vdubguru Samba Member
Posted: Tue Oct 23, 2018 12:45 pm Post subject: Re: What did you do to your Bug Today? |
I appreciate all the comments! I don't plan to do anything to the bug that can't be undone. Just some tasteful mods that will help to "make it my own" as they say. cheers!
Emspilot55 wrote: |
vdubguru wrote: |
I bought my first aircooled vw. Have had many watercooled VW's and a couple Audis but, this is the first of the aircooled persuasion.
techincally it wasn't today but a week ago... semantics
1968 with a 1600 motor (not original). From the looks of things its been restored once before. pretty clean of rust. There are a few spots here and there but its a good runner.
plans are to get it sitting low with smoothies and white walls, a roof rack and some other little mods. Would like to swap to the blade style bumpers down the road. We'll see what happens!
Cheers! |
Beautiful!! |
Posted: Tue Oct 23, 2018 1:56 pm Post subject: Re: What did you do to your Bug Today? |
peters3103 wrote: |
Fitted a pair of Nankang 145R15s up front and now no rubbing (even with front passenger and full tank). Also painted inner rims red to match trim colour. Planning to paint outer rim body colour (beige). Tedious job masking up for two toning wheels but its worth it! Running drop spindles on stock beam, rims and disc brakes. 6 rims with 205s on the rear.
she's a real beaut, Clark |
Len K Samba Member
Joined: June 13, 2005 Posts: 104 Location: Pittsburgh, Pa
Posted: Tue Oct 23, 2018 3:09 pm Post subject: Re: What did you do to your Bug Today? |
Painted, reinstalled hood
Before
After
AlmostHeavenWV_VW Samba Member
Posted: Wed Oct 24, 2018 7:30 pm Post subject: Re: What did you do to your Bug Today? |
Yesterday:
Replaced the bakelite heat tubes ( with the body on) and then fashioned the "UnderSeat Bakelite to Heater Channel Tubes MkIII" to connect it up, since I do not have the "Y" tubes, nor do I have the cables to work the flaps-even if I did have them.
Now the heat CRANKS
Before pic in middle- note the spa hose just stuck into the bakelite tube w/ broken flange(last year when I bought the bug) and After pics on left and right (with MkIII tubes I made)
Today:
Dad and I installed my shiny, newly restored 205AJ DVDA (Courtesy of Bill) to match with my 34PICT3 (I previously had a Bosch 019 with the flat spot off idle)
Here's it on the bench getting points set and final checks & grease/oiling before install (Bill, look! I found a dust cover for it!!)
HOT DANG I TELL YOU
The Bug just walks away and pulls strong through the RPMs now and pulls strong as soon as you get on the gas now.
I am another believer in the German's wisdom in the matching of the carb&distributor combos, as per stock.
HUGE difference in driveability and performance. If you are running the 009 with a 34pict3- you NEED & WANT to get a matched distributor!
Here's a pic of the 205AJ installed after Dad & I went rippin' through town on the test drive
_________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
wcfvw69 Samba Purist
Posted: Wed Oct 24, 2018 7:35 pm Post subject: Re: What did you do to your Bug Today? |
AlmostHeavenWV_VW wrote: |
Yesterday:
Today:
HOT DANG I TELL YOU
Glad you like the restored distributor! I see you plugged the retard, yes? How'd ya time it?
Oh, good man getting the dust cover for it as well! _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Oct 24, 2018 7:36 pm Post subject: Re: What did you do to your Bug Today? |
wcfvw69 wrote: |
Oh, good man getting the dust cover for it as well! |
Yes, opted to plug the retard. Timed it as a SVDA, checked max advance to about 30* all in mechanical with vacuum lines/ports plugged, then hooked up Vac advance line.
End up it landed about 7*BTDC at idle.
Purrs like a kitten _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Posted: Wed Oct 24, 2018 7:49 pm Post subject: Re: What did you do to your Bug Today? |
wcfvw69 wrote: |
Purrs like a kitten |
Awesome! _________________ Contact me at [email protected]
Posted: Thu Oct 25, 2018 5:12 am Post subject: Re: What did you do to your Bug Today? |
Just an FYI- your fuel pump looks like the economy Brazilian one. It doesn't have "C" clip retainers on the rocker pin.
