iceracer Samba Member
Joined: February 28, 2006 Posts: 949 Location: Milwaukee, Wisconsin
Posted: Mon Sep 22, 2008 10:34 am Post subject: Loose CV Bolts |
SOOOO, I finally got around to pulling the left inner cv on my daily driver syncro due to gear oil leaking out of the cv boot. Lord have mercy!!! About a quart of gear oil drained out of it. The plug on the flange was out and floating around in there, hence the leak. Plug was fine so I permatexed it back in. New cv grease and bolted it back up. Amazing how gear lube will clean a cv.
Then I noticed the left outer cv had major play. Stuck my hand in there and one bolt was loose. As it turns out, the bolt snapped off and the other bolts were loose. So I tightened up the other five and let it go. Now I know why it made a clunk in back when in reverse.
Moral of the story is, If you hear a noise that it shouldn't be making, don't ignore it, fix it. I ignored it for a few years. Yikes. Could have left me stranded. Will have to yank it out later when I have more time and fix it right, yeah right like that will happen!!! _________________ 86 Syncro Wolfsburg edition
63 Beetle (The Iceracer) |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Mon Sep 22, 2008 11:40 am Post subject: |
That story scares me! I hear odd noises all the time, which for the most part I ignore unless it seems like something I should look at. _________________ -- 1987 Westfalia automatic (Captain Vino) |
foodeater Samba Member
Joined: July 13, 2007 Posts: 1318 Location: Newburgh, NY
Posted: Mon Sep 22, 2008 12:01 pm Post subject: |
Perales wrote: |
That story scares me! I hear odd noises all the time, which for the most part I ignore unless it seems like something I should look at. |
Its the kind of story that gets told around the fire at a campout. We Vanagon owners have a different kind of scary story. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP |
