oldbugs Samba Member
Joined: September 16, 2002 Posts: 185 Location: Deerfield Beach, FL.
Posted: Sun Aug 24, 2008 6:53 pm Post subject: Idle jet ? |
How in the heck does an idle jet clog? Is it junk getting past a crappy fuel filter that clogs them up or is dirt and dust sneaking past an air filter? What kind of fuel and air filters do the best job to keep the crap out? Show me whatcha got! It seems like I'm cleaning idle jets out all the time, what gives?! Kelly _________________ I've got 2 dollars and I'm saving it... |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Aug 24, 2008 7:45 pm Post subject: Re: Idle jet ? |
oldbugs wrote: |
How in the heck does an idle jet clog? Is it junk getting past a crappy fuel filter that clogs them up or is dirt and dust sneaking past an air filter? Kelly |
All the above..... What type carburetors.....
If you have best quality gas filters and air filters problems will be less...
IF you are using WEBER IDF's, try getting "Jet Doctors" for them..
http://cbperformance.com/catalog.asp?ProductID=1507
If running Dell's
http://cbperformance.com/catalog.asp?ProductID=514
And cast aluminum bases and top covers are better than stamped steel... Also seal air filters to carb base plate and top covers....
mharney Samba Member
Posted: Sun Aug 24, 2008 7:46 pm Post subject: |
Well, what carbs do you have? Realize that an idle jet is very small.. I mean like 0.020" hole. It doesn't take much to clog that. Dirt in the lines, bad filters and setup, accumulation of smaller particles that break free as chunks in the float bowl and get sucked into the idle circuit.. lots of chances for it to happen. |
Posted: Mon Aug 25, 2008 4:14 am Post subject: |
oops, dual 44 idf's _________________ I've got 2 dollars and I'm saving it... |
73stroker Samba Member
Posted: Mon Aug 25, 2008 5:13 am Post subject: |
many different ways. I went and got the Jet Doctor for mine, simple install and solved the problem, that is providing that you are running filters. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Mon Aug 25, 2008 5:36 am Post subject: |
A Jet Doctor will not prevent any more dirt from getting in.
Most problems are from dirt getting past the air cleaner base plates on the cheap Chinese air cleaner assemblies. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Scott Novak Samba Member
Joined: October 12, 2004 Posts: 1586 Location: Minneapolis, Minnesota
Posted: Mon Aug 25, 2008 6:27 am Post subject: |
Also note that if you are using CB performance 4-1/4" x 7"air cleaners bases, that genuine K&N Air cleaners WILL NOT FIT properly!!!
Their catalog ad incorrectly states that their air cleaner linkage bases fit 4-1/2" x 7" air filters. Their K&N clone filters are 4-1/4" x 7" and genuine K&N filters are 4-1/2" x 7" and they are NOT interchangeable.
http://www.cbperformance.com/catalog.asp?ProductID=509
A direct quote from their incorrect ad:
"This linkage kit works with all 4 1/2" x 7" OD air cleaner elements which are available in Heights from 1 1/8" to 9". Filter elements (gauze & foam), air cleaner tops, and mounting hardware are all available separately."
I e-mailed them about this and never received a response from them and the catalog is still incorrect.
Also be aware, that their air cleaner bases have flashing from the mold sprues and the flashing needs to be ground off so that the air filters will seal against the air cleaner bases.
Scott Novak |
Posted: Mon Aug 25, 2008 7:53 am Post subject: |
I've had many occasions to determine cause of plugged jets, and MOST of the time it's crap in the fuel, but air cleaners are a concern for sure. Even if you have good filters if you don't oil them, you'll get more stuff in. It settles on the top of the carb, some falls into air bushings, bowl vents, etc... and plugs up the idle jets. Starting out with clean fuel system (and I mean CLEAN, none of this "looks ok" BS), and good filters (as mentioned aluminum bases and tops helps a lot), you should have minimal problems. |
77charger Samba Member
Posted: Mon Aug 25, 2008 4:39 pm Post subject: |
I used permatex on the base gasket for the filters(very little)
And use grease on the filters apply at the base and tops of filters along with outerwares for my buggy it definitely stops the sand from getting in at easy spots.Of course i oil the filters themselves with filter oil too. |
