phatveedub Samba Member
Posted: Tue Apr 13, 2010 6:33 pm Post subject: Re: spreadsheet |
Are you feeling okay?
syncro2x Samba Member
Posted: Tue Apr 13, 2010 6:38 pm Post subject: Billboard |
Face it we are driving billboards. A good slippery rig is .28, a westy is nearly double that @.52. My 86 Syncro with tall tires is a real workout when the wind blows and you crack 100km/hr (60mph). Keeps you awake. |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Tue Apr 13, 2010 6:39 pm Post subject: |
That was interesting, hard to understand but none the less necessary. I was the shiats at Physics and I have a bad attitude about it.
So bottom line, ? close off luggage racks or _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
wildenbeast Samba Member
Posted: Tue Apr 13, 2010 6:59 pm Post subject: Re: spreadsheet |
inkysocks wrote: |
i made a google spreadsheet that calculates these numbers for any given velocity for several types of vanagon body styles.
-i |
Did you check any of the numbers against what VW was claiming in the image above? Is it possible to see the Dehler profi top in your spreadsheet for comparison (since it had the least drag)? I would be curious to see an Adventurewagen top in there if you know how to calculate its drag as well. _________________ - Bill, '93 Eurovan Syncro Weekender (2.5 manual ACU) |
Vanagonner Samba Member
Joined: September 15, 2009 Posts: 506 Location: Broomfield Colorado
Posted: Wed Apr 14, 2010 5:46 am Post subject: |
To really clean it up, several things would need to be done. A well shaped cap over the luggage should give good flow without as much frontal area as a high top. A rear spoiler (like the one linked to above) would help. A pair of flow separators on the sides could encourage the air to spiral into the vacuum behind, and of course a good air dam would help a lot. With an ultra-low HP rig like mine, these kind of things would really help me. I'm working on the cap. _________________ Sage
'82 Westy 1.6 D
the mighty n/a |
randywebb Samba Member
Posted: Wed Apr 14, 2010 11:37 am Post subject: |
one could certainly:
1. improve the Cd
2. better manage the airflow re lift, brake cooling, engine cooling, passenger cabin flow, etc.
3. alter the trailing eddies that attach to the rear of the vehicle
BUT
4. there is no way to escape the fact that you are pushing something about the size of a sheet of plywood down the hwy. _________________ 1986 2.1L Westy 2wd Auto Trans. |
floggingmolly Samba Member
Joined: April 06, 2007 Posts: 1106 Location: San Diego, CA
Posted: Wed Apr 14, 2010 11:46 am Post subject: |
Driving in Baja recently, with a good (20-30 mph) headwind I could not maintain speed in 4th. In 3rd I could stay around 50-55, but shifting to 4th was a gradual decrease to 40 and dropping. I had a load though, and a kayak on top, so not really fair. But the next day, with no wind, I could ride at 65 in 4th when the day before saw speeds nowhere near that. _________________ '85 Wolfsburg Weekender |
iiigoiii Samba Member
Joined: January 05, 2008 Posts: 307 Location: Bay Area, CA
Posted: Tue Apr 20, 2010 11:30 am Post subject: |
on the original subject of noise - the most significant factors would be of course the direct engine and tire/road noise, but also the resonances driven by the engine, tires and trailing vortices shed from the vehicle at speed.
as a non-perfectly-streamlined body (uh can you say 'vanagon'?) moves through air, the body itself periodically sheds little tornadoes of air off of just about every one of the protruding objects (mirrors, rain gutters, trim, antenna, under-body components, etc.) and angles of the vehicle, not just the flat rear of the body. as was pointed out earlier, the energy of the vortices can increase exponentially with speed.
how often these vortices are shed off of each component causes noise. not only does this frequency vary with the shape and size of each component, but...that which the component is attached to. body parts (especially large metal sheets like door skins) and cavities (like the space inside the door) all have their own characteristic resonant frequencies. there are literally hundreds of panels and cavities which could be actively resonating from trailing vortices or tire, road, and engine vibrations.
it's those resonances that greatly amplify the vibrational noise of the component that is driving it. these resonances seem to 'come and go' non-linearly with speed. that's because as the speed of the vehicle changes, the vortex shedding frequency changes; that frequency occasionally will move through the resonant range of some panel or cavity, making it more or less noticeable.
so what? so, moreso than trying to track down the hundreds of vortex generating components, the hundreds of cavities, and the myriad of ways the vortex energy is transferred from one to the other, the most important things you can do to reduce noise is to dampen the resonance of the panels (hence the many samba threads on noise damping materials) and cavities, change your tires, and reduce direct transmission of noise from the engine.
