bobwires Samba Member
Joined: March 27, 2008 Posts: 11 Location: Ketchikan, AK
Posted: Tue Jun 24, 2008 11:48 pm Post subject: air bags on a VW? |
I'm looking into air bags for this car. I got it with the front lowered a bit, and I need to bring the back down a notch or so to level it out, but I'd ultimately like to bag it. anybody know of kits or something for these cars? I don't think I'll do it if I have to engineer the whole new suspension myself - I'm not patient enough for that.
any info? thanks _________________ www.bobwires.com |
vwfye Samba Member
Posted: Tue Jun 24, 2008 11:56 pm Post subject: |
sell ya mine... completely new and unused!
see the price in my sig below! _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Dryheave Samba Member
Joined: June 08, 2008 Posts: 52 Location: Corpus Christi, TX
Posted: Wed Jun 25, 2008 6:35 am Post subject: Re: air bags on a VW? |
bobwires wrote: |
any info? thanks |
www.airkewld.com |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Wed Jun 25, 2008 7:21 am Post subject: Re: air bags on a VW? |
Dryheave wrote: |
bobwires wrote: |
any info? thanks |
www.airkewld.com |
Except he said he didn't want to do enineering (a lot of work) and that system requires welding Not what I'd recommend. _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Posted: Wed Jun 25, 2008 7:37 am Post subject: |
Just trying to throw out some options. _________________ Click to view image |
Dirty Hippie Samba Member
Joined: July 19, 2007 Posts: 189 Location: Huntsville, Alabama
Posted: Wed Jun 25, 2008 8:02 am Post subject: |
I thought airkewld had a bolt on kit for type 3s. I know someone does. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Jun 25, 2008 8:07 am Post subject: |
The DDB has one. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Wed Jun 25, 2008 8:10 am Post subject: |
Parts Catalog
Home » Air Ride Kits Type 1
#2901 1949-1968 Type 1 & 3 Rear BOLT ON Air ride kit
We just made it simpler to make your kit. First select the options you would like with this kit on the right and add it to your cart. Then type in your billing and shipping information and it will give you shipping options depending on how fast you want it there. Please understand, these kits are made to order so please be patient.
This kit fits all 1955-1968 type 1 beetle's and Ghia's. If your ride is already done and you want air ride still, Our bolt on kit is what you need. It can handle the power you want to throw at it as well. You will need to drill 10 holes in the factory spring plates as well as notch them to allow the car to get down as low as possible. Bolt on design allows you to completely install in in less than a day.
"Pic 1" Heater tubes need modifying with this kit.
Here are some links to some kits we installed."Kit 1" "kit 2" "kit 3" "kit 4"
Here is a you tube "video" on the lift of this kit.
This kit is designed for higher horse power car but can even work for the 25HP. On split cars, custom shock mounts are needed. Not included in the kit but are recommended to purchase are the polyurethane spring plate bushings made by EMPI or Bug Pack. This kit can work with a narrowed(shortened) or lifted transmission as well. Slight mods needed.
The kit contains the following; 2 bags, 2 shocks, 2 lower bag mounts(Laser cut, bent and welded), 1 upper cradle(this goes under the transmission, jig welded for accuracy), upper cross member, hardware, fittings & templates. This kit is slightly higher in price due to the labor involves in welding. Each kit is made to order. _________________ Click to view image |
Posted: Wed Jun 25, 2008 8:11 am Post subject: |
from airkewld website. Bolt on _________________ Click to view image |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Wed Jun 25, 2008 8:27 am Post subject: |
vwfye wrote: |
see the price in my sig below! |
"Lead us not, into temptation,,,,," _________________ Everything known to man has been written.
Readers are Leaders! |
vwfye Samba Member
Posted: Wed Jun 25, 2008 8:33 am Post subject: |
i need to sell it to fund the race car's completion... TEMPT, TEMPT, TEMPT! _________________ 64 No'back Speedster "Pearl"
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Wed Jun 25, 2008 10:05 am Post subject: |
Dryheave wrote: |
Parts Catalog
The kit contains the following; 2 bags, 2 shocks, 2 lower bag mounts(Laser cut, bent and welded), 1 upper cradle(this goes under the transmission, jig welded for accuracy), upper cross member, hardware, fittings & templates. This kit is slightly higher in price due to the labor involves in welding. Each kit is made to order. |
this kit is only bags in the back, and monroe style air shocks in the front. not a good set up. I would buy the DDB kit from Fye _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
burgandysquare Samba Member
Joined: October 10, 2007 Posts: 434 Location: San Diego, CA
Posted: Wed Jun 25, 2008 10:41 am Post subject: |
Air bags? lol
_________________ 1968 Volkswagen Squareback |
vwfye Samba Member
Posted: Wed Jun 25, 2008 10:56 am Post subject: |
do you see how rusted that doka was? _________________ 64 No'back Speedster "Pearl"
Posted: Wed Jun 25, 2008 12:25 pm Post subject: |
Erik G wrote: |
Dryheave wrote: |
Parts Catalog
this kit is only bags in the back, and monroe style air shocks in the front. not a good set up. I would buy the DDB kit from Fye |
Like I said before, I was just trying to give some options. I would definitely prefer to have front and back bags as well. _________________ Click to view image |
Posted: Thu Jun 26, 2008 12:22 am Post subject: |
cool thanks for the sources - does anybody have any pros on the welded kits? not just cons? just curious.
VWFYE - I'd love to jump on that, but I just can't right now. my shop is being sold (I think) so I'll have to wait till the dust clears after that. thanks for the offer though.
I had on clue DDB made a bolt on kit - for that matter anybody! I'm glad it exists. I don't mind welding, but I do fear 'engineering'. I didn't want to have to make new arms and remove the stock tension rods and start experimenting. _________________ www.bobwires.com |
djsun Samba Member
Joined: March 22, 2005 Posts: 255 Location: Portland OR.
Posted: Thu Jun 26, 2008 10:59 pm Post subject: |
I have the Bolt on kit, it required a little tweeking and Im sure the DDB folks will work with you on the parts that need welding.
Check the vid of my car, Soon to have dropped spindles to go even lower.
_________________ ____________________________________________________
Video of the car in action
http://www.youtube.com/user/djsunproductions |
Posted: Fri Jun 27, 2008 12:29 am Post subject: |
that video just made up my mind - I'm getting bags!!!
thanks! _________________ www.bobwires.com |
sundog kid Samba Member
Joined: May 24, 2005 Posts: 268 Location: Grande Prairie, Alberta, Canada
Posted: Fri Jun 27, 2008 9:56 am Post subject: |
bobwires wrote: |
thanks! |
x2
I have always wanted a square on air. Anyone have a DIY install write up with this kit? |
Erik G Samba Member
Posted: Fri Jun 27, 2008 10:07 am Post subject: |
i would imagine that if you check the DDB website, or ask, they probably have instructions that come with the kit. They may or may not provide you with instructions without buying the kit, but I wouldn't, just to protect my R&D investment
I expect that this is a pretty well engineered kit, much more so than the other "kit" available from a different supplier using shocks instead of bags. That video looks great. If I had a type 3 and the cash to do so, i would by the ddb Kit that vwfye is selling _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
