Post your fog light/driving light pictures?
erdonline
erdonline is offline
PostPosted: Sun Sep 07, 2008 9:20 am    Post subject: Post your fog light/driving light pictures? Reply with quote
I've got two Vanagons- one with round and one with rectangular headlights. I'd like to add fog lights and driving lights to each, and have been looking for pictures to get ideas on what I want to add to each and on which part of the bumper. I've searched here and found some pictures here and there but can't find one thread with just this topic.
I bought a set of Hella 500FF round driving lights on clearance at Wal-Mart for $45, complete with covers, relay, wiring harness and switch. I think I'll put those on the '85, but I haven't decided exactly where and how I'll mount them in relation to any fog lights I'll add.
There are so many possibilities- round or rectangular, round with the round headlights, or round with rectangular for contrast- it makes my head spin.
So I'm looking for pictures for ideas.
Thanks,
Ed in CT
1621
1621 is offline
PostPosted: Sun Sep 07, 2008 10:10 am    Post subject: Reply with quote
If I remember correctly, driving lights should be placed a little higher in order to cast a good beam down the road, hence the SA grill set-up. Fog lights should be placed lower, or closer to the road, for optimal results. You've probably Googled this information already, but I've found this website to be helpful with automotive lighting information.
http://www.danielsternlighting.com/
As for the looks, I like the round with round, rectangular with rectangular look as well. There's an 86 Weekender around the corner from me with the SA (Projectzwo?) lower grill rectangular fog lamps that looks sharp. I went with the Hella 500 fog lights mounted above the bumper and essentially aligned with the outer edges of the lower grill. You can get the idea by looking at my avatar. The lights are nice for inclement weather.
Also, consider picking up a factory fog light switch for the dash. I know Van-Cafe carries them, but I believe they can be found in other VW models in the junkyard.
'85 Westy
wasserbox
wasserbox is offline
PostPosted: Mon Sep 08, 2008 10:07 am    Post subject: Reply with quote
PIAA driving lights.
If you pull off the bumper skins, there are 2 spots on the bumper mount that are ideal for running wires and mounting the lights.
rblake3
rblake3 is offline
PostPosted: Mon Sep 08, 2008 12:44 pm    Post subject: Reply with quote
I put Hella 530 series lights below the bumper. Works perfectly for actual fog/rain/snow and illuminating the sides of the road for deer watch. Lower is better for pure fog lighting. The only drawback is reduced clearance for off road terrain. Every dirt road I have been on has not been an issue. If you use good disconnects, I suppose they could be made to be removable in a jiffy.
Also have the acrylic clear shields installed for lens protection.
90 Vanagon Carat Wander Wagon
88 16v GTi
01 1.8T Beetle
94 Miata
Vanagon H4 E-Code Lighting Upgrade page
doyll
doyll is offline
PostPosted: Tue Sep 09, 2008 8:00 am    Post subject: Reply with quote
A couple other problems with low mounting are:
* water spashing up on hot lense and cracking/breaking it when using them in wet conditions.
* rocks/gravel flying up and breaking them.
Have had both happen.... and it gets expensive.
sunshine_norway
sunshine_norway is offline
PostPosted: Tue Sep 09, 2008 1:28 pm    Post subject: Reply with quote
My brother in laws`Vanagon GL
I`m going to install similar Bosch on my Crew-cab (DOKA). If you install them with extra relays, you can put in H3 1oow in each Very Happy
View user's profile Send private message Visit poster's website MSN Messenger Classifieds Feedback
Ryan Alfonso
Ryan Alfonso is offline
PostPosted: Tue Sep 09, 2008 1:37 pm    Post subject: Reply with quote
P'zwo's are the bomb. NLA tho', dagnabbit.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
rs4-380
rs4-380 is offline
PostPosted: Wed Sep 10, 2008 7:48 am    Post subject: Reply with quote
I prefer round if they are sitting on top of the bumper and clustered, rectangular if they are below the bumper, regardless of the van headlight shape.
Considering I didn't want to reduce the approach angle, I went all round.
Dave
87 EJ25 Syncro GL
redtail
redtail is offline
PostPosted: Wed Sep 10, 2008 9:49 am    Post subject: Reply with quote
Did you have to install an upgraded alternator to run all those lights?
rs4-380
rs4-380 is offline
PostPosted: Wed Sep 10, 2008 11:10 am    Post subject: Reply with quote
No, when they are all on (which isn't often) it's 4 55w bulbs and 1 110w bulbs (everything is relayed), that's 330w, or about 27.5 amps, people with big stereos and amps pull more than that. The stock subaru 120amp alternator has no problems with that, a 70amp alternator would most likely run them fine as well.
and fwiw, the two lower outers are 55w amber foglights, the two upper lights are 55w driving beams and the lower center is a 110w driving beam that comes on with the high beams.
