carlos_magnum Samba Member
Posted: Tue Sep 15, 2020 2:10 am Post subject: Re: What did you do to your Bug Today? |
Done replacing the fuel pump gasket and trans mounts. |
1968BUGMAN Samba Member
Joined: April 12, 2019 Posts: 246 Location: Southern California
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Wed Sep 16, 2020 10:06 am Post subject: Re: What did you do to your Bug Today? |
Excellent! |
vamram Samba Member
Posted: Fri Sep 18, 2020 1:57 pm Post subject: Re: What did you do to your Bug Today? |
Replaced the *new* aftermarket leaky windshield w/a used original. No more leaks from the front. Now for the rear..... _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
bp03 Samba Member
Posted: Fri Sep 18, 2020 2:03 pm Post subject: Re: What did you do to your Bug Today? |
Changed the ignition switch!
Got my 1972 Standard two days ago. Vehicle idled in the PO's garage and then later I got it started to drive into my driveway off the trailer...Then it wouldn't start again.
I spent some time yesterday diagnosing it and ordered an ignition switch. Got it today, swapped it out and starts up just fine. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Sat Sep 19, 2020 4:18 pm Post subject: Re: What did you do to your Bug Today? |
Cusser wrote: |
And I think it's time to install new speakers into those housings, to replace the 45 year old ones in my 1970 !!! |
My speakers date from the time of my first stereo into my 1970 (in early 1973), to replace its dealer added AM radio. The toggle switch hanging down is for my electric windshield washer.
So in 47 years those housings have contained the same speakers. The housings had been attached under the dash using two sheet metal screws into the plastic housing through holes I'd drilled from the trunk side. After removing the housings, there were 4 hidden/recessed screws to take the housings apart, and then the 5.25" speakers could be unscrewed.
Local Autozone had some Boss 5.25" speakers, but those wouldn't fit into my housing, which I had taken along; there were individual Metra 5.25" speakers there for $14 each which DID fit, and I made mental note of that. I was on my way to Walmart 20 miles away anyway to pick up a new lawn tractor battery, so I looked at the Scosche 5.25" speakers there for $25.
https://www.walmart.com/ip/Scosche-Hd5254sd-5-25-Inch-4-Way-Car-Stereo-Speakers-Pair/326392036
The Scosche speakers fit perfectly into my housing, so I purchased those. Here is one screwed into my housing.
I soldered leads to the speaker terminals to connect to my wires.
Because mounting the external speakers the way I did required a helper to align and hold them when installing, I had a stroke of "genius" and used a screw from the inside secured by a nut, to act as a mounting stud, two per speaker (sorry no picture of that); then I could attach by using a nut/washer from inside the trunk. So completion of this small project looks exactly like the first picture.
Stereo
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
atldal Samba Member
Joined: September 19, 2020 Posts: 1 Location: Montana
Posted: Sat Sep 19, 2020 5:28 pm Post subject: Re: What did you do to your Bug Today? |
Finding Mice nest! |
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 572 Location: South of Raleigh
Posted: Sun Sep 20, 2020 11:35 am Post subject: Re: What did you do to your Bug Today? |
Yesterday I took the engine out of my recently acquired 69, so that I could change the trans mounts (the front one seemed to be totally shot). Found out it wasn't the mount, the nose cone was cracked. I knew when I got the car the passenger side floor was dented up just behind the seat area. With the engine and trans out, I could see that dent actually went at an angle right to the front of the trans, and the front part of the wishbone of the center spine was actually dented. So someone had a major off-road excursion. Someone had welded in some steel to act as a brace, but it really didn't do the job. It must have happened a long time ago as the metal on both sides of the crack were heavily corroded.
I'm very thankful this is a readily available part... |
vamram Samba Member
Posted: Sun Sep 20, 2020 3:30 pm Post subject: Re: What did you do to your Bug Today? |
Installed a factory impact strip on the rear after-market bumper.
Also went on a 30-mile cruise on local highways. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Zundfolge1432 Samba Member
Posted: Sun Sep 20, 2020 4:15 pm Post subject: Re: What did you do to your Bug Today? |
Cuss, those pics look great and it’s good to see your car finally 😀 you’ve taken care of it and it shows. |
Cusser Samba Member
Posted: Sun Sep 20, 2020 5:15 pm Post subject: Re: What did you do to your Bug Today? |
Zundfolge1432 wrote: |
Thanks ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1213 Location: IRELAND
Posted: Mon Sep 21, 2020 4:23 am Post subject: Re: What did you do to your Bug Today? |
Quick wash and dry brought out a nice shine on the 50 year old paint
bp03 Samba Member
Posted: Tue Sep 22, 2020 2:36 pm Post subject: Re: What did you do to your Bug Today? |
I took my bug out on the road for the first time last night at dusk...Went to turn on the headlights and they didn't work.. Over the past week while messing with the car they seemed to be intermittent.
After some troubleshooting I determined it to be the relay...Also upon pulling the relay I found it was cracked (pretty sure I did not do it).
