surf_blau Samba Member
Posted: Sun Sep 21, 2008 1:58 pm Post subject: smoke (almost fire) from under dash on attempted ignition |
Well, I got sick of the old, broken antenna on my 84.5 westy and so I put in a new hirshmann antenna from gowesty. Fine.
The first time I tried to start the van, smoke begins coming out of the steering column, I turned it off after three seconds of no cranking (thinking it was a neutral saftey switch problem on my old mb...). Just as I was reaching for the fire extinguisher, the smoke stopped.
It turns out that the black wire that connects the ignition wiring harness to the rightmost fuse on the fuse panel is totally fried. It seems like this black wire is actually 2 black wires in parallel, but I am not sure. The larger of the two black wires has had 15% of its insulation smoked off - from the entire approx 12 inch run of the wire.
Anyone got ideas about what to do next to find the root cause?
(been searching and getting ideas, but nothing is jumping out.) |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Mon Sep 22, 2008 5:26 am Post subject: |
Here's a tip: grab the Bentley wire schematic and see what that wire does. My guess is when you routed the antenna wire in from the fender to the radio, you snagged another wire and caused a short on this one. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
Vanagon Nut Samba Member
Posted: Mon Sep 22, 2008 9:07 am Post subject: |
Is this new antenna electric?
If so, did you connect it to the ignition switch wiring?
1988 West DIY 50º ABA
VE7TBN |
Posted: Tue Sep 23, 2008 9:34 am Post subject: nope, it is a non- automatic replacement for the original |
original and replacement were both manual antennas.
Can't wait to get home and do some investigation. |
Posted: Mon Sep 29, 2008 8:54 pm Post subject: summary |
the fuse box frame was in contact with the last fuse, giving a nice path to ground which allowed the starting current to melt the ignition switch. $10 part from van cafe. Too bad it took a week to get it all figured out. |
Posted: Tue Sep 30, 2008 10:05 am Post subject: Re: summary |
surf_blau wrote: |
A week well spent I say! Now you are ( I presume) more familiar with your ride.
And thanks for posting what the solution was. It helps others searching the archives (IMHO) to see the solution. Most listers do this, but some don't. I know I've been guilty of that.
Cheers,
VE7TBN |