hope this helps.... _________________ 1984 Westfalia Wolfsburg Ed. w/ Subaru EJ22 power |
jerrydog411 Samba Member
Joined: September 28, 2009 Posts: 388 Location: North Vancouver, BC
Posted: Tue May 25, 2010 12:04 pm Post subject: luggage rack cap |
Vanagonner wrote: |
To really clean it up, several things would need to be done. A well shaped cap over the luggage should give good flow without as much frontal area as a high top. A rear spoiler (like the one linked to above) would help. A pair of flow separators on the sides could encourage the air to spiral into the vacuum behind, and of course a good air dam would help a lot. With an ultra-low HP rig like mine, these kind of things would really help me. I'm working on the cap. |
I am really interested in what you find / come up with for the luggage rack "cap", Sage.
Please let us know.
John |
Orbitald Samba Member
Joined: August 12, 2004 Posts: 320 Location: Oakland, CA
Posted: Tue May 25, 2010 3:33 pm Post subject: Re: luggage rack cap |
Quote: |
I am really interested in what you find / come up with for the luggage rack "cap", Sage. Please let us know. John |
A luggage rack cap with a slot for a removable solar panel would be pimp! _________________ '87 Syncro Westfakia, 1.9TD ADE (AAZish), 068 Injection Pump, K03 turbo, 2.5" exhaust, Mercedes nozzles, SAAB Blackstone charge-cooler w/ 800cfm fan, Micro-1000 EGT sensor pre-turbo, boost at about 13psi, 235/70/16 with stock gearing |
thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Tue May 25, 2010 5:18 pm Post subject: |
there is a mechanic named john out there that made each vehicle he owned more a.d. [google, aerodynamic] he said the results were significant. speedway hubcaps, panning the belly, fairings for gaps and spoilers made significant gains in mileage. up to 4 mpg. teflon coating the paint works contributed 1/2 mpg alone.
seems like an inflateable bladder for the rear deck would displace the ball of air we all pull along. wouldnt hurt in collisions, either.
Flushing out the windows would help too. the vanagon is more slippery than she looks, but she has a broad side too. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue May 25, 2010 8:43 pm Post subject: |
OK - this is officially hilarious... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri Jun 04, 2010 9:35 pm Post subject: Re: luggage rack cap |
jerrydog411 wrote: |
Vanagonner wrote: |
Please let us know.
John |
That's the side profile, what do you guys think?
(I have the other pieces too, just haven't put them together yet) _________________ Sage
'82 Westy 1.6 D
the mighty n/a |
Posted: Sat Jun 05, 2010 12:17 pm Post subject: |
why the bump?
is it for clearance of something underneath? _________________ 1986 2.1L Westy 2wd Auto Trans. |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sat Jun 05, 2010 1:34 pm Post subject: |
jackbombay did something similar, came out looking good.
_________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Sat Jun 05, 2010 2:44 pm Post subject: |
The bump is for two things,
1) to provide the most aerodynamic flow for the massive amount of air coming up over the windshield, similar to the new hybrid busses running in Denver. They have that shape for a good reason, I believe. There is a lot of attention given to aerodynamic details on them
and 2) making some room to store stuff under the cap and use the luggage space.
I would love to hear opinions and "best guesses" from pilots and engineers (and others) as to the efficiency of a curve like that vs jackbombay's flattop, which I think is also an admirable design.
p.s.- note that the trailing edge of my cap kicks up a tad, to help get wind and water over the leading edge of the tent seal. _________________ Sage
'82 Westy 1.6 D
the mighty n/a |
levi Samba Member
Posted: Sat Jun 05, 2010 2:53 pm Post subject: |
Since you're asking for guesses, here's mine about the hump on the bus.
If you look at that photo of the bus, you'll see that without the hump it has a sharp edge, which creates turbulence, so the hump eliminates that.
Jackbombay's already has a smooth transition, so doesn't benefit from a hump.
Just my guess. _________________ One of these days I'm gonna settle down,
Posted: Sat Jun 05, 2010 2:57 pm Post subject: |
fluid flow is a lot more complicated than just scaling something from a large bus to your van, beside the shape differences, but have fun
reason 2 is a good one _________________ 1986 2.1L Westy 2wd Auto Trans.
Posted: Sat Jun 05, 2010 2:59 pm Post subject: |
Yeah, it's probably a balancing act between making a rounded transition vs. increasing the profile of the vehicle. I can probably make it less dramatic and still have it work well. I just want it really round up there, like a hightop. And randywebb, I'd love to hear your ideas about it, complicated though it be. _________________ Sage
'82 Westy 1.6 D
the mighty n/a |
