irvanm Samba Member
Joined: January 09, 2008 Posts: 609 Location: Lawrence, Kansas
Posted: Sat Dec 17, 2022 9:04 am Post subject: Re: What did you do to your Bug Today? |
My stuff I do is never as good as what you guys do, I kept wondering why my washer bottle wouldn't stay put and i finally figured out that there was a reason for the slots where it goes through the wheel holes. I looked it up on the internet and saw they were supposed to have a pin in them so I got a couple of large zip ties and cut them off and then tapered them so they would go through.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Sat Dec 17, 2022 11:58 am Post subject: Re: What did you do to your Bug Today? |
I used "U" shaped pieces cut from a steel coat hanger back before I went to an electrical washer system.
Why did I change? I wanted one that would actually work. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
runscx Samba Member
wrdrew Samba Member
Joined: December 13, 2018 Posts: 68 Location: Chicagoland Indiana
Posted: Sun Dec 18, 2022 11:03 pm Post subject: Re: What did you do to your Bug Today? |
Put the motor back into my 68 today with my old man. Oil cooler seals gave up the ghost (on a brand new motor with less than 400 miles) so we pulled it to make sure. Ran it on the stand and she's good to go! Went on a little (freezing cold) night drive after to test it out.
_________________ Ugly, Slow, Noisy, Expensive
1968 Beetle
https://www.thesamba.com/vw/forum/viewtopic.php?p=8965092#8965092 |
BCE56 Samba Member
Posted: Mon Dec 19, 2022 7:36 pm Post subject: Re: What did you do to your Bug Today? |
Pulled the running boards and the molding strips. Boards are sound and will clean up nicely. I may opt for new rubber covers. Moldings are tattered and will not be replaced.
No rust at body mounts, and very little at fenders.
Added a spacer at Bowden tube, hoping to correct clutch engagement. Will adjust freeplay before test drive.
Today: Removed moldings from running boards. Rubber looks good. I will use small carriage bolts to fill the holes.
Applied Rust Restorer to the underside of boards, will do the same at body areas JIC.
Rust repairs and spot painting can now commence.
Some mechanical issues still remain... _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
GSuperB Samba Member
Joined: December 22, 2022 Posts: 5 Location: Guatemala
Posted: Fri Dec 23, 2022 6:26 pm Post subject: Re: What did you do to your Bug Today? |
Swapped an old beat up 31 carb that was a mess with a brand new 34. I had help.... lots of it. I could not get a Solex or similar. This one has no brand. |
platatomi Samba Member
Joined: August 09, 2012 Posts: 465 Location: Los Angeles, California
Posted: Fri Dec 23, 2022 7:26 pm Post subject: Re: What did you do to your Bug Today? |
Reinstalled carbs, installed oil temp sender in rear relief plug, new valve cover gaskets. _________________ '69 Beetle daily driver, fixing things as I go...
Update -
No longer daily driver but still fixing things... |
Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Mon Jan 02, 2023 1:04 pm Post subject: Re: What did you do to your Bug Today? |
It's been 2800 miles since I tuned up my engine. After driving around at near zero Fahrenheit for several days my timing felt off. So I filed my points down a bit, set the dwell, and re-set the timing statically. That resolved the issue and away I went.
I ran my errands, got home, and as I was pulling into the parking lot it died. It felt like I ran out of fuel. I coasted into my parking spot. I popped the cap off the distributor and the points looked good. Looked at the fuel filter - had gas. It was getting dark out so I just went inside. That night I kept dreaming of failed fuel pumps and cancerous coils...
That made no sense. I had to have caused it. Something I had done...
So I thought about it and came up with a theory. I headed out with a 10mm socket and my timing light. Sure enough - I forgot to tighten the nut on the distributor clamp, and the distributor had rotated counter clockwise advancing the timing so much it couldn't run.
So ya...
Then I go inside and wife is like did you fix it? Yes? What was the problem?
And I could have come up with something like "I was getting analogous dwell readings on the zircon rectifier" and complained about the quality of parts nowadays, and she would have marveled at how smart I was.
