Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Fri Sep 05, 2008 9:31 pm Post subject: I did not know this..... |
I stumbled across this website: http://laikamwah.com/aboutus.asp?login=&email=
and found this paragraph interesting:
"We are the only manufacturer in the world of the 34PICT3 solex designed carburetors for Volkswagen aircooled application, as well as the aircooled single port cylinder head." |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Fri Sep 05, 2008 10:57 pm Post subject: |
Maybe now we know who makes the EMPI 34PICT3's. |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Fri Sep 05, 2008 11:09 pm Post subject: |
so now we know who to bitch to |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Sat Sep 06, 2008 8:06 am Post subject: |
So they make single port heads? |
germansupplyscott Samba Member
Posted: Sat Sep 06, 2008 8:35 am Post subject: |
these people make a decent carb. this is a so-called "kafer" 34-pict. there are at least 3 asian made 34-pict3 carbs available and theirs is quite good. it does have an issue with some of the carbs where the float can stick inside the bowl, but if you fix this issue they run quite well.
there is at least one, maybe more, other manufacturers of a chinese 34-pict. the last ones we ordered from our supplier were supposed to be this kafer one, but a different carb came in, made in china and the quality was awful. these ones had no markings on the side of the bowl, a terrible accelerator pump linkage, the choke butterfly stuck and the float was lousy. we sent them back because they were supposed to be the kafer ones. _________________ SL |
