BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Sat Sep 17, 2022 4:25 pm Post subject: Re: What did you do to your Bug Today? |
I have a Regular size tennis ball for normal weather then today I picked up this one for Heat emergency conditions. ... Can never be too careful.
Mike T
_________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
mikeonthebike Samba Member
Joined: December 08, 2012 Posts: 953 Location: Sacramento, CA
Posted: Sat Sep 17, 2022 4:51 pm Post subject: Re: What did you do to your Bug Today? |
BIGMIKEY wrote: |
Mike T
Where did you get the oversized tennis ball? I live in Sacramento and could use one. |
Posted: Sun Sep 18, 2022 9:12 am Post subject: Re: What did you do to your Bug Today? |
mikeonthebike wrote: |
BIGMIKEY wrote: |
Mike T
Tractor Supply Company. It's a Dog toy.... more of a joke really. But I see there is a TSC in Dixon, CA so there ya go.
Mike T _________________ BIGMIKEY
BCE56 Samba Member
Posted: Tue Sep 20, 2022 4:43 pm Post subject: Re: What did you do to your Bug Today? |
BCE56 wrote: |
On to the next fiasco!
Which will be window scrapers, glass run channels, vent wing seals, risers, check rod bushings etc.
I will see if old lock cylinders can be swapped into the new black door handles.
But first, new coupler and shift rod bushing. |
Coupler and two-piece shift rod bushing installed.
Door lock cylinders swapped.
New handles installed, w/ new gaskets. _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
irvanm Samba Member
Joined: January 09, 2008 Posts: 609 Location: Lawrence, Kansas
Posted: Thu Sep 22, 2022 4:02 pm Post subject: Re: What did you do to your Bug Today? |
I pushed it out of the garage to wait for the rollback to take it to my friend Pats old shop. iIt seemed like it was going to be a lot easier having it on a lift, Pulled the tank and ordered a new one and blew some awful stuff out of the line.
irvanm Samba Member
whoops
irvanm Samba Member
Posted: Thu Sep 22, 2022 4:03 pm Post subject: Re: What did you do to your Bug Today? |
whoops
irvanm Samba Member
whoops |
Scat Adams Samba Member
Posted: Wed Sep 28, 2022 3:14 pm Post subject: Re: What did you do to your Bug Today? |
Removed the original running boards to work on some rust prevention and paint touch up. After cleaning the channel, I used a color matched spray can to cover up the minor rust spots along with a buffer to remove the paint discoloration from where the running boards mount. Ordering new black running boards and some other goodies now, should have them on next week.
Cheers, |
radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Thu Sep 29, 2022 7:42 am Post subject: Re: What did you do to your Bug Today? |
Scat Adams wrote: |
Cheers, |
Cleaned up nicely! _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
2002 VW Mexican Bug 1600i |
irvanm Samba Member
Posted: Fri Sep 30, 2022 6:44 am Post subject: Re: What did you do to your Bug Today? |
Am still in process of awakening it from 10 year storage by previous owners and painted rims since off while doing brake system.
Posted: Fri Sep 30, 2022 11:32 am Post subject: Re: What did you do to your Bug Today? |
irvanm wrote: |
That will make a big difference! _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
BCE56 Samba Member
Posted: Sat Oct 01, 2022 4:36 pm Post subject: Re: What did you do to your Bug Today? |
More progress in the last two weeks than in the previous 6 months!
Front disc brake kit, dust covers, stock height spindles, master cylinder, pressure switches, ball joints etc installed by my suspension guy.
(Poorly machined CIP discs required facing...)
New rear wheel cylinders and brake job, brake hoses all around. Front end aligned.
Stance looks a bit high at the rear- correction will be deferred until new tires are installed.
Have not test-driven yet but will report soon.
Still working on door cards, internals, window scrapers etc. _________________ =BCE56=
'86 Syncro tintop
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Sat Oct 01, 2022 6:24 pm Post subject: Re: What did you do to your Bug Today? |
Replaced my 12+ year old fuel filter, it plugged up in the driveway.
It was on there when I got the car. PO had 3 filters on it. plastic one by the carb, one of those glass ones by the tranny and a metal one up under the tank.
I had got rid of the plastic one pretty quick, replaced the glass one at some point with a plastic one and never messed with the metal one until today.
Replaced it with a plastic one.
Now I can check it for dirt every 5 years or so... _________________ 1972 1302
HPMX 40's & 019 |
Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 447 Location: Rhode Island
Posted: Sun Oct 02, 2022 2:12 pm Post subject: Re: What did you do to your Bug Today? |
I installed my spare Air Flow Meter #2 and road tested it today (1979 FI engine). While under load at 40 to 50 mph, the air fuel ratio was 12.5% to 14.0%. I want the ratio to stay below 13.5% - but it's not far off target.
At low speed, idle, and when I took my foot off the pedal - the air fuel ratio jumped to 14.5% - 17%. I don't want to run that lean. I suspect the air bypass in the AFM needs adjustment.
Crank case temperature was good.
_________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
Gr0unded Samba Member
Joined: October 02, 2018 Posts: 256 Location: North Carolina
Posted: Sun Oct 02, 2022 8:20 pm Post subject: Re: What did you do to your Bug Today? |
Lost69Convertible wrote: |
Keep up the great work checking the AFR. Wish we lived closer to together, would love to do the same on my '76 FI to ensure AFR is in check. _________________ B r i a n
1976 VW Type 1 Beetle - Standard
Stop Dead Photo Links! Post your VW photos to the Samba Gallery! |
irvanm Samba Member
Posted: Tue Oct 04, 2022 2:42 pm Post subject: Re: What did you do to your Bug Today? |
I bought some new seat belts and installed them, not sure why they had been removed but feel better having them.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Fri Oct 07, 2022 12:24 pm Post subject: Re: What did you do to your Bug Today? |
I drove my 1970 sedan almost 50 miles today, in to "town" (Prescott) to buy some paint at Home Depot. First I aired up the tires to specifications, and then I filled the gas tank on the way. On the way back I stopped to get a 5-gallon propane cylinder filled.
Anyway, my driver door is loose and rattles, so maybe someone wants to take a look at the thread I started for that https://www.thesamba.com/vw/forum/viewtopic.php?p=9939889#9939889 _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bandi Samba Member
Joined: August 24, 2005 Posts: 1064 Location: Campbellford, Ontario, Canada
Posted: Sun Oct 09, 2022 7:14 am Post subject: Re: What did you do to your Bug Today? |
Scat Adams wrote: |
Cheers, |
Nice Love Bug!! _________________ '60 Canadian Standard, '64 Bug, another '64 Bug, '66 Bug, '69 Sunroof Bug, '69 GT3 Bug, '71 Super, '72 Super, '73 Canadian Custom, '74 Love Bug, '83 Mexi Bug, '85 Cabrio, '94 Mexi Bug, '99 New Beetle, '02 New Beetle Turbo S, '03 New Beetle VR6. And some Fieros. |
bandi Samba Member
Posted: Sun Oct 09, 2022 7:15 am Post subject: Re: What did you do to your Bug Today? |
Scat Adams wrote: |
Cheers, |
