What did you do to your Bug Today?
Page: Previous  1, 2, 3 ... 407, 408, 409 ... 447, 448, 449  Next
Snoopy1971
Snoopy1971 is offline
PostPosted: Wed May 12, 2021 4:21 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
I got tired of my stuff in the trunk (tool bag, jack, etc) being loose and looking like this:
so I ordered a vintage suitcase off Etsy last week and it came today so I put everything in it and put up front.
1968 Bug
bp03
bp03 is offline
PostPosted: Thu May 13, 2021 3:06 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
swapped out front and rear trans mounts. The rears were nasty and separated. Front didnt look that bad actually, probably could have reused it for several more years but swapped it out anyways.
Cusser
Cusser is offline
PostPosted: Thu May 13, 2021 7:35 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Yeah, it was about time for the rear mounts !
challomoner
challomoner is offline
PostPosted: Fri May 14, 2021 2:55 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
Stripped it down for yearly deep clean and wax
DurocShark
Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
DurocShark is offline
PostPosted: Fri May 14, 2021 4:24 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
While I'm waiting for SOMEONE at ACN to respond (even emailed John directly) on the status of my cam, I decided to go ahead and order new con rods. My 2234 had used clearanced stock rods and I would have been happy to keep using those. But since I was waiting anyway, I went ahead and ordered some 5.5" H-beam rods. Should make things go a little smoother.
No boom today. Boom tomorrow. There's always a boom tomorrow.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Fri May 14, 2021 4:52 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
ACN has been a little slow in responding lately.
My guess is that they are quite busy processing orders.
Be patient. Stephanie will reach out to ya, soon.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
DurocShark
PostPosted: Fri May 14, 2021 5:02 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Well, considering the order was placed nearly a month ago, and I started asking for backorder status 2 weeks ago, I think that I've been patient. Sad
I do love John and ACN, but this kind of thing drives me nuts.
GBUCKLEY
GBUCKLEY is offline
PostPosted: Sat May 15, 2021 5:42 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
George from NY - Red 1970 convertible type 1, acquired June 2020. I've spent the pandemic thing sprucing things up, replacing parts almost as old as me, and making the car safe and drivable. Finally lost my V-card by dropping the engine out in October.
Shout out to Gene at Volksworld, who has given unbelievably helpful remote support.
I owe TheSamba a history of the rehab of my car. To follow...
Today I received 15 gallons of real gas (no ethanol, 93 octane) from my neighbor, who can buy it 6 hours away - up near Canada. Will last me 6 weeks or so, in prime convertible weather. He promised to keep me supplied.
Also I confirmed that the clunking I have heard as of late is bad ball joints. So I watched half a dozen YouTube videos on how to replace them, and looked for reliable replacements on Rockauto.
Re-adjusted my shift plate - shifter migrated a smidge.
Lost69Convertible
Lost69Convertible is offline
PostPosted: Sat May 15, 2021 7:37 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
I changed the oil today. Cleaned up the mess from the PO use of sealant.
I installed the WW silicone gaskets and copper washers. My son came by to do the same with his Honda. That bike takes more oil than a Beetle.
1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible
FredH17
FredH17 is offline
PostPosted: Sun May 16, 2021 5:12 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
Great job mate !!
challomoner
PostPosted: Sun May 16, 2021 6:04 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
Thanks Fred. All waxed up and shiney.
BrooklynTony198
BrooklynTony198 is offline
PostPosted: Sun May 16, 2021 9:46 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Took apart more of my '79 Vert.... found out that a previous owner did this to the floorpan! How exciting!
Proud(?) Owner of a Project '79 Super Vert.
"Am I in over my head? Maybe. Will I continue to work on it? Of course!"
Cusser
Cusser is offline
PostPosted: Mon May 17, 2021 6:54 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
You don't want to see the "fixes" to the pan under the battery on my two VWs !!!
DurocShark
PostPosted: Tue May 18, 2021 12:41 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Gave up on ACN. Ordered the cam (and some other bits) from Car Craft. Smile They verified they had the cam in stock.
Lost69Convertible
PostPosted: Sun May 23, 2021 4:04 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
While opening the door to my Beetle, something didn't look right. I pulled this common wood nail out of the check strap assembly. Shocked I wonder how many years it's been there?
I installed the correct part:
OTTO 1303
OTTO 1303 is offline
PostPosted: Sun May 23, 2021 10:54 pm    Post subject: Re: What did you do to your Bug Today? Reply with quote
Full rebuild on Bosch 034 SVDA (original)
Cleaned everything, which from the looks of it, hadn't been done since the day it was born.
Bearing sleeves were solid with no shaft play.
Lubed all pivots and mating surfaces.
Replaced some missing pieces with parts from VWNOS.
Installed Standard Ignition (Intermotor) points and condenser.
Set points gap at .016 and then adjusted for correct DWELL of 48
Dynamic timing will have to wait, I don't have one of those dial in timing lights.
74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG
GBUCKLEY
GBUCKLEY is offline
PostPosted: Tue May 25, 2021 7:23 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
Drove to the beach and to the supermarket. Shifting was not 100%.
I had replaced the shift rod bushing last year with Dansk. To be determined, but I suspect it didn't last 300 miles. Next one will be WW. At least I know how to change it.
I smell like Volkswagen.
unclewede
unclewede is offline
PostPosted: Wed May 26, 2021 8:55 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
So THAT'S what it could have looked like if my son allowed me to clearcoat his car. He didn't want flash/shine, and now *I* drive it. . . touch-up/repair is a lot easier with single stage.
I got that (ash?) turned gear shift knob, and set it in my car for about a week to cure/acclimate. Last night (while driving Embarassed ) I determined that if I hold the shift rod, the knob comes off rather easily. Should the shift rod just spin like that?
kpf
kpf is offline
PostPosted: Wed May 26, 2021 10:37 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
Yes.
1971 Super Beetle
vamram Premium Member
vamram is offline
PostPosted: Wed May 26, 2021 11:56 am    Post subject: Re: What did you do to your Bug Today? Reply with quote
Adjusted the valves and brakes. Ready for the weekend road trip to Putnam Valley NY!
Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!!
Page 408 of 449
