Modify your sink drain line and pick up a little more room.
JPrato
JPrato is offline
PostPosted: Wed Sep 17, 2008 7:05 pm    Post subject: Modify your sink drain line and pick up a little more room. Reply with quote
I just wanted to share a modification that we made to our Westy to free up a little more room under the sink. And it is cheep. You can go with standard hardware store 1/2" pvc. Use a short section of the original hose to splice from the drain to the new pvc. Hint: heat the hose to get it to slip over the pvc. Use a hose clamp to secure. A heat gun was use to soften and bend the new pvc down pipe to get it to conform to the outside wall, moving it out of the middle lower part of the cabinet. Connect it all up with the proper angles/connectors. It was easier to split the down pipe at the upper shelf and install it as two sections. I made it go all the way to the floor then over to the drain. A large O-ring cushioned the pipe through the floor pan. As only water goes through it, the sharp corners shouldn't matter.
The bottom shelf was remade to get rid of the slit down the middle to pick up a little more shelf area.
Joe
Joe
06 Subaru Legacy turbo (how am I gonna fit this sucker into the Westy....)
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
46 Cessna 140
MootPoint
MootPoint is offline
PostPosted: Wed Sep 17, 2008 7:32 pm    Post subject: Reply with quote
Nice! I was just looking at my drain the other day (while trying to fit camping cookware into the cabinet) and said to myself, "Self? There must a way to move that drain line to give me more room."
Thanks for doing the engineering.
1984 Westy with tencentlife power!
spitsnrovers
spitsnrovers is offline
PostPosted: Wed Sep 17, 2008 8:11 pm    Post subject: Reply with quote
Neatly done JPrato!
I did away with my drain altogether as I only use the tank to heat water for showers and dishes.
But, now, has anyone figured out how to get that cutlery drawer apart to build a new back and base, avoiding that large cutout in it? I've tried, but short of braking something, I can't figure out how it might come apart.
All I really need is - how to get the front panel off so I could build a complete new drawer behind it.
PDXWesty
PDXWesty is offline
PostPosted: Thu Sep 18, 2008 8:30 am    Post subject: Reply with quote
I had done something similar only I used black rubber hose and a right angle hose fitting at the floor and clamped it all together. Nice job.
campism
campism is offline
PostPosted: Thu Sep 18, 2008 8:55 am    Post subject: Reply with quote
JPrato,
Can you elaborate on the additional electrical goodies in that sink cabinet? Thanks!
climberjohn
climberjohn is offline
PostPosted: Thu Sep 18, 2008 9:48 am    Post subject: Reply with quote
Looks to me like a Blue Sea fuse box for the aux battery. It's a bit spendy, but a nice way to go. There are many threads about this fuse box.
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
otiswesty
otiswesty is offline
PostPosted: Thu Sep 18, 2008 9:53 am    Post subject: Reply with quote
I don't know why there has to be the large PVC. I am switching to a set up like the one GW sells:
http://www.gowesty.com/ec_view_details.php?id=2424&category_id=128&category_parent_id=
I have a black right angle Ptrap, similar to the one sold by GW, that I got out of an old Adventurewagen baywindow. Not sure why the same era Westy's had a large Ptrap with overflow out the side. A 3/4" hose to the floor from there was my plan.
E
1978 Sage Green P22 Westfalia
Just a regular guy
JPrato
JPrato is offline
PostPosted: Thu Sep 18, 2008 10:10 am    Post subject: Reply with quote
campism wrote:
JPrato,
Yes, not much here that wasn't already done on this board before. The aux box is a Blue Sea Systems, model 5025. It can be found on ebay, it's very nice! This serves as the distribution point for my second battery connected with #8 wire and a 30amp master fuse. The fridge, two fridge aux fans, rear lights and power ports come off this box. I did away with the relay for the fridge. It stays on whether the engine is on or not. Nice for when you stop to eat or fuel up but it could run the battery down if you forget. One circuit runs up to the dash to power the radio and cig lighter there.
There is a 1 amp battery charger mounted above the aux box to continuously charge the battery while on shore power. This seems to be more than adequate to keep the second battery charged up with the electrical load we draw while camping. Of course you can see the liberal use of the aircraft cable clamps, I love those guys. You can get them at Aircraft Spruce http://www.aircraftspruce.com/catalog/appages/ms21919clamps.php
Joe
46 Cessna 140
kayakwesty
kayakwesty is offline
PostPosted: Thu Sep 18, 2008 11:46 am    Post subject: Reply with quote
What is the clear tubing doing? That I see in the background?
1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
B.5.5 Passat Wagen with 30v V6-67000 Miles
DAS AUTO
CHANGE YOUR FUEL LINES!
A post without pictures is useless
http://www.kayakwesty.com
http://www.waldensridgewhitewater.com/
PDXWesty
PDXWesty is offline
PostPosted: Thu Sep 18, 2008 11:53 am    Post subject: Reply with quote
That looks like a new water line to the sink. The original would have come out of the hole in the back panel.
GreenMachineVW
GreenMachineVW is offline
PostPosted: Thu Sep 18, 2008 12:04 pm    Post subject: Reply with quote
My 1983 has the same route for the water line stock:
(Not yet reconnected in this photo.)
