Scott Novak Samba Member
Joined: October 12, 2004 Posts: 1586 Location: Minneapolis, Minnesota
Posted: Sun Sep 07, 2008 9:25 pm Post subject: |
busdaddy wrote: |
I got into it just forward of the valve bore (see RIS's upper pic and imagine a hole in the next gallery below where the holes are drilled, just back from the reinforcing web by the pushrod tube). |
Yes that would be an entry point into the main oil galley. I may just drill and tap my own engine there as I would really prefer to know what my oil pressure is in the main oil galley.
busdaddy wrote: |
This is a single relief engine, no cooler bypass |
The Single Oil Pressure Relief engine case uses a single piston for both the oil cooler bypass and the pressure relief function. I believe that it may be possible that the piston could have been forced far enough downward that the oil cooler is always being bypassed, but may be stuck before it is relieving any oil pressure. Or a spring that was too short, but also too strong, could have been installed. Or the wrong style of piston could have been installed, which would cause a serious problem.
I know that these suggestions are not likely, but you've got a problem that is a bit odd too, as the normal problems don't seem to be there, except for the possibility of an excessively high compression ratio.
Scott Novak |
SRP1 Samba Member
Posted: Mon Sep 08, 2008 8:13 am Post subject: |
Scott Novak wrote: |
This is a single relief engine, no cooler bypass,
Scott Novak |
SRP1 wrote: |
I would look carefully at the relief/bypass piston, if its stuck or sitting down off its seat slightly and in a worn bore oil can bypass the cooler, but still maintain pressure.
busdaddy wrote: |
I felt these points where worth bring back up as you may have a small amount of misunderstanding as to the pistons function on a single relief case. Just trying clear up a likely cause of the problem. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51154 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Sep 08, 2008 8:45 am Post subject: |
I get it, long day yesterday and I had a brain fart.
Plunger and spring were checked last year (not by me), I'm going to give them a good check anyways.
Thanks. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Sep 08, 2008 4:05 pm Post subject: |
Pulled the relief plunger, bore looks good, not too sloppy, definitely not jamming, haven't measured the spring yet but it looks stock, standard grooved plunger.
Interesting thing is the plunger isn't quite contacting the top of the bore, there's a little ridge approx .050 down from the end, it looks like it would still seal against the ridge and even if it isn't it's obviously not effecting pressure. Thinking about a way to remove the ridge while assembled.
I'm considering turning a few thou off the bottom of the plunger groove to make the relief come on a bit before the bypass, it should drop the pressure a bit and send more through the cooler, if it's wrong it's easy to swap a plunger.
Anybody done this?
I want my shop back and this is turning into a lifetime project. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
