volksfahrer.nl Samba Member
Joined: September 18, 2003 Posts: 2128 Location: Delft Holland
Posted: Mon Jan 10, 2011 2:49 pm Post subject: |
Brakes bled, gearbox filled up and battery in place:
Front wheels and (smart-car) tires are on.
Not sure wether I'm leaving them on. First I'm gonna drive a bit to see how high or low I want my bus to sit.
And sometimes it's 1 step forward and 2 steps back
Original upholsterythat I allready repaired in a few spots.
Ripped right under my #ss. Hope I can still fix it.
More of this project:
www.volksfahrer.nl _________________ www.volksfahrer.nl
www.theundutchables.nl
66 panel |
Posted: Sun Jan 30, 2011 10:38 am Post subject: |
Update:
Tried to fix the rip and it came out quite o.k.
It's not 100% invissible but I'm more than happy about it!
Nice red Dutch! Koni shocks all around:
Had some dust specs polished out:
And two spots in the cabine painted that didn't cover 100% at the painter:
Then it was time to finish the airbox in the cabine.
I allready had blasted and painted the internals (+ new seals offcourse)
Engine-time!
With my buddy Leon (from www.volksaddiction.nl) we seperated the case to check the inside.
Alltough this engine (1600 sp) run very well in my bug it turns out it needs all bearings replaced and a new cam.
I'm also having the crankshaft balanced to get a smooth running engine.
While that is beeing done I hope to make a start on the upholstery of
the gargo area!
More on www.volksfahrer.nl! _________________ www.volksfahrer.nl
66 panel |
mclynch310 Samba Member
Posted: Tue Feb 01, 2011 10:06 pm Post subject: |
Awesome build thread |
Posted: Sat Feb 12, 2011 12:16 pm Post subject: |
Passengerdoor done inclusing the original "Smierplan" (greasing scedule)
Can't finish the driversside yet cause I can't open the door far enough
to fit the doorcatch..
Upholstery on the panels for the cargo area:
And the first panels are in place:
Detail of the release to open the hatch from the inside:
Also started on the bulkhead:
66 panel |
67 Shane Samba Member
Joined: September 05, 2007 Posts: 1080 Location: Losing my mind in Charlotte, N.C.
Posted: Sun Feb 13, 2011 12:41 pm Post subject: |
Man your Panel is over the top nice! _________________ -OstKüste-
67 Euro Type 1.
67 SO-42 Westfalia |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Tue Feb 15, 2011 1:33 am Post subject: |
I was planing to use the original filter.
I know the papertube is thinner so I've fabbed somthing up for the rear tin.
What do you mean by heat tube to aircleaner snout? _________________ www.volksfahrer.nl
66 panel |
Posted: Tue Feb 15, 2011 7:25 am Post subject: |
volksfahrer.nl wrote: |
What do you mean by heat tube to aircleaner snout? |
i cliked on picture that shows the sand blasted engine tin going to powdercoaters. the bent tubeb to right of piece that goes on carburator is not 67 and older,used on 68 und newer where filter sits on a pedistal.
there should be a tube with a tab that bolts to head. above it is a hole with plastic ring the cardboard tube passes thru to go to snout on aircleaner. on your air clearner the attachment for this car air preheat is same size tube as the ones from fan shroud to heater boxes. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Tue Feb 15, 2011 7:33 am Post subject: |
I hink I understand what you mean (sorta)
I'll think of something when I assemble it.. _________________ www.volksfahrer.nl
66 panel |
Posted: Sun Apr 03, 2011 10:52 am Post subject: |
More work done in the cargo area:
Details, details, details!!
And done!
Sides and rear corners:
Added some decoration with this decal-panel.
Next up is the roof upholtery which has proven to be a real bitch!
The fabric I use is 100% NON stretch! So when I curve the panel
it starts to wrinkle like a senior citizen.. _________________ www.volksfahrer.nl
66 panel |
Posted: Sun Apr 24, 2011 11:59 am Post subject: |
Headline DONE!!
Creative RnR bed placed (gift from my lovely wife!!).
It proved to be quite a job
As a start the instruction where wrong and it needed to sit on 18mm floor instead of 9mm..
The rear crossmember didn't fit (in bed position the backrest didn't fold down completly)
Had to fit spacers behing the frame or else the backrest would'nt fully go
in sitting position..
And the dumbest thing was that one of the bolts catched the hinge when folding it in to seating position!!
I'd expected it to be better for what it costs.
But now that it's in it is solid as a rock!
66 panel |
clnvwe2 Samba Member
Joined: April 15, 2006 Posts: 878 Location: BBQ grill
Posted: Sun Apr 24, 2011 12:14 pm Post subject: |
Panel looks tight.. I bet your itching to drive her _________________ "Keep your horn on"
Cunado 4 life!!!!!!!
Instagram : Flatkool
WTB- The Brundage Motors Plate frame that Merrpie Pribanic's looking for. |
Sidbus Samba Member
brese73 Samba Member
Posted: Mon Apr 25, 2011 8:12 am Post subject: |
damn im jealous! I want to learn how to weld and do body work! my bus definitely needs everything you did to your panel |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Mon Apr 25, 2011 8:42 pm Post subject: |
Looks great! |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10781 Location: San Diego, CA
Posted: Mon Apr 25, 2011 9:01 pm Post subject: |
Beautiful.........Great attention to detail |
Posted: Sun May 15, 2011 12:47 pm Post subject: |
Engine is done!
Nice and clean
And if it wassen't for me having the wrong diameter pressureplate it would have really been in the bus today...
66 panel |
Saul Koll Samba Member
Joined: September 28, 2008 Posts: 191 Location: Portland
Posted: Sun May 15, 2011 1:55 pm Post subject: |
Amazing and beautiful!! _________________ "I wish you could smell the smell that's coming from the bus"... |
Posted: Wed May 18, 2011 2:27 pm Post subject: |
Thanks!!
Another BIG step was made today...
Hell YEAH!
PS: Sparks you see where from a lose spring on one of the carbon brushes of the generator.
It solved now offcourse. _________________ www.volksfahrer.nl
66 panel |
