gotten a bad product from WW, but I would be curious to see what size the hex is on those bolts. It looks like they are at least 15mm, which is going to leave little room for a socket. |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sun Jun 20, 2021 7:47 am Post subject: Re: Bolt size for rear wheel bearing cover |
I used those rear bearing bolts from WW on my '62 and they worked perfectly. The head of the bolt used a 15mm to tighten.I think I used a thin wall socket on it. It was at least a year or so ago. |
Ovally Samba Member
Posted: Sun Jun 20, 2021 10:14 am Post subject: Re: Bolt size for rear wheel bearing cover |
If you prefer NOS original VW bolts hex size 14mm :
https://heritagestocks.com/product/311501325-bolt-bearing-cover
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sun Jun 20, 2021 10:59 am Post subject: Re: Bolt size for rear wheel bearing cover |
i just used zinc coated hex heads from master-carr. you have lots of options there and i always get my stuff within 2-3 days _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
