bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Tue Aug 26, 2008 6:16 pm Post subject: Replacement for air intake boot |
Driving the other day in my 84 1.9 liter, and notice a high idle; about 1200 RPM. I removed the air cleaner box and air intake boot, and notice some small hairline cracks. This is the second air intake boot I've installed. It seems that the boot never does quite fit perfectly to the mass air flow flapper (wrong description) in front of the air filter. Right now I have a dab of silicone on the crack to seal it, and the idle is fine now.
Is there a "kit" anyone has installed that eliminates the stock air filter box? I've seen kits at the PEP BOYS parts stores that have an angled chrome tube and a cone type air cleaner. It would seem I should be able to get a straight boot from the throttle body to the air flow box, then to a cone type filter (like a K&N). Installing the crankcase breather tube would be easy enought to plumb in.
Anyone done something like this? Those intake boots for the 1.9 are getting costly. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
msinabottle Samba Member
Posted: Tue Aug 26, 2008 7:54 pm Post subject: Good question... |
That's a good question, Bucko, and I hope someone can answer it in the spirit in which you're asking it. I used self-adhering rubber tape to seal up mine. I might try J.B. Weld, too. There are a LOT of plastic parts (such as a certain firewall fitting) that I'd love to see replaced with metal. I think we had a pretty good lead for that one, actually.
meyervw Samba Member
Joined: January 29, 2006 Posts: 470 Location: Chico, California
Posted: Tue Aug 26, 2008 8:04 pm Post subject: |
2 problems here. The plastic box helps keep the air cool. More o2. So putting in a metal one can hurt if you are in warm climates. Also the box is on the motor and if it was metal would create a ton of heat. Less O2. Same with a cone folter. You are sucking in hot engine heat. Not good unless its 20 deg F outside. I agree there is room for improvement here though. Just not much. |
bucko Samba Member
Posted: Wed Aug 27, 2008 4:12 am Post subject: |
meyervw wrote: |
I would plum the cone filter to the same outlet as the original snorkle; passenger side fender area. I guess I will start my trek on finding some flexable couplers that will fit over the throttle body opening and the mass air flow unit. Once I have these, I can create a tube of sorts that will route along the passenger side (same as stock) and then elbow to the passenger fender to get the somewhat cooler air intake.
Off I go.... _________________ Current VW drives: 1984 Westfalia
Posted: Wed Aug 27, 2008 7:28 am Post subject: |
That would be good. Just keep the air cool and you will be alright. |