Those pumps w/out the retainer pins are know to do this ^ The pins loosens and backs out. The pump obviously stops pumping and you're on the side of the road with a dead engine. This pump was mounted on my bus when I bought it. I had it for a week and was going to get it off. This happened on the freeway and I had no tools to fix it.
I really enjoyed throwing that pump in the steel recycle pin and mounted a restored German Pierburg with the C clips that hold the pin.
There are a lot of new pumps sold today with the rocker pin secured with "C" clips. Brosal comes to mind.
Here's a picture of the pin with the "C" clips securing the rocker pin.
FYI _________________ Contact me at [email protected]
vamram Samba Member
Posted: Sun Oct 28, 2018 4:23 pm Post subject: Re: What did you do to your Bug Today? |
Did a bit of regular maintenance:
Changed to my winter oil castrol 5w/30 and new spin-on filter;
installed new clutch and brake pedal pads;
removed the rear drums to clean and lube the adjusting stars which had become almost frozen;
adjusted the rear brakes
and swapped out the distributor for the 205AJ with a new compufire module.
Oh and ordered 6 cans of fluid film for this year's winterization
_________________ Eventually, "we are what we pretend to be.
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
neisman Samba Member
Posted: Mon Oct 29, 2018 9:12 am Post subject: Re: What did you do to your Bug Today? |
Took it to my local garage to have new shocks, struts and steering box installed. I am so excited! |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Mon Oct 29, 2018 9:14 am Post subject: Re: What did you do to your Bug Today? |
Yesterday I drove the 68 with the new 1835 for its break-in cruise after the no load break-in. Powerful little engine.
It sputtered and crapped out on the way back, and I haven't had a chance to check it out. I'm betting that it's ignition again. Sigh. lol _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Mon Oct 29, 2018 10:06 am Post subject: Re: What did you do to your Bug Today? |
DurocShark wrote: |
It sputtered and crapped out on the way back, and I haven't had a chance to check it out. I'm betting that it's ignition again. Sigh. lol |
YOO WHOOO!!!!
Nice job man!
Sputtered sounds like fuel. Ignition is typically on or off. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Mon Oct 29, 2018 10:07 am Post subject: Re: What did you do to your Bug Today? |
Could be. I'll figure it out...
Knowing it's mechanically sound is all I care about right now. The rest is just details. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Mon Oct 29, 2018 10:09 am Post subject: Re: What did you do to your Bug Today? |
DurocShark wrote: |
Knowing it's mechanically sound is all I care about right now. The rest is just details. |
Agreed! That is a huge relief! I went through a whole big mechanical issue myself. Not fun! _________________ Jimbo
TDCTDI wrote: |
vamram Samba Member
Posted: Tue Oct 30, 2018 4:40 pm Post subject: Re: What did you do to your Bug Today? |
Loosened the rear brake shoes - had the right side adjust too tight and could feel it snagging when coasting to a stop. Also adjusted the front brakes which I ran out of time for on Sunday. _________________ Eventually, "we are what we pretend to be.
Click to view image
Save the Supers!! |
Posted: Tue Oct 30, 2018 6:46 pm Post subject: Re: What did you do to your Bug Today? |
Pushed my 69 into a shed till I can find a body shop that will fix the horrible job done by a local shop. |
Posted: Wed Oct 31, 2018 7:51 am Post subject: Re: What did you do to your Bug Today? |
Installed some rear seat belts & chrome eyelids on my '68. Great Success!! _________________ "I wear a suit of armour made only of my mistakes" -unknown |
73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Sat Nov 03, 2018 9:38 pm Post subject: Re: What did you do to your Bug Today? |
Installed new white window seals on the side windows. Mine were all cracked and dried out. Gonna install the rear windshield seal tomorrow, but that one's black. I got these cool NOS white window seals from a samba member here. They're west coast metric from the 80s or early 90s. I don't even think they make white ones any more.
_________________ Daily driven....Slowly. |
Posted: Sun Nov 04, 2018 2:30 pm Post subject: Re: What did you do to your Bug Today? |
Last night I did some measuring and planning for my door-switch-operated LED strip interior lighting.
Plans are to try tackling and install the planned LED lighting tomorrow. Should be able to tie it in and make it operate same as the OEM dome light when the doors open.
We'll see how it goes tomorrow. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Posted: Sun Nov 04, 2018 2:34 pm Post subject: Re: What did you do to your Bug Today? |
Did a nice freeway run with SharkDaughter. Held 75mph easily.
WOOT! _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
