turkishgecko Samba Member
Joined: February 28, 2008 Posts: 68 Location: istanbul
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Thu Sep 11, 2008 11:59 pm Post subject: |
Do you mean the back-up light fuse? Originally they used a special clip to secure the fuseholder. You don't see those clips very often these days though. The 74 Owner's manual has a picture: (click on the picture for a full-size view of it)
Posted: Fri Sep 12, 2008 4:21 am Post subject: |
thanks.do you know how to find the clip? |
bon2198 Samba Member
Joined: August 04, 2008 Posts: 1969 Location: Nashville, GA
Posted: Fri Sep 12, 2008 5:23 am Post subject: |
i'm not sure if they sell that actual clip anymore or not. you may ask your local VW dealer or pay a visit to some junk yards. _________________ 1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
"It's better to be hated for what you are than loved for what you are not"
At the end of the day it's YOUR car so do what YOU want to it. |
Posted: Fri Sep 12, 2008 8:03 am Post subject: |
Another note - earlier bugs had the fuse above the generator, as shown by the black arrow in the middle picture here:
Well I wanted one of those for my 62.
I had added backup lights and had just been using the wiring harness hold-down clip on that side to secure my fuseholder. But it was wearing out, so I wanted some kind of clip. Either style, I think one type requires a small hole in the fan housing to insert the clip, and the other has a 6mm hole to bolt beneath the coil mounting.
I dug around the VW salvage yard I used to work at looking for such a clip a couple of years ago and could not find one.
I should have posted a WTB (wanting to buy) ad on TheSamba Classifieds though, I'm sure one would have turned up. One style just poppped up on a quick search:
http://www.thesamba.com/vw/classifieds/detail.php?id=607991
But what I ended up finding though, was a solid metal clip that was big enough to hold the fuseholder after some bending. I then used a step stud (actually a valve cover mounting stud from a VW Golf) and a couple of M6 nuts and washers to mount in place of my top right generator-to-shroud bolt. This is what it ended up looking like:
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
ScottK Samba Member
Joined: August 28, 2004 Posts: 1748 Location: Avilla America
Posted: Fri Sep 12, 2008 8:26 am Post subject: |
Didn't I post that same link just above? |
ScottK Samba Member
Posted: Fri Sep 12, 2008 8:28 am Post subject: |
Crap.... Sorry. |
Posted: Fri Sep 12, 2008 3:21 pm Post subject: |
thanks |
swharris Samba Member
Joined: September 10, 2010 Posts: 502 Location: N. Orange County
Posted: Tue Jun 30, 2020 4:02 pm Post subject: |
Only a 12-year-old thread (;-P ), but I have a '67 (very original) that I pulled the motor out to reseal and clean up. I remember disconnecting the fuse to pull it. Months later, finally, the motor went in but to my "horror" I can only find one side to the fuse holder. I'm hoping I did not bury the other end behind the new tar board...lol. Does one side go to the coil and the other side back around and down to the switch on the trans? Maybe I've just lost the "coil end" of the fuse holder??
Thanks for any help Everett!
ooh, I just found a pic of the motor before I pulled it. Hey, it even has the "clip". Now to find that. Haha.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Tue Jun 30, 2020 4:52 pm Post subject: Re: inline fuse holder |
The "hot" wire with the inline fuse comes from coil positive terminal #15 and goes to the reverse switch at the front of the transmission. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Jun 30, 2020 8:22 pm Post subject: Re: inline fuse holder |
Cusser wrote: |
The "hot" wire with the inline fuse comes from coil positive terminal #15 and goes to the reverse switch at the front of the transmission. |
Thanks. I must have put the half of the fuse holder with the wire to the coil in a box somewhere. I appreciate the fact you are monitoring 12 year old threads. ;-P |
ricaroo Samba Member
Posted: Wed Jul 01, 2020 11:01 am Post subject: Re: inline fuse holder |
Hi everyone,
What amp in-line fuse for #15 wire from fuse block to coil?
Rick _________________ 1971 Standard Beetle 2 dr Sedan 1600dp |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Wed Jul 01, 2020 11:49 am Post subject: Re: inline fuse holder |
ricaroo wrote: |
Hi everyone,
Rick |
Did you see this upthread?
_________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Cusser Samba Member
ricaroo wrote: |
Hi everyone,
Rick |
8-amp from factory _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Jul 01, 2020 12:32 pm Post subject: Re: inline fuse holder |
Q-Dog wrote: |
ricaroo wrote: |
Hi everyone,
Rick |
Q-Dog, yes I did however, it doesn’t mention the #15 Wire from the Input side of the fuse block directly to the coil...
I found my answer a few minutes ago in a older post where it indicated to use either 15amp or 20amp in-line fuse for this application.
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Jul 01, 2020 1:03 pm Post subject: Re: inline fuse holder |
I’ve been using an 8 amp German fuse in this application for years, and no problems. That’s what my Owners Manual says, anyway.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Wed Jul 01, 2020 1:13 pm Post subject: Re: inline fuse holder |
Tim,
That’s the same size fuse Cusser indicated as well. What year is yours, mine is a 10 fuse block 71 and it doesn’t reference it. I looked at a 12 fuse block 71 and it says un-fused connection
My decision is to try an 8amp fuse.
Thanks to everyone for the help.
Posted: Wed Jul 01, 2020 1:59 pm Post subject: Re: inline fuse holder |
Rick, I have the 12 fuse bank. I can’t see why the fuse from the #15 coil connection to the transmission switch would be any different, from year to year, regardless of how many other fuses that one model has, compared to another.
The only fuse I have that is over the 8 and 16 amp varieties is a 20 amp modern fuse that I have at a hard-start relay. Other than that, I follow what the Owners Manual says. It’s odd that yours doesn’t mention the size of the fuse.
Richard O'Brien |