Instead I confessed I was an idiot and she baked me some little VW cookies. _________________ Repeat after me "I am smarter than metal!" |
BCE56 Samba Member
Posted: Mon Jan 02, 2023 2:18 pm Post subject: Re: What did you do to your Bug Today? |
Jimbug57 wrote: |
Instead I confessed I was an idiot and she baked me some little VW cookies. |
Mmmmm, cookies! _________________ =BCE56=
'86 Syncro tintop
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 460 Location: Canadian Rockies
Posted: Tue Jan 03, 2023 8:44 am Post subject: Re: What did you do to your Bug Today? |
I removed my 1500 from my 69 beetle. I believe the numbers matching engine has only 43,000 miles on it! It will be torn down and rebuilt and restored, upping the displacement to 1641, but retaining the original stock appearance. The engine runs great, but leaking lots of oil(of course). I don't know anything about the first 32,000 miles of it's life, but I don't think there was much maintenance done to it. When I got the car in 2018, I'm sure the fuel lines were the originals from 1969 - saturated with gas.
I'm fortunate to have found a veteran air-cooled specialist to take on the job. Once this engine is totally restored, it should last me for the rest of my adventures. My hope is to travel through the US taking in VW shows, meeting VW folks, Route 66, and checking out some iconic golf courses. _________________ Where would this hobby be if no one shipped parts.
crukab
Feb. 11, 2021
Smokey says.... only you can prevent Bug fires!
zerotofifty
May 16, 2023 |
Cusser Samba Member
BCE56 Samba Member
Posted: Tue Jan 17, 2023 2:21 pm Post subject: Re: What did you do to your Bug Today? |
Took the trim pieces to plater this AM.
Aluminum moldings will be stripped and black hard anodized.
Chrome plated parts will be media blasted to prep for paint.
I will post results. _________________ =BCE56=
'86 Syncro tintop
alex857 Samba Member
Joined: December 26, 2010 Posts: 714 Location: Stuttgart/Germany
Posted: Sun Jan 22, 2023 12:25 pm Post subject: Re: What did you do to your Bug Today? |
Drove my 1983 Mexican Special Bug shortly before its 40th first registration day carefully through the snow.
radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Mon Jan 23, 2023 11:53 am Post subject: Re: What did you do to your Bug Today? |
Nice Bug! I like your your pictures! _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
2002 VW Mexican Bug 1600i |
GedasV Samba Member
Joined: December 28, 2022 Posts: 16 Location: Lithuania
Posted: Wed Jan 25, 2023 11:52 am Post subject: Re: What did you do to your Bug Today? |
alex857 wrote: |
Nice! The same Special Bug is mine! 1982.
But.... In novadays it's a pitty I didn't paint it in original color. Now my Bug is green/ grey/ blue/ yellow, etc. It depends on the sunrays angle. |
GedasV Samba Member
Posted: Wed Jan 25, 2023 11:53 am Post subject: Re: What did you do to your Bug Today? |
GedasV Samba Member
Posted: Wed Jan 25, 2023 11:57 am Post subject: Re: What did you do to your Bug Today? |
Who can give me an advice- where to put front number palte?
Two examples and Your opinions, please.
OldSchoolVW's Samba Member
Posted: Wed Jan 25, 2023 1:02 pm Post subject: Re: What did you do to your Bug Today? |
I like both locations, but if mounded on the front of the bumper it will probably get damaged (bent). I'm sure you will be careful, but someone parking in front of you may not be. _________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 635 Location: Louisiana
Posted: Wed Jan 25, 2023 2:13 pm Post subject: Re: What did you do to your Bug Today? |
GedasV wrote: |
The lower mounting does not cover the effect of the body color bumper, just have to watch out for parking curbs and raised sidewalks. _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
vamram Samba Member
Posted: Sat Jan 28, 2023 7:55 am Post subject: Re: What did you do to your Bug Today? |
Installed front kick panels with speakers. Geez, what a difference having four speakers rather than only 2 rear ones makes. I never give this much thought in my wife's 2019 Subaru Forester... _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