Luckily Advance Auto has one that is a direct fit. I put 'er in and had lights again and then went for a ride! |
Jennthom Samba Member
Posted: Thu Sep 24, 2020 7:01 pm Post subject: Re: What did you do to your Bug Today? |
Bought my very first Bug on Tuesday! Yesterday I drove it for the very first time and today I'm removing the after market stereo amp and sub. Found some rust hiding under the sub.
Discovered oil leaking from 2 locations and preparing for the first oil change and tune up!
Excited!! |
Rome Samba Member
Posted: Thu Sep 24, 2020 8:50 pm Post subject: Re: What did you do to your Bug Today? |
Jennthom- congratulations, and welcome to the Beetle world. What year is yours? Where was the sub located?
When you do your oil change, be very careful with those 6 small "acorn" nuts that are on the bottom of the metal round sump plate. A thorough oil change involves removing that sump plate, pulling down the aluminum oil screen, and cleaning both parts with solvent or brake cleaner spray.
When you reassemble afterwards, first fit the copper washers from the oil change kit onto the studs before you put on the acorn nuts. Those nuts call for only 5 ft. lb tightening torque. Hand-tighten them onto the studs, then snug up each nut 1/2 turn at a time in a criss-cross pattern until you reach the 5 ft. lb. 30 years ago I bought a small 1/4" drive inch-pound ratcheting torque wrench on sale from JC Whitney, put on a 3" extension, and set it at 60 in. lb (12" x 5 ft) as my dedicated oil change wrench. You can probably find a similar cheap one from HarborFreight. The acorn nuts use a 10 mm socket. |
Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 445 Location: Rhode Island
Posted: Fri Sep 25, 2020 7:12 pm Post subject: Re: What did you do to your Bug Today? |
I have an ongoing problem. After driving the Beetle for about 30 minutes, it begins to misfire. It's beautiful weather this time of year. It's a real loss not to drive it.
Distributor cap has no cracks or carbon scoring. But the points had moderate pitting, so I started by replacing the points and condenser.
Went for a test drive and the misfiring started again. No easy fix. So I checked the coil polarity - good. I measured the primary and secondary coil resistance - good.
I tested the spark from the coil center post wire to the engine block. The spark is yellow, not blue like it should be. Hmmm - maybe getting closer to the problem.
Next I plan to measure voltage across the primary coil. And I'll probably run a hot lead from the battery to the coil to rule out the ignition switch, and check the coil wire spark again. If the spark is still yellow, it might be time to replace the coil. Any help or advice would be greatly appreciated.
In other news: Mechanics had their way with the engine over the years. Many things were modified. The ignition timing advanced only about 8 degree from idle to 3500 RPM.
My distributor has centrifugal advance. And it has vacuum advance and retard. Tracing the vacuum lines revealed that somehow, some way, the lines were reversed in the past. After correcting this error, my ignition timing advances to about 28 degrees BTDC at high RPM. _________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
Trikezilla Samba Member
Joined: September 26, 2020 Posts: 2 Location: Ft. Worth, TX
Posted: Sat Sep 26, 2020 7:35 pm Post subject: Re: What did you do to your Bug Today? |
Bought more parts! |
Gr0unded Samba Member
Joined: October 02, 2018 Posts: 256 Location: North Carolina
Posted: Sat Sep 26, 2020 8:03 pm Post subject: Re: What did you do to your Bug Today? |
Installed a "Hot Oil Sensor" today.....went for a test drive and all was well until the final stretch back home. I had been driving for about 20 minutes of mixed country and highway driving. Before turning down my road, I slowed the car down from 60mph, turned right and the oil light began flashing and in some instances continuously glowed. Very strange....car was fine the whole while until that last right turn. Thankfully it was not far before turning into the driveway and parked it......the oil light flickered then I shut it down. I have more work to do... _________________ B r i a n
1976 VW Type 1 Beetle - Standard
Stop Dead Photo Links! Post your VW photos to the Samba Gallery! |
J-Gaz. Samba Member
Joined: November 19, 2007 Posts: 613 Location: 253 Then, Now 206.
Posted: Sun Sep 27, 2020 3:32 pm Post subject: Re: What did you do to your Bug Today? |
@cusser
[quote="Cusser"]
Cusser wrote: |
That's a great Housing & Location - better than the kick plate stuff I've seen.
Know of anyone making a Kit like that- Eventually I might put a stereo in my 70
Right now it's still got the original uncut dash with no stereo! _________________ 1970 Beetle | Basically Stock 1600 SP |
Posted: Sun Sep 27, 2020 5:19 pm Post subject: Re: What did you do to your Bug Today? |
Engine misfire problem:
Bentley says the voltage across the primary ignition coil should be 9.6V minimum. On my car while idling I measured 6V. When I reved the engine to about 2500 RPM I measured 4V.
In my earlier post, the spark from the coil center post wire to the engine block is yellow (it should be blue). Combined with low voltage across the coil, it looks like I'm getting close to the problem.
I'm looking for advice on what's next. Is this a likely coil issue? Or should I look at the ignition wiring or the alternator? _________________ 1956 Beetle Ragtop: My Father's car
