Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Mon Sep 15, 2008 9:06 pm Post subject: Spark Plug Wires that fit. |
Need some.
The ones I bought from the local aircooled parts place a while back for the square do have 90º boots on the distributor end but the wire inside is just the same old straight wire. So they don't fit very well on the type-3. And the lengths aren't letting me get nice routing, particularly from the #3 plug.
So I want to make my own. Does anybody know of a contemporary source for plug wire and ends?
Long ago, when the earth was flat and we were still young and immortal, I worked at a little service station in Vermont. We had rolls of spark plug wire and a stock of all sorts of different ends. For pretty much anything that came in, we would just pick the right ends and cut the wire to the required length. We could get it all nice and neat looking.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Sep 15, 2008 9:33 pm Post subject: |
Tell them you need some wire for your ford tractor. Then maybe you can get some solid wire.
The spark plug ends can be purchased at about any aircooled supply place.
The 90 ends for the distributor are another story.
BTW, something I noticed the last set of Bosch wires, I installed. The coil wire was a carbon core, not solid wire.
I reused the old coil wire. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Bobnotch Samba Member
Posted: Tue Sep 16, 2008 3:07 am Post subject: |
I got 10 ft of spark plug wire from Jim Adney at the Invasion. He sells the wire if you have the ends. It was enough to do the job, and let me route them like I wanted. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
MOCHABILL Samba Member
Joined: June 12, 2008 Posts: 584 Location: BY THE BAY
Posted: Tue Sep 16, 2008 5:01 pm Post subject: |
Bought this set recently,made by BOSCH with metal wires,molded caps.
09004 Type 3 Spark Plug Wires 1 $29.95
From this site, [email protected] |
tomnotch Samba Member
Joined: October 22, 2004 Posts: 788 Location: Key Peninsula, Wash.
Posted: Tue Sep 16, 2008 6:04 pm Post subject: |
Pretty sure those are the ones that I also used. really great wires and they fit really well after I put the longer T4 ends on them..
oh, yeah T4
MOCHABILL wrote: |
BOSCH with metal wires,molded caps. 09004 Type 3 Spark Plug Wires $29.95 |
_________________ Tom
DVKK
DSD, Dark Side Disciples
Progenitor |
Posted: Tue Sep 16, 2008 6:09 pm Post subject: |
I bet that is not copper core plug wire material.
I bet it is carbon core. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
KTPhil Samba Member
Posted: Tue Sep 16, 2008 8:33 pm Post subject: |
Carbon degrades and breaks when bent, increasing resistance and causing misfires and fouling. Copper inside of silicone lasts forever! |
Posted: Wed Sep 17, 2008 8:01 am Post subject: |
And, with Bosch wires, you can replace just the bad ends if needed.
I have bought Bosch wires lately, and they have fit properly.
Only problem is, if you have an early car, the coil wire is not long enough to reach the coil mounted on the other side. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop.
Dramaguy Samba Member
Joined: June 09, 2008 Posts: 159 Location: Yucaipa, CA
Posted: Tue Nov 11, 2008 12:19 pm Post subject: Re: |
I bought these wires from cip1 and they don't fit at all the wire for the coil is not even long enough to fit. Waste of money.
http://www2.cip1.com/ProductDetails.asp?ProductCode=BOS-09004 _________________ "what ever happen to sex drugs and rock n roll now we just have aids, crack and techno" |
Posted: Tue Nov 11, 2008 12:27 pm Post subject: |
There are 2 different sets of plug wires sold for T-3 from Bosch.
09 003 for the 62 through 66/67.
09 004 for the 68 through 73.
If also depends on how your distributor cap is wired. If the cap is wired properly, the wires just reach on a type 3. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
PIMPPRIDE Samba Member
Joined: November 19, 2003 Posts: 879 Location: Carson California
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Tue Nov 11, 2008 2:02 pm Post subject: |
question: are the wires stamped with what kind of core they have inside? _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
Posted: Tue Nov 11, 2008 4:29 pm Post subject: |
You just look at them. If the ends screw on, they are probably copper core. If the wires don't say Bosch on them, they are probably not copper core.
Even now, the coil wires that come in the Bosch kits is carbon core.
I rarely if ever replace the original Bosch wires. Just replace the ends, as needed. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
orbittron Samba Member
Joined: February 03, 2008 Posts: 48 Location: Houston
Posted: Tue Nov 11, 2008 7:25 pm Post subject: |
I've got to chime in on this one....
I too recently bought the "original German quality" type 3 wires from cip1. They are crap; didn't fit #3 or coil and the insulation feels like hard cheap plastic. Don't waste your $$. |
mfnheff Samba Member
Posted: Tue Nov 11, 2008 7:57 pm Post subject: |
i still don't understand why anyone would want to run a high resistance, factory style wire. and with those factory screw-on boots? don't those have a bout 1000ohms of resistance? i bought a set of cheapo accel wires and cut them myself, and it made a running engine run so much better. i was told some folks use those factory screwon ends because of am radio interference...but then i was wondering who the hell listens to am radio, and copper core wires with around 500ohms per foot don't cause enough rf frequency to actually bothering anyone, not to mention less resisitance means hotter spark, which means more fuel burnt, which means better combustion, which means more power, and better mpg.
unless all i've learned about automotive ignition systems doesn't apply to aircooled volksawagens, which would mean they're running on a totally new ignition system no one has heard about
so if anyone wants my screw on terminals, i'll send them to ya. i don't want them to waste space in a landfill somewhere, which is where they're going |
Posted: Tue Nov 11, 2008 8:56 pm Post subject: |
Copper core wires dont have any resistance. Only the ends do. And those can be replaced if needed.
VW wires are not high resistance. They are 1000 ohms per wire, and 3000 ohms for the rotor. Most carbon core wires are higher than that. (and FCC rules say that you have to have some type of suppression)
I have seen more bad carbon core wires than bad resistance ends.
As for listening to AM radio, many original T-3's only have AM radio. Besides, If I want to listen to music, I listen to my iPod. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
sima112 Samba Member
Posted: Sun Jan 19, 2020 3:13 pm Post subject: |
Russ Wolfe wrote: |
As for listening to AM radio, many original T-3's only have AM radio. Besides, If I want to listen to music, I listen to my iPod. |
Can anyone explain please how to find out if the end is bad? (higher resistance or burned or something else)
3000ohm for the rotor means the short coil cable? How do you get such a resistance if you want to make the cables? Different wire than copper?
Thank you Danny |