Dave
87 EJ25 Syncro GL
kevtherev
kevtherev is offline
PostPosted: Wed Sep 10, 2008 12:57 pm    Post subject: Reply with quote
straight forward driving lamps.. 55watt halogen OE VW (lenses match the headlights)
next to my mates syncro... (drool)
erdonline
PostPosted: Wed Sep 10, 2008 3:34 pm    Post subject: light pics Reply with quote
Thanks for the pics so far. I'm going to mount round Hella 500 driving lights on the top of the bumper of my '85, and I think amber rectangular fog lights below. Now I just have to decide if they will go above one another, or one set inside and one set outside, etc.
After I got the 55 watt Hellas, I found a set similar Hellas (the 1900 series) with 100 watt bulbs. I was thinking of mounting them on the '85 instead, as driving lights, and still using the fog lights.
On the '87, I was thinking of using 55 or 100 watt driving lights to come on with my low beams. I'd do this for two reasons. One, just the stock low beams are pretty dim, and two, as far as I know, there is a law that states that you cannot have more than four "main" lights on at any one time. A law-enforcement person in CT told me this about ten or 15 years ago, so something may have changed.
Keep those pics coming. We can all use some ideas.
Thanks,
Ed in CT
bibbylauer
bibbylauer is offline
PostPosted: Wed Sep 10, 2008 6:13 pm    Post subject: Reply with quote
Hella's on 85 Westy crossing a stream at Silver City ID.
Found these worked great during our summer trip out west. Good lighting helped us avoid a bison at the last second in South Dakota while hunting for a campground.[/img]
85 Westy
Jon_slider
Jon_slider is offline
PostPosted: Thu Sep 11, 2008 6:46 am    Post subject: Reply with quote
I agree. You should upgrade them:
Van Cafe sells a kit including relays to replace the stock round lights with Euro code Hella' lenses and upgraded to 80w low beam, 100w high beam.. HIGHLY recommended
euro lenses
http://www.van-cafe.com/vanagon_parts.jsp?pa=p&p=312505831
upgraded wattage H4 lamps
http://www.van-cafe.com/vanagon_parts.jsp?pa=p&p=1020725469
relay
http://www.van-cafe.com/vanagon_parts.jsp?pa=p&p=1267852675
total watts on low, 160, on high 200, with H4 lamps, and Euro lenses,
stock is 110w on low, 130w on high, with H3 lamps in a non euro lens
IF after that you think you need more light, upgrade to the South African Grille, which adds another pair of 80w H4 high beams
total watts on high, 360, compared to stock 130watts on high beam
IF after that you need more light, its probably a FOG light you will be wanting.
this kit from Van Cafe includes lenses, lamps and relays, and can be setup as fogs instead of driving lights
http://www.van-cafe.com/vanagon_parts.jsp?pa=p&p=1341526804
Dogpilot
Dogpilot is offline
PostPosted: Thu Sep 11, 2008 11:07 am    Post subject: Reply with quote
The Hellas are great and if you can find a projectwo kit for the fogs, the install is easy. If you put all the light on, you are indeed a small star on the horizon. The entire package does draw some power. I kind of like a mix of square and round, but I am not the mavin of style.
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
erdonline
PostPosted: Thu Sep 11, 2008 12:36 pm    Post subject: lights Reply with quote
This is exactly what Wal-Mart has for $65. It's $90 at Van-Cafe. Wal-Mart kit includes the same stuff- relay, harness, switch, covers.
Ed
Jon_slider
PostPosted: Fri Sep 12, 2008 12:13 pm    Post subject: Reply with quote
Low beam, 160 watts from Hellas with H4's
Hi beam, 360 watts, South african grille
pictures taken while moving, one after the other, non scientific, shaky, and not in exact same spot on the road, but, I think you get the idea
MarkE
MarkE is offline
PostPosted: Sun Sep 14, 2008 8:43 pm    Post subject: Reply with quote
Hella 500's. I removed the factory plastic caps from the bumper and installed the lights in the factory-drilled holes Very Happy Too easy. It currently has a lighted-toggle. I have a Mk1 fog-light switch somewhere, so this will do for now until I find it. They work great on the highway. Most impressed Very Happy
1984 Vanagon GL Westfalia
2000 Toyota 4Runner SR5 V6
erdonline
PostPosted: Sun Sep 14, 2008 9:56 pm    Post subject: light pictures Reply with quote
MarkE, are those fog lights or driving lights you've got on there?
Also, are those "alternative" round headlights?
Ed
foodeater
foodeater is offline
PostPosted: Sun Sep 14, 2008 10:08 pm    Post subject: Reply with quote
I dont know Dogpilot that is one sexy van you got there
If you really want the Projektzwo lights the german ebay (Ebay.de) is the place to get them. But they will cost you quite a bit of $$$, and dont forget to ask if they will ship to the states, and the cost of it before you bid.
89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
