VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9971 Location: Huntington Beach, CA
Posted: Wed Aug 29, 2018 7:21 pm Post subject: Re: What did you do to your Bug Today? |
Buggeee wrote: |
It all starts the same way: "what year is that" |
Yep! Every signal around here. But I did pull up to a cherried out 57 the other day and it was I asking him if it was a 57! He asked what year mine was, though!
Life is good!!! Totally agree! No bad days! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Tue Sep 04, 2018 7:25 am Post subject: Re: What did you do to your Bug Today? |
Getting ready to do the engine swap, and was installing the valve covers Saturday.
Between the aftermarket valve covers having a deep as hell flange that hits the bosses on the head, and the pathetic paper thin cork gaskets, I had to double up. Sigh...
_________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
mukluk Samba Member
Posted: Tue Sep 04, 2018 8:49 am Post subject: Re: What did you do to your Bug Today? |
DurocShark wrote: |
Trimming the flange as needed to clear the bosses would be a better solution. Using two gaskets per cover is wasteful as well as significantly increases the chances you'll end up with a leak in that area. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue Sep 04, 2018 8:53 am Post subject: Re: What did you do to your Bug Today? |
Yeah, I thought about it. I probably will later on. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Zundfolge1432 Samba Member
Posted: Tue Sep 04, 2018 3:00 pm Post subject: Re: What did you do to your Bug Today? |
Not much but I did build a short block today.
Posted: Tue Sep 04, 2018 8:13 pm Post subject: Re: What did you do to your Bug Today? |
Got the old engine out today. I forgot just how light a VW engine is.
I guess I found out why my clutch was such crap... I've never seen a pressure plate fail like this before...
Posted: Tue Sep 04, 2018 8:55 pm Post subject: Re: What did you do to your Bug Today? |
DurocShark wrote: |
Yep! Way lighter than a 454 big block!
Plate was improperly installed. It was stressed during the install, and then gave up the ghost. _________________ Jimbo
TDCTDI wrote: |
Posted: Tue Sep 04, 2018 8:59 pm Post subject: Re: What did you do to your Bug Today? |
How do you improperly install a pressure plate?
I just want to make sure I don't do whatever was done to that one. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Tue Sep 04, 2018 9:04 pm Post subject: Re: What did you do to your Bug Today? |
DurocShark wrote: |
I just want to make sure I don't do whatever was done to that one. |
Do not tighten one bolt at a time all the way. Instead, align the disc and start tightening the bolts one at a time, about a turn each time. I typically go in a cross star pattern. Eventually, they get to the snug part. Thats when you pull out the torque wrench.
Baby steps!
By the way. That looks like a stage1 Kennedy plate. Little better grab than stock. _________________ Jimbo
TDCTDI wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Tue Sep 04, 2018 9:55 pm Post subject: Re: What did you do to your Bug Today? |
DurocShark wrote: |
A friend of mine had a bad pressure plate late spring. When I removed the engine. This is what I found.
So it's not so uncommon.
Glad you found the issue with your clutch.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Wed Sep 05, 2018 5:28 am Post subject: Re: What did you do to your Bug Today? |
VW_Jimbo wrote: |
DurocShark wrote: |
Baby steps!
By the way. That looks like a stage1 Kennedy plate. Little better grab than stock. |
Oh, I figured there was some trick I maybe didn't know about. I've done a dozen clutches over the years, but who knows?
Yep. Kennedy. This clutch had been slipping for a long time. I just hadn't fixed it because this 2180 engine is coming out and my new 1835 is going in. I just wanted to see what the clutch looked like. The 2180 when rebuilt will go back to having a Stage 1. But stock should be fine for the new engine. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
DurocShark wrote: |
Good Luck. |
I guess not. Thanks for the pic! _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Thu Sep 06, 2018 2:20 pm Post subject: Re: What did you do to your Bug Today? |
Greased the front beam and ball joints. I can't remember the last time I greased anything, nothing has grease fittings anymore! Next is an oil change and valve adjustment. The engine that I installed in this Project bug was sitting under a workbench for 8 years. I put fresh oil in it when I installed it in July but I have put maybe 100 miles on it so I want to flush it with clean oil. Man it's good to be back in a Bug again after 18 years. Time flies.
Mike T
Engine before I installed it in the Bug. _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
Posted: Thu Sep 06, 2018 8:11 pm Post subject: Re: What did you do to your Bug Today? |
BIGMIKEY wrote: |
Man it's good to be back in a Bug again after 18 years. Time flies.” |
That’s what I thought four years ago, exactly! Feels really good! _________________ Jimbo
TDCTDI wrote: |
Posted: Sat Sep 08, 2018 6:31 pm Post subject: Re: What did you do to your Bug Today? |
For the first time in over 10 years we got the band back together. Just like the blues brothers we got all the guys we could round up, VW guys that is. One of the guys used to operate a VW shop in town for nearly 30 years, he shut the doors over 10 years ago. Anyway we came together to build a transaxle. Probably more BS than actual work but we did the gear stack and carrier then it devolved into lunch.
The two stacks sitting upright represent late model and early model we talked about the differences and progressive refinements. There’s strength in numbers just imagine what 6 old guys can accomplish |
Teehoovee Samba Member
Joined: January 15, 2016 Posts: 271 Location: Finland , kangasala city .
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Sun Sep 09, 2018 6:29 pm Post subject: Re: What did you do to your Bug Today? |
Went to the local cruise-in. No VW guys there. so I took a drive. Ended up cruising the country roads I used to cruise in the '70's when I was a kid. I had a thoroughly good time too. Car ran pretty good aside from a sudden tendency to idle at a real low rpm. The weather was cool for a change. Air temperature was about 50°F so I tried the heat. Toasty. Need to adjust the brakes again. New shoes are settling in.
Oh yeah, I installed a 15" EMPI trigger shifter. Works great and I don't have to lean forward for 3rd gear now.
Mike T
vamram Samba Member
Posted: Thu Sep 13, 2018 8:30 pm Post subject: Re: What did you do to your Bug Today? |
Finished and reinstalled my rear seat and cards. Should've painted the headliner...
_________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
chekrz Samba Member
Joined: March 13, 2015 Posts: 2 Location: DEEP SOUTH USA
Posted: Fri Sep 14, 2018 7:29 pm Post subject: Re: What did you do to your Bug Today? |
Cut my beam down 3 inches. Added disc brakes and 2.5 in. Drop spindles and my tires rubbed the out side of the fenders. So I had no choice but to chop the beam. Was way easier then I thought. The worst part was getting all the crud in my eyes upon taking it out!
Btw. I wish I had done the disc brakes yrs ago. They perform amazing.
_________________ You are what you are in the dark. |
