Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Tue May 16, 2023 11:31 am Post subject: Re: What did you do to your Bug Today? |
Just today I noticed a leak in a short piece of my fuel line, between my all-metal fuel filter and my single Weber 40DCNF carburetor. I had brand-new German fuel line in my trunk, and I replaced that leaky fuel line, including using a piece of rubber hose as the protective "grommet".
I was not able to pinpoint exactly the reason for the leak. I know some here hate braided fuel line, and I know some here hate worm-style hose clamps....
Yes, also noticed that the ground wire to the generator has cracked insulation; yes, folks - it gets real hot here in Arizona !!! Original factory ground wire there. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Maddel Samba Member
Posted: Tue May 16, 2023 1:03 pm Post subject: Re: What did you do to your Bug Today? |
Cusser wrote: |
... using a piece of rubber hose as the protective "grommet" ... |
That will help!
Clamping the whole filter may be an option to relief strain? |
boxer74 Samba Member
Joined: July 03, 2011 Posts: 709 Location: Ontario, Canada
Posted: Wed May 17, 2023 4:58 am Post subject: Re: What did you do to your Bug Today? |
Installed some Corbeau Moab seats in my 74 super last night using their adapters for 73-79 beetles. Was a 30min bolt-in job. No cutting or welding or modification required. How often can you say that when installing aftermarket parts? I really like how they look and feel. Can't wait to get the car on the road soon.
_________________ 74 Super
84 Westy |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 637 Location: Louisiana
Posted: Wed May 17, 2023 7:14 am Post subject: Re: What did you do to your Bug Today? |
NICE!!! _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Thu May 18, 2023 8:50 am Post subject: Re: What did you do to your Bug Today? |
boxer74 wrote: |
Wow! Nice choice! _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
2002 VW Mexican Bug 1600i |
boxer74 wrote: |
1971 VW Bug (Past)
1975 VW Bus (Past)
boxer74 wrote: |
1971 VW Bug (Past)
1975 VW Bus (Past)
boxer74 wrote: |
1971 VW Bug (Past)
1975 VW Bus (Past)
Posted: Thu May 18, 2023 12:06 pm Post subject: Re: What did you do to your Bug Today? |
radstude wrote: |
Wow! Nice choice! |
Thanks. I lucked out. The Corbeau Moab shape was what I was after. Something similar to tombstone style Porsche or Miata seats. Unfortunately, most Corbeau seats come with the harness slot which I think looks silly in a classic car. I realized they offer a version without the slot so I jumped on it. Turns out that was the last pair in stock of that limited run. They are no longer available. Score! _________________ 74 Super
84 Westy |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Fri May 19, 2023 8:23 pm Post subject: Re: What did you do to your Bug Today? |
Replaced my radio and was able to hook up a couple wires that I had knocked loose at some point. Now I have a 2-speed fan again and the brake light works again. the brake light wire was the black key on hot wire, I don't know how it didn't ground itself years ago, it was just floating around in there. _________________ 1972 1302
HPMX 40's & 019 |
AlmostHeavenWV_VW Samba Member
Posted: Tue May 23, 2023 11:36 am Post subject: Re: What did you do to your Bug Today? |
Spring tune ups and checks with my diagnostic box
Oil change
Timing and dwell
Voltage and charging
Air filter
Carb settings
And a new state inspection sticker this morning _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
OldSchoolVW's Samba Member
Posted: Sun Jun 04, 2023 6:58 pm Post subject: Re: What did you do to your Bug Today? |
Finally got around to installing a power port underneath the dash.
_________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Sun Jun 04, 2023 7:11 pm Post subject: Re: What did you do to your Bug Today? |
OldSchoolVW's wrote: |
Looks familiar, I used that location for my power plug as well:
_________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
Cusser Samba Member
plastikman187 Samba Member
Posted: Wed Jun 07, 2023 10:52 am Post subject: Re: What did you do to your Bug Today? |
Ordered a refurb pedal cluster from Avery's Aircooled. My current pedal cluster has a broken hinge where the stock accelerator pedal sits, I currently have a roller pedal that my wife hates.
Guess ill get around to installing this when it arrives in the mail. Ill post so pics once its all done. hopefully this weekend. |
clockworkbox Samba Member
Joined: July 12, 2020 Posts: 286 Location: Williamsport, PA
Posted: Wed Jun 07, 2023 6:09 pm Post subject: Re: What did you do to your Bug Today? |
Rebuilt a speedo using a mix of '69 and '68 parts. I like the look of the '68 speedo but wanted the parking light indicator so I modified the '68 speedo face for the park light warning and used the housing from a '69.
_________________ '69 Beetle (pieces)
Learning the hard way is still learning... |
vamram Samba Member
Posted: Thu Jun 08, 2023 9:30 am Post subject: Re: What did you do to your Bug Today? |
Replaced the front-left blinker assembly w/a good original. Old one had too much corrosion to salvage, driving/parking light would turn off when going over bumps in the road. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Sun Jun 11, 2023 6:15 am Post subject: Re: What did you do to your Bug Today? |
Finished repairing some previous bodywork, fix some crunch areas and welded holes, in rear apron. Included the removal of the inner heat shield with all rust treated and heat shield spot welded back into place.
74 Super - DANZIG
74 Super - HERZOG |
Posted: Thu Jun 15, 2023 6:02 pm Post subject: Re: What did you do to your Bug Today? |
Cleaned up the new to me pedal cluster. I didn’t take any before shots. The clutch hook was new and the rest of the cluster was pretty good. I hope to actually get it installed this weekend. The clutch will be easy to hook back up right?
The foot was my dads I took it from his house when I cleaned it out. I think it will be a cool addition. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Thu Jun 15, 2023 6:46 pm Post subject: Re: What did you do to your Bug Today? |
I'd run it!
Clutch cable hooking is a delicate balance to keep it hooked while installing the pedal cluster.
Some say a bread bag, wire tie around the hook and the cable end will hold it in place.
Or a small "Zip tie" will do the same job. Neither of these worked for me.
But try them if you feel unsure of your abilities to keep the cable on the hook.
Just don't let the clutch pedal flop rearward while install the cluster into the tunnel.
Or you'll be trying again. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
