Slowlow Samba Member
Joined: March 17, 2004 Posts: 4121 Location: Northeast Tennessee
Posted: Thu Aug 28, 2008 6:35 pm Post subject: Do you HAVE to have early Type3 backing plates? |
First off, I did a search but didnt find an exact answer.
My bus has a '68 Beetle tranny and Offset plates. I want to run Early Type three drums, but I really see NO reason why I HAVE to run the matching backingplate.
Looks and seems to me like the beetle backingplates are the same.
Maybe the adjusting holes are different?
Otherwise, I dont know why I HAVE to get the drums and plates..... Right now Im running '68 Beetle backingplates, internals and '73 Thing drums.
Any info is appreciated!
- Sam _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
roberto Samba Member
Joined: December 10, 2002 Posts: 833 Location: West Central Ohio
Posted: Thu Aug 28, 2008 6:39 pm Post subject: |
These are 74 super rear backing plates I used on my brothers bus. |
Posted: Thu Aug 28, 2008 6:43 pm Post subject: |
Was that with Early type three drums on top of them? _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
Posted: Thu Aug 28, 2008 6:54 pm Post subject: |
Early typ 2 with the snouts turned down and the back lip cut back. when I first did my bus. I used the late typ 3 plates. (had the two piece drum)
I am not sure it really matters. I thought the difference is in the back lip of the drum.
Does yours rub or something? |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Thu Aug 28, 2008 7:02 pm Post subject: |
Type 3 drums are larger diameter than Type 1.
You must run Type 3 backing plates if you plan to run Type 3 drums. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Thu Aug 28, 2008 7:08 pm Post subject: |
I stand corrected, I thought that they were only a wider shoe and wider braking surface. |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Thu Aug 28, 2008 10:30 pm Post subject: |
You can use late T 3 backing plates also. The difference is the late one have no adjusting holes but you can drill some. Type 4 (411 and 412) brakes are the same also. _________________ If you`re going to do something, do it right. |
Shortbus Samba Member
Joined: June 16, 2007 Posts: 263 Location: My Happy Place
Posted: Thu Aug 28, 2008 10:32 pm Post subject: |
You can however use later Type 3 backing plates with your early wide 5 drums. I stole all the IRS parts and tranny for my last bus off of a 69 Type 3 (including backing plates) and then ordered new early wide 5 type 3 drums. No issues. _________________ Um... you lost me at "Bay". |
Posted: Fri Aug 29, 2008 5:43 pm Post subject: |
Thanks guys, thats all I needed to hear.
I didnt realize that Early Type3 was bigger than Type 1... but I should have known with the weight difference.
My bus is just fine with the Type 1 parts and Thing drums, but the ass end looks a little wide. I have PLENTY of room in every direction, I just wanted to tuck the tires in a little more...
Thanks for the help guys!! _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
Posted: Sat Aug 30, 2008 3:45 pm Post subject: |
I`m pretty sure that Thing drums go with Type 3 brakes and not Type 1 IRS. They are just wider. If thats the case then just get T 3 drums and that will narrow your track about a half inch each side. If they use T 1 brakes than the best way to go is machining down some early Bus drums. _________________ If you`re going to do something, do it right. |
Posted: Sat Aug 30, 2008 4:17 pm Post subject: |
Im running Thing drums RIGHT now with the same brakeparts as an IRS beetle....
onebadoval56 Samba Member
Posted: Sat Aug 30, 2008 4:27 pm Post subject: |
sam your selling it?
damn you must have found something good _________________ 1955 oval
1956 oval
1960 euro bug
1962 15 window delux
1963 double cab |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
Posted: Sat Aug 30, 2008 4:56 pm Post subject: |
onebadoval56 wrote: |
damn you must have found something good |
?????????? _________________
aeromech wrote: |
in my opinion you don't know shit |
Posted: Sat Aug 30, 2008 4:59 pm Post subject: |
i saw the ad then went back to look at it again and it was gone
1956 oval
1960 euro bug
1963 double cab |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sat Aug 30, 2008 5:57 pm Post subject: |
Bryan67 wrote: |
I`m pretty sure that Thing drums go with Type 3 brakes and not Type 1 IRS. |
i'm pretty sure you are wrong.. type 181 thing drums are used on 4 lug brake setup to get wide 5 bolt pattern. type 3 brakes are not even close to being small enough to fit type 1 brakes. type 3 brakes are huge and humongous compared to any type 1,thing brakes. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Sat Aug 30, 2008 6:14 pm Post subject: |
VWsArent4Hippies wrote: |
Nah, I posted it up for like two minutes and changed my mind....
bill may wrote: |
Bryan67 wrote: |
i'm pretty sure you are wrong.. type 181 thing drums are used on 4 lug brake setup to get wide 5 bolt pattern. type 3 brakes are not even close to being small enough to fit type 1 brakes. type 3 brakes are huge and humongous compared to any type 1,thing brakes. |
I hear that. _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
Posted: Tue Sep 02, 2008 8:33 am Post subject: |
Yeah, I wasn`t sure about the Thing drums. I never saw the need for them on a Bus so never messed with them. Why make the trake wider? Type 3 brakes are the way to go. _________________ If you`re going to do something, do it right. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
sled Samba Member
Posted: Tue Sep 02, 2008 2:45 pm Post subject: |
if you want to tuck, just narrow the torsion and run short axle/short castings.
gets rid of those offset plates too. _________________ drive your split. |
