madspaniard Samba Member
Posted: Wed Sep 10, 2008 8:19 pm Post subject: 15" spare tire in clam shell carrier...will it fit? |
Hi there,
I'm still a newby to the westy world. Changing to 15" Rhein wheels and steel spare tire. Mounting Hydroedge 215/70/15 tires. Will the spare tire fit in the clam shell original carrier? what about de-inflated? What about my friend's 215/75/15?
Thanks a lot for your help |
1621 Samba Member
Posted: Wed Sep 10, 2008 8:24 pm Post subject: |
I didn't have any luck with that so I took the easy route and used the larger spare carrier from Van-Cafe down in Santa Cruz. If you search through the old threads though, I'm sure you will find some good solutions. Try SPARE and CARRIER and see what you come up with. _________________ '85 Westy |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Jon_slider Samba Member
Posted: Thu Sep 11, 2008 6:08 am Post subject: |
I dont think a 15" rhein will fit in the clamshell, but if you dont have a syncro, a steel 15 as a spare will fit
the burley tire carrier only works on Syncro's (not on 2wd vans). I dont know if you have a 2WD or a Syncro.
for a 2wd, I recommend the Michellin Agilis, rated for a light truck, as a better choice than the Hydroedge, rated for a passenger vehicle.
For a Syncro I recommend the BFG AT KO in 215/75/15, but be aware it will rob you of 10% of your power, because its 10% bigger than stock.
and I agree the Van Cafe bent wire carrier is a great option for 15" wheels |
Westy-Life Samba Member
Joined: June 24, 2008 Posts: 178 Location: The Road or Calgary AB
Posted: Thu Sep 11, 2008 9:56 am Post subject: |
I am running 215/70/16's on my Westy and I have the spare sitting in the original place.
I removed all the original pan and weird hanger bars. Then I simply used a 2" wide piece of steel with the proper bends. It holds it in place perfectly and does not rub on the shifter or coolant lines.
The tire fits snugly between the frame rails.
Cheers!
Dave _________________ 86 Westfalia with 03' TDI Auto trans |
kevinm Samba Member
Joined: September 08, 2008 Posts: 117 Location: Minneapolis, MN
Posted: Thu Sep 11, 2008 8:03 pm Post subject: |
The Rhein will fit into the clamshell spare, but only with a whole lot of pressure on the clamshell lip to get it close enough to line up the retaining bolt.
I would not recommend trying this. The problem I found is that the face of your nice new alloy wheel will get scratched up by the top side of the clamshell, as it is not shaped to provide space around the face of the wheel.
Reducing inflation does not seem to help. I believe the van-cafe carrier will work and will try it this weekend.
- Kevin |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9620 Location: Western WA
Posted: Thu Sep 11, 2008 8:44 pm Post subject: |
The spare tire cavity has a lot of flanges, weldments and other non-precise features protruding into it. It is very reasonable that the cavity size could vary by 1/2 inch from van to van!
And crash damage might affect it too.
On mine, ----->if the cavity happened to be 1/8" smaller------> the (new) BFG tire probably would not fit. Its reasonable to assume that a BFG A/T KO 215R75X15 could fit in some Syncros and not others. Sorry I have never tried to put a 15" in a 2wd, sorry if this stuff does not apply.
FWIW, my BFG A/T KO 215R75X15 on 6" wide Audi wheels, fits perfectly in my syncro.
Photos here http://www.thesamba.com/vw/forum/viewtopic.php?p=2357729#2357729
Tom _________________
....KTMs, GasGas, SPOT mtb
Posted: Thu Sep 11, 2008 8:52 pm Post subject: |
thanks for all the good info. Since I don't have a lot of time to do mods before my trip to Baja I decided to buy the van-cafe carrier.
Thanks
Enrique |
Posted: Fri Sep 12, 2008 8:54 am Post subject: |
> FWIW, my BFG A/T KO 215R75X15 fits perfectly in my syncro.
yes, but you cut and modified your clamshell
that tire will NOT fit in a stock clamshell, dont you agree?
The burley motorsports modified clamshell will work, as does yours, modified, not stock |
Posted: Fri Sep 12, 2008 9:01 am Post subject: |
Jon_slider wrote: |
I currently have LT tires and really don't like them, too rough of a ride, lots of people are mounting P tires, doesn't seem to be a big deal, plus the 215/70/15 hydroedge seems to be a robust tire and I believe is rated something like 98S? |
Posted: Fri Sep 12, 2008 9:42 am Post subject: |
yes, OK
fwiw, there are people who disagree with the use of Hydroedges on Vans
lets just compare, and btw, the Agilis is nothing like a BFG in terms of highway ride. You mention you dont like the ride on your current LT tires.. you dont mention which ones, but, the Agilis is smooth as butter, I drive it on my 2WD van and LOVE it.
Agilis is load rated higher than Hydroedge,
Agilis can be inflated higher (implies stronger sidewall construction to me)
Agilis weighs less, always a good thing, IF the tire is strong enough. Vans should use at least C rated tires, the Hydroedge is not C rated.
Agilis turns 802 revolutions per mile, closer to stock than the 782 revolutions of the Hydroedge. Stock rotations is 819, so the Agilis is just 2% taller than stock size, while the Hydroedge is 5% bigger than stock.
That means with Hydroedge you will have LESS power to climb hills in 4th gear than with the Agilis, and you will have to shift into 3rd gear sooner on a hill climb with the Hydroedge.
imho, there is absolutely nothing a Hydroedge doese better than an Agilis. And personally, I find the Hydroedge tread pattern unappealing, actually, pretty stupid looking.. Its a speacialty tread for rain. Do you have lots of rain? My Agilis handle rain very very well btw.
enjoy whatever you get
Jonathan
http://www.tirerack.com/tires/Spec.jsp?make=Michelin&model=Agilis&tirePageLocQty=
Agilis
205/65R15
Load Index 102/100T C
Max Load 1875 lbs.
Max. Inflation Press. 54 psi
Tire Weight 24 lbs.
Revs Per Mile 802
http://www.tirerack.com/tires/Spec.jsp?make=Michelin&model=HydroEdge&tirePageLocQty=
MichelinHydroEdge
215/70R15
Load Index 98T SL
Max Load 1653 lbs.
Max. Inflation Press. 44 psi
Tire Weight 26 lbs.
Revs Per Mile 782 |
Dogpilot Samba Member
Posted: Fri Sep 12, 2008 10:53 am Post subject: |
Other have seen this before, but I fabbed up this mount out of some sheet steel, scrap strapping and a piece of aluminum angle to make a strap mount. I fit a 16" in the clamshell location. I used the original mounting locations for the rear hinges and the angle screwed up exactly like the original. It must have cost me $5 to make, and it has been on for almost two years now with no issues.
_________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Posted: Fri Sep 12, 2008 12:29 pm Post subject: |
Thanks a lot for the info Jonathan
Jon_slider wrote: |
you dont mention which ones, but, the Agilis is smooth as butter, I drive it on my 2WD van and LOVE it. |
I can't remember the maker of those LT tires I had on so probably some cheap ones
Jon_slider wrote: |
I find the Hydroedge tread pattern unappealing, actually, pretty stupid looking. |
Have to agree with you on that one.
I guess what I liked about the hydroedge is the braking ability, thread life, and being a good all around tire. I tried to steer away from LTs for the reason I mentioned above but that could be biased due to the poor quality of the ones I had on.
Thanks for the info Jon. |
Sodo Samba Member
Posted: Fri Sep 12, 2008 7:49 pm Post subject: |
Jon_slider wrote: |
> FWIW, my BFG A/T KO 215R75X15 fits perfectly in my syncro. yes, but you cut and modified your clamshell
More clarification:
The BFG A/T KO 215R75X15 cannot possibly fit into the Syncro spare tire cavity with a STOCK clamshell.
The cavity itself is just barely big enough,,,,, but the clamshell prevents the tire from fitting, thus it must be trimmed. I don't know if a Syncro clamshell is a special part but now that I have big brakes I'm never going back, so I cut mine.
The Audi wheel that I used, is 6" wide. A 6.5" or 7" wheel likely requires either 1/2" or 1" more downward space in the 'hinge design'.
On the plus side, a wider wheel would spread the carcass out thus would produce MORE clearance at the top, between the tread edge and the steering shaft. Probably 1/4" or 1/2" MORE clearance than mine, which is less than 1/8". At least that problem solves itself....
........there's no end to the details is there?
....KTMs, GasGas, SPOT mtb |
Posted: Fri Sep 12, 2008 8:48 pm Post subject: |
Jonathan,
the LT tires I had on were Wildcat Radial LT.
BTW, I stopped by my local Costco, asked for the Agilis 205/65R15. Didn't have them in stock so the guy called Michelin, the answer was this tire has been discontinued. Is that true? |
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 324 Location: Chicago, IL
Posted: Mon Aug 31, 2020 11:49 am Post subject: Re: 15" spare tire in clam shell carrier...will it fit? |
I wanted to report back as I just recently solved the riddle of getting a 15" alloy rim in the clamshell with a 205/65-R15 Michelin Agilis Cross Climate on a GW 15" alloy rim.
The thing that was most surprising to learn was that the width (from frame rail to frame rail) was actually more than the depth (From rear crossmember to the front indent.) Most of the research I did here prior to attempting this led me to believe that the problems would be overall height and width.
My challenge was height and depth. I also thought it would be helpful to post some photos of actual measurements, as this seems to be lacking as well. (Note: This is from a 2wd 85 westy and the shifter box is 5 speed bus. YRMV)
As you'll see, the width is just over 27" inches and the depth is ~25".. As you can probably also see, I modified the clamshell hinge and removed the retaining bars (those curvy bars that sit above the tire and act as the hinge pin as well. But I found out that I didn't need to modify the clamshell at all with this wheel. So, I reverted back to just a bolt running through to act as the hinge. The clearance I got from removing the retaining bars was enough. Went from 7.5" tall to 8.5" at the shortest point from the clamshell, which became the shifter box.
My tire is 8.5" x 25.5"
So, I ended up needing to put the tire up on the crossmember in the back (like the original design.) I'm not sure you could get anything in there that is BOTH +25" in diameter AND more than 8.5" - 9" wide. This is because anything +25" will have to sit up on the crossmember and dropping the clamshell hinge doesn't really help you anymore.
Here's the final answer for me. Take out the retaining bars, put bolts in place to secure the clamshell in the original position. Buy a new M12x1.5 bolt. I think the one I got was 80mm and a ~2" spacer. Still waiting to hear from BenT Syncro about the extended latch.
Hope this helps someone doing this in the future.
PS. Yes, I'm aware that I have a directional tire as a spare. One of the bummers of my process was realizing that when they were mounting the tires and the tech asked which direction I wanted the spare. Just had never even crossed my mind until I was past the point of no return. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
Sodo Samba Member
Posted: Mon Aug 31, 2020 12:11 pm Post subject: Re: 15" spare tire in clam shell carrier...will it fit? |
Quote: |
PS. Yes, I'm aware that I have a directional tire as a spare. One of the bummers of my process was realizing that when they were mounting the tires and the tech asked which direction I wanted the spare. Just had never even crossed my mind until I was past the point of no return. |
Yep there is always one Vanagon owner who finds himself at the racetrack, a contender for first place, who has a “dohhhhh!! moment”, remembering that theres a backwards spare on the van. And that simple oversight may have cost him the championship! Dang!!
The other 99.999%, bumbling around in their antique RVs, checking AAA status before crossing that 100 miles distance from home..... no worries. _________________
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Posted: Mon Aug 31, 2020 12:23 pm Post subject: Re: 15" spare tire in clam shell carrier...will it fit? |
Sodo wrote: |
Yep there is always one Vanagon owner who finds himself at a racetrack, a contender for first place, who has a “dohhhhh!! moment”, remembering that theres a backwards spare on the van. And that simple error cost him the championship! Dang!!
The other 99.999%, bumbling around in ther antique RVs, checking AAA status before venturing more than 100 miles feet home..... no worries. |
The directional issue is not an issue on dry pavement for a Vanagon. Where it can cause a problem is in heavy rain, water on the pavement, since it will not pump the water away properly and it could hydroplane in extreme situations. YMMV. _________________ Dave O
The Western Syncro build
Sodo Samba Member
Posted: Mon Aug 31, 2020 1:24 pm Post subject: Re: 15" spare tire in clam shell carrier...will it fit? |
Ok there’s that...hydroplaning, driving fast in heavy rain conditions.
I bet it would take some effort, in a van, in worst conditions, to notice the subtle difference. _________________
montanasurfer Samba Member
Joined: March 06, 2014 Posts: 319 Location: United States
Posted: Fri Jul 07, 2023 7:13 pm Post subject: Re: 15" spare tire in clam shell carrier...will it fit? |
I decided to do this. I bought a Falken Sincera SN250 A/S All- Season Radial Tire-205/65R15 99H XL-ply tire on a whim and mounted it to my spare GW 15x7 wheel.
The good news is that it fit! I did have to remove the retaining bars and use bolts as hinge pins. I had the spare tire carrier that came equipped on vans running the 205/70R14 97R's. It had a longer tab at the front where the bolt secures the spare tire carrier. I was actually able to get the bolt in and the spring catch to latch! However, I couldn't get the bolt fully tightened down so I used an old radius rod nut as a spacer between the tab and the body.
There are two problems with this that I think I can live with. At full inflation, there is very slight pinch between happening to one of the radiator hoses. I think I may be able to push it out of the way and it will be a non-issue. The only other issue is that when I push the shifter down to go into reverse, the shaft hits the tire. It still goes down low enough for me to get past the gate to enter reverse. Tire deflation may alleviate both of these issues.
Now I have a "donut" style spare and no need for a spare tire carrier! I'm stoked. I can buy me some GW Rear Disc Brakes now! I'm stoked. _________________ 1987 Vanagon GL - Wolfsburg Edition |
